Archiving NICE Cognigy.AI Deprecated Dialogue Flow Versions via REST API with Go
- A Go service that identifies deprecated bot versions, validates dependency graphs, constructs archival payloads with migration matrices and rollback directives, and executes atomic archival operations against the NICE Cognigy.AI REST API.
- This tutorial uses the Cognigy.AI v1 REST API surface for bot version management, endpoint resolution, and flow dependency mapping.
- The implementation is written in Go 1.21+ using standard library HTTP clients, context-aware cancellation, and production-grade error handling.
- Cognigy.AI tenant with API access enabled
- OAuth2 client credentials with scopes:
bot:read,bot:write,version:manage,endpoint:read,flow:read - Go 1.21 or higher
- Standard library only:
net/http,context,encoding/json,time,sync,crypto/sha256,compress/gzip,io,bytes,log,fmt - Environment variables:
COGNIGY_TENANT,COGNIGY_CLIENT_ID,COGNIGY_CLIENT_SECRET,COGNIGY_AUTH_URL,ARCHIVE_WEBHOOK_URL,MAX_ARCHIVE_BYTES
Cognigy.AI uses an OAuth2 authorization server for programmatic access. The client credentials flow returns a JWT that must be attached to every request. Token caching prevents unnecessary re-authentication, and automatic refresh logic handles expiration before archival operations begin.
package cognigyarchiver
import (
"bytes"
"context"
"crypto/sha256"
"encoding/json"
"fmt"
"io"
"net/http"
"os"
"sync"
"time"
type AuthConfig struct {
TenantURL string
ClientID string
ClientSecret string
AuthURL string
type TokenResponse struct {
type OAuthClient struct {
config AuthConfig
token *TokenResponse
mu sync.RWMutex
client *http.Client
func NewOAuthClient(cfg AuthConfig) *OAuthClient {
return &OAuthClient{
config: cfg,
client: &http.Client{Timeout: 15 * time.Second},
func (o *OAuthClient) GetToken(ctx context.Context) (string, error) {
o.mu.RLock()
if o.token != nil && o.token.ExpiresIn > 30 {
token := o.token.AccessToken
o.mu.RUnlock()
return token, nil
o.mu.RUnlock()
o.mu.Lock()
defer o.mu.Unlock()
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s",
o.config.ClientID, o.config.ClientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, o.config.AuthURL, bytes.NewBufferString(payload))
if err != nil {
return "", fmt.Errorf("auth request creation failed: %w", err)
resp, err := o.client.Do(req)
if err != nil {
return "", fmt.Errorf("auth network error: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("auth failed with status %d: %s", resp.StatusCode, string(body))
var tokenResp TokenResponse
return "", fmt.Errorf("auth token decode error: %w", err)
o.token = &tokenResp
return tokenResp.AccessToken, nil
The GetToken method implements read-write locking to allow concurrent requests while serializing token refresh. The JWT is cached until expiration minus a thirty-second safety margin. All subsequent API calls will extract this token before constructing requests.
Step 1: Version Discovery and Constraint Validation
The archival process begins by enumerating bot versions and filtering deprecated candidates. Cognigy.AI returns version lists with pagination parameters. The validation pipeline checks version control constraints, verifies maximum archive size limits, and calculates compression ratios before proceeding.
type BotVersion struct {
ID string `json:"id"`
Name string `json:"name"`
IsArchived bool `json:"isArchived"`
IsDeprecated bool `json:"isDeprecated"`
IsLocked bool `json:"isLocked"`
CreatedAt string `json:"createdAt"`
SizeBytes int64 `json:"sizeBytes"`
type VersionListResponse struct {
Data []BotVersion `json:"data"`
Total int `json:"total"`
Next string `json:"next"`
func (o *OAuthClient) FetchDeprecatedVersions(ctx context.Context, botID string, maxBytes int64) ([]BotVersion, error) {
token, err := o.GetToken(ctx)
if err != nil {
return nil, fmt.Errorf("token retrieval failed: %w", err)
var deprecated []BotVersion
page := 0
limit := 50
for {
url := fmt.Sprintf("%s/api/v1/bots/%s/versions?limit=%d&offset=%d",
o.config.TenantURL, botID, limit, page*limit)
req, err := http.NewRequestWithContext(ctx, http.MethodGet, url, nil)
if err != nil {
return nil, fmt.Errorf("request build failed: %w", err)
req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
if err != nil {
return nil, fmt.Errorf("network error: %w", err)
retryAfter := 2
if ra := resp.Header.Get("Retry-After"); ra != "" {
fmt.Sscanf(ra, "%d", &retryAfter)
time.Sleep(time.Duration(retryAfter) * time.Second)
return nil, fmt.Errorf("version fetch failed %d: %s", resp.StatusCode, string(body))
var pageResp VersionListResponse
if err := json.NewDecoder(resp.Body).Decode(&pageResp); err != nil {
return nil, fmt.Errorf("version decode error: %w", err)
for _, v := range pageResp.Data {
if v.IsDeprecated && !v.IsArchived && !v.IsLocked && v.SizeBytes <= maxBytes {
deprecated = append(deprecated, v)
if pageResp.Next == "" {
break
page++
return deprecated, nil
Pagination uses a cursor-based next field when available, falling back to offset calculation. The size constraint check prevents archival failures caused by exceeding tenant storage quotas. The 429 retry logic respects the Retry-After header and implements exponential backoff implicitly through the response directive.
Step 2: Dependency Pruning and Reference Verification
Before archiving, the system must verify that no active endpoints reference the deprecated flows. Circular reference detection prevents deployment conflicts during Cognigy scaling. The validation pipeline queries endpoint bindings and flow graphs to construct a clean dependency matrix.
type EndpointBinding struct {
FlowID string `json:"flowId"`
IsActive bool `json:"isActive"`
type FlowGraph struct {
References []string `json:"references"`
IsOrphan bool `json:"isOrphan"`
func (o *OAuthClient) ValidateDependencies(ctx context.Context, botID string, versionID string) (bool, error) {
if err != nil {
return false, fmt.Errorf("token retrieval failed: %w", err)
// Fetch active endpoints
epURL := fmt.Sprintf("%s/api/v1/bots/%s/endpoints?isActive=true", o.config.TenantURL, botID)
epReq, _ := http.NewRequestWithContext(ctx, http.MethodGet, epURL, nil)
epReq.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
epResp, err := o.client.Do(epReq)
if err != nil {
return false, fmt.Errorf("endpoint fetch failed: %w", err)
defer epResp.Body.Close()
var endpoints []EndpointBinding
if err := json.NewDecoder(epResp.Body).Decode(&endpoints); err != nil {
return false, fmt.Errorf("endpoint decode error: %w", err)
// Fetch flow graph for the version
flowURL := fmt.Sprintf("%s/api/v1/bots/%s/versions/%s/flows", o.config.TenantURL, botID, versionID)
flowReq, _ := http.NewRequestWithContext(ctx, http.MethodGet, flowURL, nil)
flowReq.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
flowResp, err := o.client.Do(flowReq)
if err != nil {
return false, fmt.Errorf("flow fetch failed: %w", err)
defer flowResp.Body.Close()
var flows []FlowGraph
if err := json.NewDecoder(flowResp.Body).Decode(&flows); err != nil {
return false, fmt.Errorf("flow decode error: %w", err)
// Orphan endpoint checking
for _, ep := range endpoints {
for _, f := range flows {
if ep.FlowID == f.ID && f.IsOrphan {
return false, fmt.Errorf("orphan endpoint detected: %s references orphaned flow %s", ep.ID, f.ID)
// Circular reference verification
visited := make(map[string]bool)
var detectCycle func(flowID string, path []string) bool
detectCycle = func(flowID string, path []string) bool {
for _, p := range path {
if p == flowID {
return true
if visited[flowID] {
return false
visited[flowID] = true
path = append(path, flowID)
if f.ID == flowID {
for _, ref := range f.References {
if detectCycle(ref, path) {
return true
return false
if detectCycle(f.ID, nil) {
return false, fmt.Errorf("circular reference detected in flow %s", f.ID)
return true, nil
The dependency validator performs two critical checks. First, it cross-references active endpoints against orphaned flows to prevent broken routing after archival. Second, it runs a depth-first traversal to detect circular references that would block deployment pipelines. Both checks return a boolean status and descriptive errors when constraints are violated.
Step 3: Archival Payload Construction and Atomic Execution
The final step constructs the archival payload containing bot version references, migration path matrices, and rollback retention directives. The payload is compressed, validated against schema constraints, and submitted via an atomic POST operation. Webhook callbacks synchronize external artifact repositories, while latency and compression metrics feed into audit logging.
type MigrationPath struct {
SourceVersion string `json:"sourceVersion"`
TargetVersion string `json:"targetVersion"`
RoutingRule string `json:"routingRule"`
type RollbackDirective struct {
MaxRetentionDays int `json:"maxRetentionDays"`
StorageTier string `json:"storageTier"`
AutoPurgeEnabled bool `json:"autoPurgeEnabled"`
type ArchivePayload struct {
BotVersionReference string `json:"botVersionReference"`
MigrationPathMatrix []MigrationPath `json:"migrationPathMatrix"`
RollbackRetention RollbackDirective `json:"rollbackRetentionDirective"`
Metadata map[string]interface{} `json:"metadata"`
func (o *OAuthClient) ArchiveVersion(ctx context.Context, botID string, versionID string, payload ArchivePayload, webhookURL string) error {
if err != nil {
return fmt.Errorf("token retrieval failed: %w", err)
jsonData, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("payload serialization failed: %w", err)
// Compression tracking
var compressed bytes.Buffer
gzWriter := gzip.NewWriter(&compressed)
if _, err := gzWriter.Write(jsonData); err != nil {
return fmt.Errorf("compression failed: %w", err)
gzWriter.Close()
compressionRatio := float64(len(jsonData)) / float64(compressed.Len())
checksum := sha256.Sum256(compressed.Bytes())
startTime := time.Now()
url := fmt.Sprintf("%s/api/v1/bots/%s/versions/%s/archive", o.config.TenantURL, botID, versionID)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, &compressed)
if err != nil {
return fmt.Errorf("archive request build failed: %w", err)
req.Header.Set("Content-Type", "application/gzip")
req.Header.Set("X-Checksum", fmt.Sprintf("%x", checksum))
req.Header.Set("X-Compression-Ratio", fmt.Sprintf("%.2f", compressionRatio))
if err != nil {
return fmt.Errorf("archive network error: %w", err)
retryAfter := 2
return o.ArchiveVersion(ctx, botID, versionID, payload, webhookURL)
if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
return fmt.Errorf("archive failed %d: %s", resp.StatusCode, string(body))
latency := time.Since(startTime).Milliseconds()
// Webhook synchronization
go func() {
hookPayload := map[string]interface{}{
"event": "version_archived",
"botID": botID,
"version": versionID,
"latency": latency,
"checksum": fmt.Sprintf("%x", checksum),
"timestamp": time.Now().UTC().Format(time.RFC3339),
hookData, _ := json.Marshal(hookPayload)
hookReq, _ := http.NewRequest(http.MethodPost, webhookURL, bytes.NewBuffer(hookData))
hookReq.Header.Set("Content-Type", "application/json")
http.DefaultClient.Do(hookReq)
// Audit log
log.Printf("ARCHIVE_AUDIT | bot=%s version=%s latency=%dms compression=%.2f checksum=%x",
botID, versionID, latency, compressionRatio, checksum)
return nil
The archival function compresses the JSON payload to reduce network transfer time and calculates a SHA-256 checksum for integrity verification. The atomic POST operation includes custom headers for compression tracking and checksum validation. A background goroutine dispatches the webhook callback to external artifact repositories without blocking the main execution thread. Audit logging captures latency, compression ratios, and cryptographic hashes for release governance compliance.
The following script orchestrates the full archival workflow. It loads configuration from environment variables, discovers deprecated versions, validates dependencies, constructs archival payloads, and executes the atomic archival sequence.
package main
import (
"context"
"fmt"
"log"
"os"
"strconv"
"time"
cognigy "cognigyarchiver"
func main() {
ctx, cancel := context.WithTimeout(context.Background(), 5*time.Minute)
defer cancel()
tenant := os.Getenv("COGNIGY_TENANT")
clientID := os.Getenv("COGNIGY_CLIENT_ID")
clientSecret := os.Getenv("COGNIGY_CLIENT_SECRET")
authURL := os.Getenv("COGNIGY_AUTH_URL")
webhookURL := os.Getenv("ARCHIVE_WEBHOOK_URL")
maxBytes, _ := strconv.ParseInt(os.Getenv("MAX_ARCHIVE_BYTES"), 10, 64)
if maxBytes == 0 {
maxBytes = 50 * 1024 * 1024 // 50MB default
auth := cognigy.NewOAuthClient(cognigy.AuthConfig{
TenantURL: fmt.Sprintf("https://%s.cognigy.ai", tenant),
ClientID: clientID,
ClientSecret: clientSecret,
AuthURL: authURL,
botID := os.Getenv("COGNIGY_BOT_ID")
if botID == "" {
log.Fatal("COGNIGY_BOT_ID environment variable is required")
deprecated, err := auth.FetchDeprecatedVersions(ctx, botID, maxBytes)
if err != nil {
log.Fatalf("version discovery failed: %v", err)
if len(deprecated) == 0 {
log.Println("No deprecated versions found for archival")
return
for _, v := range deprecated {
log.Printf("Validating version %s...", v.ID)
valid, err := auth.ValidateDependencies(ctx, botID, v.ID)
if err != nil {
log.Printf("Validation failed for %s: %v", v.ID, err)
if !valid {
log.Printf("Version %s failed dependency checks", v.ID)
payload := cognigy.ArchivePayload{
BotVersionReference: v.ID,
MigrationPathMatrix: []cognigy.MigrationPath{
{SourceVersion: v.ID, TargetVersion: "current", RoutingRule: "fallback_to_latest"},
RollbackRetention: cognigy.RollbackDirective{
MaxRetentionDays: 30,
StorageTier: "cold",
AutoPurgeEnabled: true,
Metadata: map[string]interface{}{
"archivedBy": "automated_pipeline",
"reason": "deprecated_flow_cleanup",
if err := auth.ArchiveVersion(ctx, botID, v.ID, payload, webhookURL); err != nil {
log.Printf("Archival failed for %s: %v", v.ID, err)
log.Printf("Successfully archived version %s", v.ID)
The orchestrator iterates through deprecated versions, applies validation gates, constructs standardized archival payloads, and executes the archival sequence. Context timeouts prevent indefinite hangs during network operations. All failures are logged with descriptive messages, allowing safe continuation of the archival pipeline.
- Cause: Expired JWT, invalid client credentials, or missing OAuth scopes.
- Fix: Verify
COGNIGY_CLIENT_IDandCOGNIGY_CLIENT_SECRETmatch the Cognigy identity provider configuration. Ensure the client hasbot:writeandversion:managescopes. The token cache automatically refreshes, but network timeouts during auth will propagate 401 responses. - Code Fix: The
GetTokenmethod returns detailed error wrapping. Add retry logic around the initial authentication call if the identity provider experiences transient failures.
Error: 403 Forbidden
- Cause: Insufficient permissions for the specific bot or version lock state.
- Fix: Confirm the API client is assigned to the target bot in the Cognigy tenant. Versions marked
isLocked: trueare excluded by the validation filter. If a locked version must be archived, unlock it via the admin console or use an elevated service account. - Code Fix: The
FetchDeprecatedVersionsmethod explicitly filters!v.IsLocked. Adjust the filter if administrative overrides are required.
- Cause: Rate limiting triggered by rapid pagination or concurrent archival calls.
- Fix: The implementation respects the
Retry-Afterheader and pauses execution. For high-volume tenants, implement exponential backoff with jitter. TheArchiveVersionmethod includes recursive retry on 429 responses. - Code Fix: Add a maximum retry counter to prevent infinite recursion during prolonged rate limiting events.
Error: Circular Reference or Orphan Endpoint Detected
- Cause: Active endpoints reference deprecated flows, or flows reference each other in a loop.
- Fix: Resolve endpoint bindings before archival. Update routing rules to point to active flows. The dependency validator returns specific error messages identifying the conflicting IDs.
- Code Fix: The
ValidateDependenciesmethod halts execution on detection. Implement a dry-run mode that logs conflicts without failing the pipeline.
