Assigning Genesys Cloud Task Management Work Items with Node.js
A Node.js assignment engine that validates agent skill matches and workload capacity, executes atomic task assignments via PATCH, triggers notification payloads, syncs assignment events to external webhooks, and tracks latency and success metrics. This tutorial uses the Genesys Cloud Task Management and Routing APIs. This implementation covers JavaScript and Node.js.
- OAuth Client Type: Confidential Client (Client Credentials Grant)
- Required Scopes:
task:write,routing:read,routing:write,analytics:read - SDK Version:
@genesyscloud/node-sdkv13.0.0 or higher - Runtime: Node.js 18.0.0 or higher
- External Dependencies:
@genesyscloud/node-sdk,axios,uuid
The Genesys Cloud Node.js SDK handles token acquisition and caching automatically when initialized with a confidential client. You must provide your environment host, client ID, and client secret. The SDK attaches the Bearer token to every request and refreshes it before expiration.
const { PureCloudPlatformClientV2 } = require('@genesyscloud/node-sdk');
* Initializes the Genesys Cloud SDK with client credentials flow.
* @param {Object} config - SDK configuration
* @returns {PureCloudPlatformClientV2} Initialized platform client
function initializeSdk(config) {
const platformClient = new PureCloudPlatformClientV2();
platformClient.setEnvironment(config.environment || 'mypurecloud.com');
platformClient.loginClientCredentials(config.clientId, config.clientSecret);
return platformClient;
The loginClientCredentials method requires task:write and routing:read scopes configured in the Genesys Cloud Admin Console under Applications. The SDK caches the access token in memory and automatically refreshes it when the HTTP response returns a 401 Unauthorized status.
Step 1: Validate Task Assignment Schema and Depth Limits
Before modifying a task, you must verify that the assignment payload conforms to Genesys constraints. The tasking engine enforces a maxAssignments limit and requires a valid assignedTo UUID. You will also validate the dueDate directive against ISO 8601 format.
const { v4: uuidv4 } = require('uuid');
* Validates the assignment payload against Genesys tasking engine constraints.
* @param {Object} task - Existing task object from GET /api/v2/tasks/{taskId}
* @param {Object} payload - Proposed assignment payload
* @returns {Object} Validation result with isValid flag and error message
function validateAssignmentSchema(task, payload) {
const errors = [];
// Verify assignedTo is a valid UUID
if (!payload.assignedTo || !/^[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}$/i.test(payload.assignedTo)) {
errors.push('assignedTo must be a valid UUID.');
// Verify max assignment depth
if (task.maxAssignments !== undefined) {
const currentAssignments = task.assignments ? task.assignments.length : 0;
if (currentAssignments >= task.maxAssignments) {
errors.push(`Task has reached maximum assignment depth of ${task.maxAssignments}.`);
// Verify dueDate directive format
if (payload.dueDate) {
const date = new Date(payload.dueDate);
if (isNaN(date.getTime())) {
errors.push('dueDate must be a valid ISO 8601 timestamp.');
if (date < new Date()) {
errors.push('dueDate cannot be in the past.');
isValid: errors.length === 0,
errors: errors,
requestId: uuidv4()
OAuth Scope Required: task:write
Expected Response: Returns { isValid: true, errors: [], requestId: '...' } or lists constraint violations.
Error Handling: Throws a custom validation error if isValid is false, preventing downstream API calls.
Step 2: Verify Agent Skill Match and Workload Capacity
Genesys routing relies on skill profiles and queue workload to determine agent availability. You will query the agent’s routing profile and active work items to ensure optimal utilization. This step prevents task backlog during scaling events.
* Checks agent skill match and current workload capacity.
* @param {PureCloudPlatformClientV2} platformClient - Authenticated SDK instance
* @param {string} agentId - UUID of the target agent
* @param {Array<string>} requiredSkills - Array of skill names required for the task
* @param {number} maxActiveWork - Maximum allowed active work items for the agent
* @returns {Object} Verification result
async function verifyAgentCapacity(platformClient, agentId, requiredSkills, maxActiveWork) {
// Fetch routing profile and skill assignments
const routingApi = new platformClient.RoutingApi();
const userRoutingProfile = await routingApi.getRoutingUser(agentId);
const agentSkills = userRoutingProfile.skillProfiles
? userRoutingProfile.skillProfiles.map(sp => sp.skill.name)
// Skill match verification pipeline
const missingSkills = requiredSkills.filter(skill => !agentSkills.includes(skill));
if (missingSkills.length > 0) {
isValid: false,
reason: `Skill mismatch. Agent lacks: ${missingSkills.join(', ')}`
// Workload balance checking via active work items
const workApi = new platformClient.RoutingApi();
const activeWork = await workApi.getRoutingUserWork(agentId, {
expand: ['workType']
const activeCount = activeWork.entities ? activeWork.entities.length : 0;
if (activeCount >= maxActiveWork) {
isValid: false,
reason: `Workload limit reached. Agent has ${activeCount} active items.`
return { isValid: true, activeWorkCount: activeCount };
} catch (error) {
if (error.code === 401 || error.code === 403) {
throw new Error(`Routing verification failed: Insufficient permissions. Ensure routing:read scope is granted.`);
if (error.code === 429) {
throw new Error('Routing verification rate-limited. Implement exponential backoff.');
throw new Error(`Agent capacity verification failed: ${error.message}`);
OAuth Scope Required: routing:read
Expected Response: Returns { isValid: true, activeWorkCount: 2 } or details the rejection reason.
Error Handling: Catches 401/403 for scope issues, 429 for rate limits, and generic 5xx for routing service degradation.
Step 3: Execute Atomic PATCH with Notification Trigger
The assignment operation uses an atomic PATCH /api/v2/tasks/{taskId} request. The payload updates assignedTo and dueDate in a single transaction. Immediately after assignment, you trigger a notification payload to alert the agent via the Genesys notification engine.
* Executes atomic task assignment and triggers agent notification.
* @param {string} taskId - UUID of the target task
* @param {Object} assignPayload - Assignment data
* @returns {Object} Assignment result with latency tracking
async function executeAssignment(platformClient, taskId, assignPayload) {
const startTime = Date.now();
const tasksApi = new platformClient.TasksApi();
// Construct atomic PATCH body
const patchBody = {
assignedTo: assignPayload.assignedTo,
dueDate: assignPayload.dueDate ? new Date(assignPayload.dueDate).toISOString() : undefined,
status: assignPayload.status || 'pending'
// Atomic PATCH operation
const updatedTask = await tasksApi.patchTask(taskId, patchBody);
// Trigger automatic notification
const notificationPayload = {
notificationType: 'assignment',
recipientId: assignPayload.assignedTo,
subject: 'New Task Assignment',
body: `Task ${taskId} assigned with due date ${patchBody.dueDate || 'none'}.`,
priority: 'normal'
await tasksApi.postTaskNotification(taskId, notificationPayload);
const latencyMs = Date.now() - startTime;
success: true,
taskId: taskId,
latencyMs: latencyMs,
} catch (error) {
throw new Error(`Assignment rate-limited (429). Retry with backoff. Latency: ${latencyMs}ms`);
if (error.code === 409) {
throw new Error(`Conflict (409). Task state changed during assignment window.`);
throw new Error(`Assignment failed: ${error.message}`);
Expected Response: Returns success object with latencyMs and assignment timestamp.
Error Handling: Catches 429 for rate limits, 409 for concurrent modification conflicts, and propagates SDK exceptions for 5xx failures.
Step 4: Webhook Sync, Latency Tracking, and Audit Logging
You will synchronize assignment events to an external workforce planner via webhook, track assignment latency and success rates in a metrics registry, and generate structured audit logs for governance compliance.
class TaskAssignerMetrics {
constructor() {
this.totalAttempts = 0;
this.successfulAssignments = 0;
this.latencySamples = [];
recordAttempt(result) {
this.totalAttempts++;
if (result.success) {
this.successfulAssignments++;
this.latencySamples.push(result.latencyMs);
getSuccessRate() {
return this.totalAttempts === 0 ? 0 : (this.successfulAssignments / this.totalAttempts) * 100;
getAverageLatency() {
if (this.latencySamples.length === 0) return 0;
return this.latencySamples.reduce((a, b) => a + b, 0) / this.latencySamples.length;
* Syncs assignment event to external webhook and records audit/metrics.
* @param {Object} config - Webhook URL and metrics instance
* @param {Object} assignmentResult - Result from executeAssignment
* @param {string} requestId - Correlation ID
async function syncAndAudit(config, assignmentResult, requestId) {
// Webhook synchronization for workforce planners
const webhookPayload = {
event: 'task.assigned',
requestId: requestId,
taskId: assignmentResult.taskId,
agentId: assignmentResult.assignedTo,
timestamp: assignmentResult.timestamp,
latencyMs: assignmentResult.latencyMs
await axios.post(config.webhookUrl, webhookPayload, {
timeout: 5000
} catch (webhookError) {
console.error(`[WEBHOOK_SYNC] Failed to notify external planner: ${webhookError.message}`);
// Audit logging for task governance
const auditLog = {
level: 'INFO',
component: 'TaskAssigner',
action: 'ASSIGN_TASK',
targetTaskId: assignmentResult.taskId,
targetAgentId: assignmentResult.assignedTo,
outcome: assignmentResult.success ? 'SUCCESS' : 'FAILURE',
latencyMs: assignmentResult.latencyMs,
console.log(JSON.stringify(auditLog));
// Update metrics registry
config.metrics.recordAttempt(assignmentResult);
OAuth Scope Required: None (internal sync)
Expected Response: Prints structured JSON audit log and posts to webhook URL.
Error Handling: Catches webhook timeout and network failures without blocking the assignment flow. Metrics track success rate and average latency for scaling decisions.
The following module integrates all steps into a reusable TaskAssigner class. It handles retry logic for 429 responses, validates schemas, checks capacity, executes assignments, and maintains audit trails.
class TaskAssigner {
constructor(config) {
this.platformClient = new PureCloudPlatformClientV2();
this.platformClient.setEnvironment(config.environment || 'mypurecloud.com');
this.platformClient.loginClientCredentials(config.clientId, config.clientSecret);
this.webhookUrl = config.webhookUrl;
this.metrics = {
totalAttempts: 0,
successfulAssignments: 0,
latencySamples: []
* Orchestrates the full assignment workflow with retry logic.
* @param {Object} assignmentRequest - Contains taskId, assignedTo, dueDate, requiredSkills, maxActiveWork
* @returns {Object} Final assignment result
async assignTask(assignmentRequest) {
const requestId = assignmentRequest.requestId || `req-${Date.now()}`;
let attempts = 0;
const maxRetries = 3;
while (attempts < maxRetries) {
// Step 1: Fetch current task state
const tasksApi = new this.platformClient.TasksApi();
const task = await tasksApi.getTask(assignmentRequest.taskId);
// Step 2: Validate schema and depth limits
const validation = {
isValid: true,
errors: []
if (!assignmentRequest.assignedTo || !/^[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}$/i.test(assignmentRequest.assignedTo)) {
validation.isValid = false;
validation.errors.push('Invalid assignedTo UUID.');
if (task.maxAssignments !== undefined && (task.assignments?.length || 0) >= task.maxAssignments) {
validation.errors.push('Max assignment depth reached.');
if (!validation.isValid) {
throw new Error(`Validation failed: ${validation.errors.join(' | ')}`);
// Step 3: Verify agent capacity and skills
const capacityCheck = await this.verifyAgentCapacity(assignmentRequest.assignedTo, assignmentRequest.requiredSkills || [], assignmentRequest.maxActiveWork || 10);
if (!capacityCheck.isValid) {
throw new Error(`Capacity check failed: ${capacityCheck.reason}`);
// Step 4: Execute atomic assignment
const result = await this.executeAssignment(assignmentRequest.taskId, assignmentRequest);
// Step 5: Sync and audit
await this.syncAndAudit(result, requestId);
return result;
} catch (error) {
attempts++;
if (error.message.includes('429') && attempts < maxRetries) {
const backoffMs = Math.pow(2, attempts) * 1000;
console.warn(`[RETRY] Rate limited. Backing off ${backoffMs}ms. Attempt ${attempts}/${maxRetries}`);
await new Promise(resolve => setTimeout(resolve, backoffMs));
continue;
throw error;
throw new Error('Max retries exceeded for assignment.');
async verifyAgentCapacity(agentId, requiredSkills, maxActiveWork) {
const routingApi = new this.platformClient.RoutingApi();
const agentSkills = userRoutingProfile.skillProfiles ? userRoutingProfile.skillProfiles.map(sp => sp.skill.name) : [];
return { isValid: false, reason: `Skill mismatch. Agent lacks: ${missingSkills.join(', ')}` };
const activeWork = await routingApi.getRoutingUserWork(agentId, { expand: ['workType'] });
return { isValid: false, reason: `Workload limit reached. Agent has ${activeCount} active items.` };
async executeAssignment(taskId, payload) {
const patchBody = {
assignedTo: payload.assignedTo,
dueDate: payload.dueDate ? new Date(payload.dueDate).toISOString() : undefined,
status: payload.status || 'pending'
recipientId: payload.assignedTo,
priority: 'normal'
success: true,
taskId: taskId,
async syncAndAudit(result, requestId) {
taskId: result.taskId,
agentId: result.assignedTo,
timestamp: result.timestamp,
latencyMs: result.latencyMs
await axios.post(this.webhookUrl, webhookPayload, { headers: { 'Content-Type': 'application/json' }, timeout: 5000 });
} catch (err) {
console.error(`[WEBHOOK_SYNC] Failed: ${err.message}`);
const auditLog = {
level: 'INFO',
targetTaskId: result.taskId,
targetAgentId: result.assignedTo,
outcome: 'SUCCESS',
latencyMs: result.latencyMs,
this.metrics.totalAttempts++;
this.metrics.successfulAssignments++;
this.metrics.latencySamples.push(result.latencyMs);
getMetrics() {
successRate: this.metrics.totalAttempts === 0 ? 0 : (this.metrics.successfulAssignments / this.metrics.totalAttempts) * 100,
averageLatencyMs: this.metrics.latencySamples.length === 0 ? 0 : this.metrics.latencySamples.reduce((a, b) => a + b, 0) / this.metrics.latencySamples.length,
totalProcessed: this.metrics.totalAttempts
module.exports = { TaskAssigner };
Run the module by importing TaskAssigner, instantiating it with your OAuth credentials, and calling assignTask() with a valid request object. The class exposes metrics via getMetrics() for monitoring assignment efficiency.
- Cause: OAuth token expired, invalid client credentials, or missing
task:writescope. - Fix: Verify the client ID and secret match the Genesys Cloud Application configuration. Ensure the application has the
task:writeandrouting:readscopes enabled. The SDK automatically refreshes tokens, but initial login must succeed. - Code Fix: Wrap initialization in a try-catch block and log the exact error message from
loginClientCredentials.
Error: 403 Forbidden
- Cause: The OAuth client lacks role permissions for the target task queue or routing profile.
- Fix: Assign the OAuth client a role with
Task AdministratororRouting Administratorpermissions. Verify theassignedTouser belongs to the same organization as the task. - Code Fix: Check the
error.messagepayload from the SDK. It returns the exact permission denial reason.
- Cause: Exceeded Genesys API rate limits for task PATCH operations or routing queries.
- Fix: Implement exponential backoff. The complete example includes a retry loop with
Math.pow(2, attempts) * 1000delay. Monitor theRetry-Afterheader if returned. - Code Fix: The
assignTaskmethod already handles 429 retries. IncreasemaxRetriesif your workload requires higher throughput.
Error: 409 Conflict
- Cause: Concurrent modification of the task. Another process changed the task state between the GET and PATCH operations.
- Fix: Implement optimistic locking by reading the
versionfield from the GET response and including it in the PATCH headers if required by your task type. The SDK handles standard ETag validation automatically. - Code Fix: Retry the entire workflow after a short delay, as shown in the retry logic.
