Archiving NICE CXone Case Management Records with Java
A Java service that queries resolved NICE CXone cases, validates them against retention policies and compliance windows, constructs batch archive payloads, executes atomic HTTP PUT operations, tracks latency and success metrics, generates structured audit logs, and synchronizes archival events with an external data lake.
This implementation uses the NICE CXone Case Management REST API and Spring WebClient for HTTP operations.
The tutorial covers Java 17 with modern async/await patterns via reactive streams.
  • NICE CXone OAuth 2.0 Client ID and Client Secret
  • Required OAuth scopes: cases:read, cases:write
  • Java 17 or later
  • Dependencies: spring-webflux, jackson-databind, micrometer-core, slf4j-api
  • Maven or Gradle build system
  • Active CXone instance with Case Management enabled
NICE CXone uses the standard OAuth 2.0 Client Credentials flow. The service must fetch an access token before making API calls and cache it until expiration. The token endpoint returns an expires_in field in seconds.
import org.springframework.web.reactive.function.client.WebClient;
import java.time.Instant;
import java.util.Map;
public class CxoneAuthManager {
    private final WebClient webClient;
    private final String baseUrl;
    private final String clientId;
    private final String clientSecret;
    private final Map<String, Object> tokenCache = new ConcurrentHashMap<>();
    private final ObjectMapper mapper = new ObjectMapper();
    public CxoneAuthManager(String baseUrl, String clientId, String clientSecret) {
        this.baseUrl = baseUrl;
        this.clientId = clientId;
        this.webClient = WebClient.builder().baseUrl(baseUrl).build();
    public String getAccessToken() throws Exception {
        Instant now = Instant.now();
        Instant expiresAt = Instant.ofEpochSecond((Long) tokenCache.getOrDefault("expires_at", 0L));
        if (now.isBefore(expiresAt.minusSeconds(60))) {
            return (String) tokenCache.get("access_token");
        JsonNode response = webClient.post()
                .uri("/api/v2/oauth/token")
                .header("Content-Type", "application/x-www-form-urlencoded")
                .bodyValue("grant_type=client_credentials&client_id=" + clientId + "&client_secret=" + clientSecret)
                .retrieve()
                .bodyToMono(JsonNode.class)
                .block();
        if (response == null || response.path("access_token").isNull()) {
            throw new RuntimeException("OAuth token retrieval failed: " + response);
        String token = response.path("access_token").asText();
        int expiresIn = response.path("expires_in").asInt();
        tokenCache.put("access_token", token);
        tokenCache.put("expires_at", now.getEpochSecond() + expiresIn);
        return token;
Step 1: Query Resolved Cases and Validate Constraints
The query endpoint returns cases in pages. You must paginate through results, filter for resolved cases, and validate each record against compliance windows and duplicate archive states. The compliance window check prevents archiving cases under legal hold. The duplicate check verifies the case status is not already set to archived.
import java.util.ArrayList;
import java.util.List;
import java.util.stream.Stream;
public class CxoneCaseValidator {
    private final int complianceWindowDays = 7;
    public CxoneCaseValidator(WebClient webClient) {
        this.webClient = webClient;
    public List<JsonNode> fetchAndValidateResolvedCases(String token) throws Exception {
        List<JsonNode> validCases = new ArrayList<>();
        String nextPageToken = null;
        do {
            String body = nextPageToken == null
                    ? "{\"query\":{\"field\":\"status\",\"operator\":\"eq\",\"value\":\"resolved\"}}"
                    : "{\"query\":{\"field\":\"status\",\"operator\":\"eq\",\"value\":\"resolved\"},\"nextPageToken\":\"" + nextPageToken + "\"}";
                    .uri("/api/v2/cases/cases/query")
                    .bodyValue(body)
                    .retrieve()
                    .block();
            JsonNode items = response.path("items");
            if (items.isArray()) {
                StreamSupport.stream(items.spliterator(), false)
                        .filter(this::passesComplianceAndDuplicateCheck)
                        .forEach(validCases::add);
            nextPageToken = response.path("nextPageToken").isNull() ? null : response.path("nextPageToken").asText();
        } while (nextPageToken != null);
        return validCases;
    private boolean passesComplianceAndDuplicateCheck(JsonNode caseNode) {
        String status = caseNode.path("status").asText();
        if (!"resolved".equals(status)) return false;
        long updatedTimestamp = caseNode.path("updatedTimestamp").asLong(0);
        Instant updatedTime = Instant.ofEpochMilli(updatedTimestamp);
        Instant cutoff = Instant.now().minusSeconds(complianceWindowDays * 86400);
        if (updatedTime.isAfter(cutoff)) {
            return false;
        String caseType = caseNode.path("caseTypeId").asText();
        if ("LEGAL_HOLD".equals(caseType)) {
            return false;
        return true;
Step 2: Construct Archive Payloads and Enforce Batch Limits
CXone enforces maximum batch limits for bulk operations. The service groups valid cases into batches of 500 records. Each batch payload includes a record-ref (the case ID), a case-matrix mapping type to retention rules, and a store directive indicating archive storage tier. The service also calculates a compression ratio by comparing original payload size against a simulated archived footprint.
import com.fasterxml.jackson.databind.node.ObjectNode;
import java.util.HashMap;
public class CxoneArchivePayloadBuilder {
    private static final int MAX_BATCH_SIZE = 500;
    public List<ArchiveBatch> constructBatches(List<JsonNode> cases) throws Exception {
        List<ArchiveBatch> batches = new ArrayList<>();
        List<JsonNode> currentBatch = new ArrayList<>();
        Map<String, Object> caseMatrix = Map.of(
                "SUPPORT", Map.of("retention_days", 365, "tier", "standard"),
                "SALES", Map.of("retention_days", 180, "tier", "compressed"),
                "COMPLIANCE", Map.of("retention_days", 2555, "tier", "immutable")
        for (JsonNode caseNode : cases) {
            currentBatch.add(caseNode);
            if (currentBatch.size() == MAX_BATCH_SIZE) {
                batches.add(createBatch(currentBatch, caseMatrix));
        if (!currentBatch.isEmpty()) {
        return batches;
    private ArchiveBatch createBatch(List<JsonNode> cases, Map<String, Object> matrix) throws Exception {
        ObjectNode payload = mapper.createObjectNode();
        payload.putArray("record_refs").addAll(cases.stream()
                .map(c -> c.path("id").asText())
                .map(mapper::createTextNode)
                .toArray(JsonNode[]::new));
        payload.set("case_matrix", mapper.valueToTree(matrix));
        payload.set("store_directive", mapper.createObjectNode()
                .put("action", "archive")
                .put("trigger_index", true)
                .put("verify_format", true));
        String jsonPayload = mapper.writeValueAsString(payload);
        int originalSize = jsonPayload.getBytes().length;
        int simulatedArchivedSize = (int) (originalSize * 0.35);
        double compressionRatio = (double) (originalSize - simulatedArchivedSize) / originalSize;
        return new ArchiveBatch(
                cases.stream().map(c -> c.path("id").asText()).toList(),
                jsonPayload,
                compressionRatio
    public record ArchiveBatch(List<String> caseIds, String payload, double compressionRatio) {}
Step 3: Execute Atomic PUT Operations, Track Metrics, and Sync Webhooks
The service iterates through batches and executes atomic HTTP PUT operations to /api/v2/cases/cases/{caseId} for each record. The implementation includes exponential backoff for 429 rate limit responses, latency tracking per operation, success rate calculation, audit log generation, and webhook payload construction for external data lake synchronization.
import org.springframework.web.reactive.function.client.WebClientResponseException;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
public class CxoneCaseArchiver {
    private final AtomicLong totalLatencyNs = new AtomicLong(0);
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger failureCount = new AtomicInteger(0);
    private final List<String> auditLogs = new ArrayList<>();
    private final String webhookUrl;
    public CxoneCaseArchiver(WebClient webClient, String webhookUrl) {
        this.webhookUrl = webhookUrl;
    public ArchiveMetrics processBatch(CxoneArchivePayloadBuilder.ArchiveBatch batch, String token) throws Exception {
        for (String caseId : batch.caseIds()) {
            boolean archived = archiveSingleCase(caseId, token);
            if (archived) {
                successCount.incrementAndGet();
                generateAuditLog(caseId, "ARCHIVE_SUCCESS", Instant.now());
                triggerWebhookSync(caseId, "SUCCESS");
            } else {
                failureCount.incrementAndGet();
                generateAuditLog(caseId, "ARCHIVE_FAILURE", Instant.now());
                triggerWebhookSync(caseId, "FAILURE");
        double avgLatencyMs = totalLatencyNs.get() / (double) (successCount.get() + failureCount.get()) / 1_000_000;
        double successRate = (double) successCount.get() / (successCount.get() + failureCount.get());
        return new ArchiveMetrics(avgLatencyMs, successRate, batch.compressionRatio());
    private boolean archiveSingleCase(String caseId, String token) {
        String url = "/api/v2/cases/cases/" + caseId;
        String payload = "{\"status\":\"archived\",\"archiveTimestamp\":\"" + Instant.now().toString() + "\"}";
        for (int attempt = 0; attempt < 4; attempt++) {
                long start = System.nanoTime();
                webClient.put()
                        .uri(url)
                        .bodyValue(payload)
                        .retrieve()
                        .toBodilessEntity()
                        .block();
                long elapsed = System.nanoTime() - start;
                totalLatencyNs.addAndGet(elapsed);
                return true;
            } catch (WebClientResponseException e) {
                if (e.getStatusCode().value() == 429 && attempt < 3) {
                    long delay = (long) Math.pow(2, attempt) * 1000;
                    try { Thread.sleep(delay); } catch (InterruptedException ignored) {}
                } else {
                    return false;
            } catch (Exception e) {
                return false;
        return false;
    private void generateAuditLog(String caseId, String event, Instant timestamp) {
        ObjectNode log = mapper.createObjectNode();
        log.put("case_id", caseId);
        log.put("event", event);
        log.put("timestamp", timestamp.toString());
        log.put("operator", "CXONE_ARCHIVER_V1");
        auditLogs.add(mapper.writeValueAsString(log));
    private void triggerWebhookSync(String caseId, String status) {
            ObjectNode webhookPayload = mapper.createObjectNode();
            webhookPayload.put("record_ref", caseId);
            webhookPayload.put("sync_status", status);
            webhookPayload.put("data_lake_target", "s3://compliance-archive/cases/");
            webhookPayload.put("event_time", Instant.now().toString());
            webClient.post()
                    .uri(webhookUrl)
                    .bodyValue(mapper.writeValueAsString(webhookPayload))
                    .retrieve()
                    .toBodilessEntity()
                    .block();
            System.err.println("Webhook sync failed for case " + caseId + ": " + e.getMessage());
    public record ArchiveMetrics(double avgLatencyMs, double successRate, double compressionRatio) {}
The following class orchestrates authentication, validation, payload construction, and archival execution. Replace the placeholder credentials and base URL with your CXone environment values.
public class CxoneArchiveRunner {
        String baseUrl = "https://api.mynicecxone.com";
        String clientId = "YOUR_CLIENT_ID";
        String clientSecret = "YOUR_CLIENT_SECRET";
        String webhookUrl = "https://your-data-lake-endpoint.com/webhooks/cxone-archive";
        WebClient baseClient = WebClient.builder().build();
        CxoneAuthManager auth = new CxoneAuthManager(baseUrl, clientId, clientSecret);
        WebClient apiClient = WebClient.builder().baseUrl(baseUrl).build();
            String token = auth.getAccessToken();
            System.out.println("OAuth token acquired.");
            CxoneCaseValidator validator = new CxoneCaseValidator(apiClient);
            List<JsonNode> resolvedCases = validator.fetchAndValidateResolvedCases(token);
            System.out.println("Validated " + resolvedCases.size() + " resolved cases.");
            CxoneArchivePayloadBuilder builder = new CxoneArchivePayloadBuilder();
            List<CxoneArchivePayloadBuilder.ArchiveBatch> batches = builder.constructBatches(resolvedCases);
            System.out.println("Constructed " + batches.size() + " archive batches.");
            CxoneCaseArchiver archiver = new CxoneCaseArchiver(apiClient, webhookUrl);
            for (CxoneArchivePayloadBuilder.ArchiveBatch batch : batches) {
                CxoneCaseArchiver.ArchiveMetrics metrics = archiver.processBatch(batch, token);
                System.out.println("Batch processed. Avg Latency: " + String.format("%.2f", metrics.avgLatencyMs()) + "ms | Success Rate: " + String.format("%.2f", metrics.successRate()) + " | Compression: " + String.format("%.2f", metrics.compressionRatio()));
            System.out.println("Archival pipeline completed.");
            System.err.println("Pipeline failed: " + e.getMessage());
            e.printStackTrace();
  • What causes it: The OAuth token has expired, the client credentials are incorrect, or the scope cases:read or cases:write is missing from the OAuth client configuration.
  • How to fix it: Verify the client ID and secret in the CXone admin console. Ensure the OAuth client has both required scopes assigned. Implement token refresh logic before the expires_in window closes.
  • Code showing the fix: The CxoneAuthManager.getAccessToken() method caches tokens and refreshes them sixty seconds before expiration to prevent mid-request authentication failures.
Error: 403 Forbidden
  • What causes it: The authenticated user lacks permissions to update cases or archive records. Case Management API enforces role-based access control.
  • How to fix it: Assign the Case Manager or Administrator role to the OAuth application user. Verify that the target cases belong to queues or groups the application has access to.
  • What causes it: CXone enforces rate limits per API endpoint and per tenant. Bulk archival operations trigger rapid sequential PUT requests.
  • How to fix it: Implement exponential backoff with jitter. The archiveSingleCase method retries up to three times with increasing delays (1s, 2s, 4s) when a 429 response is received.
  • Code showing the fix: The retry loop in archiveSingleCase catches WebClientResponseException, checks for status 429, sleeps for Math.pow(2, attempt) * 1000 milliseconds, and reissues the request.
Error: 400 Bad Request
  • What causes it: The payload schema violates CXone case constraints. Common issues include invalid caseTypeId, missing required fields, or attempting to archive cases that are not in a resolved or closed state.
  • How to fix it: Validate the status field before constructing the archive payload. Ensure the case-matrix references valid type IDs. Verify that the store_directive matches supported archive tiers.
  • Code showing the fix: The passesComplianceAndDuplicateCheck method filters out cases that are not resolved, fall within the compliance window, or match legal hold types.
Error: 5xx Server Errors
  • What causes it: Temporary CXone backend failures, database locks, or index trigger timeouts during archive commits.
  • How to fix it: Implement circuit breaker patterns or dead letter queues for failed batches. Retry the entire batch after a fixed cooldown period. Log the exact case IDs for manual reconciliation.
  • Code showing the fix: The processBatch method tracks success and failure counts. Failed case IDs are recorded in audit logs and webhook payloads for external retry orchestration.
