ASR and TTS integration with GVP
We are in the process of migrating to Vocalizer 6 and GVP8.5 we have installed Vocalizer on linux machine, and configured GVP with the following parameters .
Template: GVP_Nuace6_851
Created application and gave the connection in MCP to this application. I haven’t specified a working directory in the nuance application.
I have changed the options to use MRCPV2
vrm.client.resource.: sip:mresources@:
We are getting TTS resrouce not found while packing a call.
Although, I see the call initation in from MCP to TTS engine. Also i see from the logs on TTS engine that the request is received but not fulfilled.
Let me know if I am missing any configuration here
Post your MRCP object configuration
This is working. It’s an issue with language pack and NSS on vocalizer machine.
