Atomic PUT to CXone Voice Bot TTS endpoint returns 422 with SSML tuning matrix
Hi all,
Problem
I’m building an Express middleware to sync TTS configs via callbacks for our GC webhooks. The atomic PUT to the org-level TTS settings endpoint fails when I bundle SSML markup with pronunciation dictionary directives.
Latency tracking shows the phonetic alignment pipeline blocks the request.
Code
 "voiceId": "en-US-Standard-A",
 "ssmlTemplate": "<prosody rate='fast'>{{text}}</prosody>",
 "tuningMatrix": {"pitch": 0.2, "speed": 1.1},
 "pronunciationDict": "custom_phonetics_v2"
Error
Returns 422 Unprocessable Entity. It’s choking on the prosody boundary verification pipeline.
Question
How do I structure the payload to bypass the max SSML complexity limit without triggering the audio preview failure?
Cause: The 422 error fires because the CXone gateway treats the pronunciation dictionary as a webhook payload instead of a standard config object, which matches that broken TTS sync thread from last year.
Solution: Sorry for the rookie question, but the phonetic routing layer still chokes on bundled matrices, so you don’t need to send the dictionary in the body at all. Just isolate the tuning object like this:
{ "voiceId": "en-US-Standard-A", "ssmlTemplate": "{{text}}", "tuningMatrix": { "pitch": 0.2, "speed": 1.1 } }
Hi all,
The atomic PUT approach fails because the CXone gateway validates the schema strictly. Here’s what the testing cycle revealed:
  • Bundled pronunciationDict with tuningMatrix in a single payload
  • Gateway returned 422 due to conflicting validation rules
  • Split the request into sequential PATCH operations
  • Tuning parameters applied correctly, but SSML overrides dropped during reconciliation
CXone routes dictionary updates through a separate sub-resource. The gateway won’t accept the combined payload. It’s strictly enforced on the v2 endpoints. Takes a bit of work to align the state file, but the math checks out. Keeping the main configuration lean prevents the phonetic alignment pipeline from blocking the request. Use this structure for the primary endpoint:
State drift happens fast if the state file retains the old dictionary reference after the split.
What’s the exact status code on the fallback retry attempt?
PureCloudPlatformClientV2 rejects the pronunciationDict array inside the configuration body because the schema strictly expects a reference ID string, not the raw object data. You’ve got to upload the dictionary resource separately first to get the generated ID, then include only that ID in the main PUT request. The 422 error fires when the gateway tries to parse the nested object against the string field definition. It’s a common trip up with the JS SDK validation. The schema is strict on that one. Splitting the upload and the config update resolves the schema mismatch immediately. The tuning matrix can stay in the body as long as the dictionary is removed. Just make sure the ID matches the region scope.
 "tuningMatrix": { "pitch": 0.2, "speed": 1.1 },
 "pronunciationDictionaryId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
