Archiving NICE CXone Flow Execution Logs with Node.js and the Flow API
- A Node.js service that retrieves NICE CXone flow execution logs, validates them against retention constraints, compresses them using gzip, and posts atomic archive batches to an external analytics webhook.
- This implementation uses the NICE CXone Flow API endpoint
GET /api/v2/flows/{flowId}/versions/{versionId}/executions/{executionId}/logsand OAuth 2.0 Client Credentials authentication. - The code uses modern Node.js 18+ syntax with native
fetch,zlibfor compression, andajvfor strict schema validation.
- OAuth 2.0 Client Credentials grant type with
flow:readandwebhook:writescopes - NICE CXone API version 2.x
- Node.js 18.0 or higher (for native
fetchand modernasync/await) - External dependencies:
ajv(JSON schema validation),ajv-formats(date validation support) - Environment variables:
CXONE_BASE_URL,CXONE_CLIENT_ID,CXONE_CLIENT_SECRET,ARCHIVE_WEBHOOK_URL,MAX_RETENTION_DAYS,MAX_ARCHIVE_BYTES
NICE CXone uses OAuth 2.0 for API authentication. You must exchange your client credentials for an access token before calling any Flow API endpoints. The token expires after a fixed duration, so you must implement refresh logic.
import https from 'node:https';
import { URL } from 'node:url';
const CXONE_BASE_URL = process.env.CXONE_BASE_URL || 'https://api.mycxone.com';
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
export async function acquireOAuthToken() {
const auth = Buffer.from(`${CLIENT_ID}:${CLIENT_SECRET}`).toString('base64');
const tokenUrl = new URL('/oauth/token', CXONE_BASE_URL).toString();
const body = new URLSearchParams({
scope: 'flow:read webhook:write'
const response = await fetch(tokenUrl, {
method: 'POST',
headers: {
'Authorization': `Basic ${auth}`,
'Content-Type': 'application/x-www-form-urlencoded'
body: body
if (!response.ok) {
const errorText = await response.text();
throw new Error(`OAuth token acquisition failed (${response.status}): ${errorText}`);
const data = await response.json();
accessToken: data.access_token,
expiresIn: data.expires_in,
issuedAt: Date.now()
The response returns access_token, expires_in, and token_type. You must cache the token and request a new one when Date.now() + expiresIn * 1000 exceeds the current timestamp. The flow:read scope is required for retrieving execution logs. The webhook:write scope is required if you post archive confirmation events back to CXone.
Step 1: Fetch Flow Execution Logs with Pagination and Rate Limit Handling
The Flow API returns execution logs in paginated batches. You must handle 429 Too Many Requests responses with exponential backoff to prevent rate limit cascades. The endpoint supports pageToken and pageSize parameters.
export async function fetchFlowExecutionLogs(
accessToken,
flowId,
versionId,
executionId,
pageSize = 200
let allLogs = [];
let pageToken = null;
let retryCount = 0;
const maxRetries = 5;
do {
const url = new URL(`/api/v2/flows/${flowId}/versions/${versionId}/executions/${executionId}/logs`, CXONE_BASE_URL);
url.searchParams.set('pageSize', pageSize.toString());
if (pageToken) url.searchParams.set('pageToken', pageToken);
const response = await fetch(url.toString(), {
method: 'GET',
headers: {
'Authorization': `Bearer ${accessToken}`,
'Accept': 'application/json'
if (response.status === 429) {
const retryAfter = parseInt(response.headers.get('Retry-After') || '2', 10);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000 * (retryCount + 1)));
retryCount++;
continue;
if (!response.ok) {
throw new Error(`Flow API request failed (${response.status})`);
allLogs = allLogs.concat(data.entities || data);
pageToken = data.pageToken || null;
retryCount = 0;
} catch (error) {
if (retryCount >= maxRetries) throw error;
retryCount++;
await new Promise(resolve => setTimeout(resolve, Math.pow(2, retryCount) * 1000));
} while (pageToken);
return allLogs;
The request targets GET /api/v2/flows/{flowId}/versions/{versionId}/executions/{executionId}/logs. The response contains an array of log entries with flowExecutionId, stepId, timestamp, and debugMessage. The 429 handler reads the Retry-After header and applies exponential backoff. Pagination continues until pageToken is null.
Step 2: Validate Logs Against Flow Constraints and Maximum Retention Limits
You must validate the log structure against a defined schema and filter entries that exceed your retention policy. NICE CXone flow logs follow a predictable structure. You will use ajv to enforce type safety and date boundaries.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const ajv = new Ajv();
addFormats(ajv);
const flowLogSchema = {
type: 'object',
required: ['flowExecutionId', 'stepId', 'timestamp', 'stepType'],
properties: {
flowExecutionId: { type: 'string', format: 'uuid' },
stepId: { type: 'string' },
timestamp: { type: 'string', format: 'date-time' },
stepType: { type: 'string', enum: ['start', 'end', 'error', 'transition', 'data'] },
debugMessage: { type: 'string' },
flowMatrix: { type: 'object' }
additionalProperties: false
const validateLogSchema = ajv.compile(flowLogSchema);
export function validateAndFilterLogs(logs, maxRetentionDays) {
const cutoffDate = new Date();
cutoffDate.setDate(cutoffDate.getDate() - maxRetentionDays);
const validLogs = [];
const auditErrors = [];
for (const log of logs) {
const schemaValid = validateLogSchema(log);
if (!schemaValid) {
auditErrors.push({ logId: log.stepId, reason: 'schema_violation', errors: validateLogSchema.errors });
continue;
const logDate = new Date(log.timestamp);
if (logDate < cutoffDate) {
auditErrors.push({ logId: log.stepId, reason: 'retention_exceeded', timestamp: log.timestamp });
continue;
// Incomplete-trace checking: ensure flow has matching start/end or explicit error marker
if (log.stepType === 'start' && !log.flowMatrix?.hasEndMarker) {
auditErrors.push({ logId: log.stepId, reason: 'incomplete_trace' });
continue;
validLogs.push(log);
return { validLogs, auditErrors };
The schema enforces UUID format for flowExecutionId, ISO 8601 for timestamp, and restricts stepType to known flow states. The retention filter calculates a cutoff date based on MAX_RETENTION_DAYS. The incomplete-trace check verifies that flow matrices contain proper termination markers. Logs failing validation are routed to auditErrors for governance reporting.
Step 3: Compress Payloads and Verify Storage Quotas
Before transmission, you must compress the validated logs using gzip. You must also verify that the compressed payload does not exceed your storage quota or trigger disk exhaustion during scaling events.
import zlib from 'node:zlib';
import { promisify } from 'node:util';
const gzipAsync = promisify(zlib.gzip);
export async function compressAndVerifyQuota(validLogs, maxArchiveBytes) {
const payload = JSON.stringify({
archiveMetadata: {
created: new Date().toISOString(),
totalEntries: validLogs.length,
compressDirective: 'gzip-std',
flowMatrixIncluded: validLogs.some(l => !!l.flowMatrix)
logs: validLogs
const compressed = await gzipAsync(payload);
if (compressed.byteLength > maxArchiveBytes) {
throw new Error(`Archive quota exceeded: ${compressed.byteLength} bytes exceeds limit of ${maxArchiveBytes}`);
compressedBuffer: compressed,
originalSize: Buffer.byteLength(payload),
compressedSize: compressed.byteLength,
compressionRatio: (1 - compressed.byteLength / Buffer.byteLength(payload)).toFixed(2)
The compression directive uses standard gzip via zlib. The function returns metadata including the compression ratio. If the compressed buffer exceeds MAX_ARCHIVE_BYTES, the operation fails fast to prevent storage quota violations. The payload includes a compressDirective field for downstream parsers and a flowMatrixIncluded flag for trace reconstruction.
Step 4: Atomic Archive POST and Webhook Synchronization
You must post the compressed archive to your external log analytics system using an atomic HTTP POST. You will track latency, success rates, and generate audit logs for flow governance. The webhook synchronization ensures alignment between CXone execution state and your archive index.
export async function postArchiveToWebhook(compressedData, webhookUrl, auditLogger) {
const startTime = Date.now();
let attempt = 0;
const maxAttempts = 3;
let success = false;
while (attempt < maxAttempts && !success) {
const response = await fetch(webhookUrl, {
method: 'POST',
headers: {
'Content-Type': 'application/gzip',
'X-Archive-Format': 'cxone-flow-log-v2',
'X-Compression-Ratio': compressedData.compressionRatio
body: compressedData.compressedBuffer
if (!response.ok) {
throw new Error(`Webhook POST failed (${response.status})`);
success = true;
const latency = Date.now() - startTime;
auditLogger.info('archive_success', {
entries: compressedData.metadata.totalEntries,
compressedSize: compressedData.compressedSize,
latencyMs: latency,
return { success: true, latency };
} catch (error) {
attempt++;
if (attempt < maxAttempts) {
await new Promise(resolve => setTimeout(resolve, Math.pow(2, attempt) * 1000));
} else {
auditLogger.error('archive_failure', {
error: error.message,
attempts: attempt,
throw error;
The POST operation uses application/gzip content type to signal compressed payloads. Custom headers expose the archive format version and compression ratio for analytics indexing. The function implements atomic retry logic with exponential backoff. Latency and success metrics are written to the audit logger for governance reporting. The webhook URL points to your external log analytics ingestion endpoint.
The following script combines all components into a production-ready Node.js module. It reads configuration from environment variables, manages token lifecycle, fetches logs, validates constraints, compresses data, and posts archives with full error handling and audit tracking.
import { acquireOAuthToken } from './auth.js';
import { fetchFlowExecutionLogs } from './logs.js';
import { validateAndFilterLogs } from './validation.js';
import { compressAndVerifyQuota } from './compression.js';
import { postArchiveToWebhook } from './webhook.js';
const MAX_RETENTION_DAYS = parseInt(process.env.MAX_RETENTION_DAYS || '30', 10);
const MAX_ARCHIVE_BYTES = parseInt(process.env.MAX_ARCHIVE_BYTES || '10485760', 10);
const ARCHIVE_WEBHOOK_URL = process.env.ARCHIVE_WEBHOOK_URL;
const auditLogger = {
info: (event, data) => console.log(JSON.stringify({ event, level: 'info', ...data })),
error: (event, data) => console.error(JSON.stringify({ event, level: 'error', ...data }))
async function runFlowLogArchiver(flowId, versionId, executionId) {
auditLogger.info('archiver_start', { flowId, versionId, executionId });
const token = await acquireOAuthToken();
const rawLogs = await fetchFlowExecutionLogs(token.accessToken, flowId, versionId, executionId);
const { validLogs, auditErrors } = validateAndFilterLogs(rawLogs, MAX_RETENTION_DAYS);
if (auditErrors.length > 0) {
auditLogger.info('validation_filtered', {
totalRaw: rawLogs.length,
validCount: validLogs.length,
filteredCount: auditErrors.length
if (validLogs.length === 0) {
auditLogger.info('archiver_skip', { reason: 'no_valid_logs_after_filtering' });
return;
const compressed = await compressAndVerifyQuota(validLogs, MAX_ARCHIVE_BYTES);
const result = await postArchiveToWebhook(compressed, ARCHIVE_WEBHOOK_URL, auditLogger);
auditLogger.info('archiver_complete', {
success: result.success,
latencyMs: result.latency,
compressionRatio: compressed.compressionRatio
} catch (error) {
auditLogger.error('archiver_fatal', {
message: error.message,
stack: error.stack
process.exit(1);
// Execution entry point
const args = process.argv.slice(2);
if (args.length !== 3) {
console.error('Usage: node archiver.js <flowId> <versionId> <executionId>');
process.exit(1);
runFlowLogArchiver(args[0], args[1], args[2]);
Run the script with node archiver.js <flowId> <versionId> <executionId>. The script outputs structured JSON audit logs to stdout. You can redirect output to a file or pipe it to your logging aggregator. All environment variables must be set before execution. The token acquisition, log fetching, validation, compression, and webhook posting execute sequentially with explicit error boundaries.
- What causes it: The OAuth token has expired, the client credentials are incorrect, or the token was not included in the
Authorizationheader. - How to fix it: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETmatch your CXone admin console configuration. Implement token caching with a five-minute buffer beforeexpires_in. - Code showing the fix: Add a token cache wrapper that checks
Date.now() > token.issuedAt + (token.expiresIn - 300) * 1000before reuse.
Error: 403 Forbidden
- What causes it: The OAuth client lacks the
flow:readscope, or the execution ID belongs to a flow version restricted by tenant policies. - How to fix it: Update the OAuth client in the CXone admin console to include
flow:read. Verify theflowIdandversionIdmatch an active flow configuration. - Code showing the fix: Log the
response.headers.get('x-cxone-error')header for specific policy violation details.
- What causes it: You exceeded the CXone API rate limit (typically 100 requests per minute per tenant for Flow API).
- How to fix it: Implement exponential backoff with
Retry-Afterheader parsing. ReducepageSizeto decrease payload size and request frequency. - Code showing the fix: The
fetchFlowExecutionLogsfunction already implementsRetry-Afterparsing and exponential backoff. Add a global request queue if running parallel archivers.
Error: 400 Bad Request
- What causes it: Schema validation failed due to malformed log entries, or the compressed payload exceeds the target webhook size limit.
- How to fix it: Inspect
auditErrorsfrom the validation step. AdjustMAX_ARCHIVE_BYTESif your external system supports larger chunks. Split archives into smaller batches if quota limits are strict. - Code showing the fix: Modify
compressAndVerifyQuotato return partial batches when approaching quota limits instead of throwing.
