Archiving Genesys Cloud Web Messaging Transcripts via Node.js with Validation and Webhook Synchronization
  • A Node.js module that retrieves web messaging transcripts, validates them against retention and storage constraints, normalizes text, extracts metadata, and archives them atomically.
  • Uses the Genesys Cloud Analytics API and Conversations API with the @gen.cloud/genesyscloud-node-sdk.
  • Covers Node.js 18+ with modern async/await, native fetch, and zlib compression.
  • OAuth 2.0 Client Credentials flow (confidential client)
  • Required scopes: analytics:query, webchat:read, retention:read, webhook:write
  • SDK: @gen.cloud/genesyscloud-node-sdk ^1.0.0
  • Runtime: Node.js 18+ (ESM modules)
  • External dependencies: zod (schema validation), uuid (audit tracking)
  • Access to an external storage endpoint (S3-compatible or REST API) for the archive destination
Genesys Cloud uses OAuth 2.0 Client Credentials for server-to-server integrations. The SDK handles token acquisition and automatic refresh, but you must configure the base path and scopes before initializing the client.
import { PureCloudPlatformClientV2 } from '@gen.cloud/genesyscloud-node-sdk';
export class GenesysAuthManager {
  #client;
  #tokenExpiry;
  constructor(baseUrl, clientId, clientSecret) {
    this.#client = new PureCloudPlatformClientV2();
    this.#client.setBasePath(baseUrl);
    this.#client.loginClientCredentials(clientId, clientSecret);
    this.#tokenExpiry = Date.now() + (89 * 60 * 1000); // 89 minutes default
  getClient() {
    return this.#client;
  isTokenExpired() {
    return Date.now() >= this.#tokenExpiry;
  async refreshIfExpired() {
    if (this.isTokenExpired()) {
      const authResponse = await this.#client.Auth.loginClientCredentials(
        process.env.GENESYS_CLIENT_ID,
        process.env.GENESYS_CLIENT_SECRET
      this.#tokenExpiry = Date.now() + (authResponse.expires_in * 1000);
The loginClientCredentials method caches the bearer token internally. The wrapper above adds explicit expiry tracking to prevent silent 401 failures during long-running archive batches.
Step 1: Transcript Retrieval and Payload Construction
The Analytics API returns conversation details in paginated batches. You must construct the archiving payload with the required transcript-ref, format-matrix, and store directive fields before validation.
export async function fetchWebMessagingTranscripts(client, dateFrom, dateTo) {
  const analyticsApi = client.Analytics;
  const query = {
    dateFrom,
    dateTo,
    view: 'webchat',
    query: {
      select: ['id', 'transcript', 'retentionPolicyId', 'startTime', 'endTime']
  const response = await analyticsApi.postAnalyticsConversationsDetailsQuery(query);
  return response.body.entities || [];
export function buildArchivePayload(transcriptEntity) {
    'transcript-ref': {
      conversationId: transcriptEntity.id,
      view: 'webchat',
      fetchedAt: new Date().toISOString()
    'format-matrix': {
      version: '2.1',
      encoding: 'UTF-8',
      structure: 'flat',
      normalization: 'ansi-stripped-html-decoded'
    'store': {
      directive: 'archive',
      destination: 'external-bucket',
      compression: 'gzip',
      retentionAlignment: transcriptEntity.retentionPolicyId
    transcript: transcriptEntity.transcript || []
The view: 'webchat' parameter targets Genesys Cloud web messaging conversations. The payload structure separates reference metadata from the raw transcript array, enabling downstream systems to validate format compliance before ingestion.
Step 2: Validation Pipeline (Retention, Quota, Encoding, Completeness)
Archiving failures occur when transcripts violate retention rules, exceed storage quotas, contain truncated messages, or use invalid byte sequences. This pipeline validates all constraints before compression.
import { z } from 'zod';
const ArchiveSchema = z.object({
  'transcript-ref': z.object({
    conversationId: z.string().uuid(),
    view: z.literal('webchat'),
    fetchedAt: z.string().datetime()
  'format-matrix': z.object({
    version: z.string(),
    encoding: z.literal('UTF-8'),
    structure: z.literal('flat'),
    normalization: z.string()
  'store': z.object({
    directive: z.literal('archive'),
    destination: z.string(),
    compression: z.literal('gzip'),
    retentionAlignment: z.string().nullable()
  transcript: z.array(z.object({
    timestamp: z.string().datetime(),
    direction: z.enum(['agent', 'customer', 'system']),
    type: z.string(),
    text: z.string().nullable()
export async function validateArchivePayload(payload, client, maxStorageBytes) {
  // Schema validation
  const parsed = ArchiveSchema.safeParse(payload);
  if (!parsed.success) {
    throw new Error(`Schema validation failed: ${parsed.error.message}`);
  // Retention constraint check
  if (payload['store'].retentionAlignment) {
    const retentionApi = client.Retention;
    const policies = await retentionApi.getRetentionPolicies();
    const policy = policies.body.entities.find(p => p.id === payload['store'].retentionAlignment);
    if (!policy) {
      throw new Error(`RetentionPolicyId ${payload['store'].retentionAlignment} not found.`);
    if (policy.retentionPeriod < 30) {
      throw new Error(`Policy retention period ${policy.retentionPeriod} days is below archival minimum.`);
  // Storage quota estimation
  const estimatedSize = new TextEncoder().encode(JSON.stringify(payload)).length;
  if (estimatedSize > maxStorageBytes) {
    throw new Error(`Payload exceeds maximum storage quota limit of ${maxStorageBytes} bytes.`);
  // Incomplete message checking
  const incompleteMessages = payload.transcript.filter(msg =>
    msg.direction !== 'system' && (!msg.text || msg.text.trim().length === 0)
  if (incompleteMessages.length > 0) {
    throw new Error(`Found ${incompleteMessages.length} incomplete messages with missing text.`);
  // Encoding mismatch verification
  for (const msg of payload.transcript) {
    if (msg.text) {
      const bytes = new TextEncoder().encode(msg.text);
      // Verify valid UTF-8 by decoding and comparing length
      const decoded = new TextDecoder('utf-8', { fatal: true }).decode(bytes);
      if (decoded.length !== msg.text.length) {
        throw new Error(`Encoding mismatch detected in message at ${msg.timestamp}.`);
  return true;
The pipeline uses zod for strict schema enforcement, queries the retention API to verify policy compliance, estimates byte size against quota limits, checks for empty customer/agent turns, and validates UTF-8 integrity using TextDecoder with the fatal: true flag.
Step 3: Text Normalization and Metadata Extraction
Raw transcripts contain HTML entities, ANSI escape codes, and inconsistent whitespace. Normalization ensures searchable history and prevents storage bloat.
export function normalizeTranscriptText(text) {
  if (!text) return null;
  // Remove ANSI escape codes
  let cleaned = text.replace(/\x1b\[[0-9;]*m/g, '');
  // Decode common HTML entities
  const entityMap = {
    '&amp;': '&', '&lt;': '<', '&gt;': '>', '&quot;': '"', '&#39;': "'", '&nbsp;': ' '
  cleaned = cleaned.replace(/&(amp|lt|gt|quot|#39|nbsp);/g, match => entityMap[match]);
  // Normalize whitespace
  cleaned = cleaned.replace(/\s+/g, ' ').trim();
  return cleaned;
export function extractMetadata(transcriptArray) {
  const metadata = {
    participantCount: 0,
    messageCount: transcriptArray.length,
    durationMs: 0,
    agentIds: new Set(),
    customerIds: new Set()
  let firstTimestamp = null;
  let lastTimestamp = null;
  for (const msg of transcriptArray) {
    if (!firstTimestamp) firstTimestamp = msg.timestamp;
    lastTimestamp = msg.timestamp;
    if (msg.direction === 'agent') metadata.agentIds.add(msg.senderId);
    if (msg.direction === 'customer') metadata.customerIds.add(msg.senderId);
  if (firstTimestamp && lastTimestamp) {
    metadata.durationMs = new Date(lastTimestamp).getTime() - new Date(firstTimestamp).getTime();
  metadata.participantCount = metadata.agentIds.size + metadata.customerIds.size;
  metadata.agentIds = Array.from(metadata.agentIds);
  metadata.customerIds = Array.from(metadata.customerIds);
  return metadata;
Normalization strips formatting artifacts that increase storage footprint without adding semantic value. Metadata extraction calculates conversation duration, participant counts, and sender identifiers for downstream analytics.
Step 4: Atomic HTTP POST with Compression and Retry Logic
The archiving operation must be atomic. Compression reduces payload size, and retry logic handles Genesys Cloud or external store rate limits.
import zlib from 'zlib';
import { setTimeout } from 'timers/promises';
export async function archiveToExternalStore(payload, externalEndpoint, apiKey) {
  const startTime = performance.now();
  // Format verification before compression
  await validateArchivePayload(payload, null, 10 * 1024 * 1024); // 10MB limit
  // Text normalization
  const normalizedTranscript = payload.transcript.map(msg => ({
    ...msg,
    text: normalizeTranscriptText(msg.text)
  payload.transcript = normalizedTranscript;
  // Add extracted metadata
  payload._metadata = extractMetadata(payload.transcript);
  // Automatic compress trigger
  const jsonPayload = JSON.stringify(payload);
  const compressed = zlib.gzipSync(jsonPayload);
  // Retry configuration for 429 and 5xx errors
  const maxRetries = 3;
  let attempt = 0;
  while (attempt < maxRetries) {
      const response = await fetch(externalEndpoint, {
        method: 'POST',
        headers: {
          'Content-Encoding': 'gzip',
          'Authorization': `Bearer ${apiKey}`,
          'X-Archive-Format': '2.1',
          'X-Compression': 'gzip'
        body: compressed
      if (response.ok) {
        const latency = performance.now() - startTime;
          success: true,
          latencyMs: latency,
          status: response.status,
          headers: Object.fromEntries(response.headers)
      if (response.status === 429) {
        const retryAfter = parseInt(response.headers.get('Retry-After') || '5', 10);
        await setTimeout(retryAfter * 1000);
        attempt++;
        continue;
      if (response.status >= 500) {
        await setTimeout(Math.pow(2, attempt) * 1000);
        attempt++;
        continue;
      throw new Error(`Archive failed with status ${response.status}: ${await response.text()}`);
    } catch (error) {
      if (attempt === maxRetries - 1) throw error;
      attempt++;
The function normalizes text, extracts metadata, compresses the payload, and POSTs it atomically. The retry loop respects Retry-After headers for 429 responses and applies exponential backoff for 5xx errors. The Content-Encoding: gzip header signals the external store to decompress automatically.
Step 5: Webhook Synchronization, Metrics, and Audit Logging
Genesys Cloud emits conversation:transcript:stored webhooks when transcripts become available. You must register the webhook, track latency and success rates, and generate audit logs for retention governance.
export class TranscriptArchiver {
  #metrics = { total: 0, success: 0, failed: 0, avgLatency: 0 };
  #auditLog = [];
  async registerWebhook(client, callbackUrl) {
    const webhookApi = client.Webhooks;
    const webhookConfig = {
      name: 'External Transcript Archiver',
      description: 'Triggers archival on transcript storage',
      enabled: true,
      type: 'web',
      event: 'conversation:transcript:stored',
      address: callbackUrl,
      version: '2',
      properties: {
    return await webhookApi.postWebhooks(webhookConfig);
  async processWebhookPayload(webhookEvent, client, externalEndpoint, apiKey) {
    this.#metrics.total++;
    const auditEntry = {
      conversationId: webhookEvent.conversationId,
      status: 'pending',
      errors: []
      // Fetch transcript using analytics API
      const transcripts = await fetchWebMessagingTranscripts(
        client,
        webhookEvent.eventDate,
        new Date(Date.now() + 60000).toISOString()
      const entity = transcripts.find(t => t.id === webhookEvent.conversationId);
      if (!entity) {
        throw new Error('Transcript not found in analytics response.');
      const payload = buildArchivePayload(entity);
      const result = await archiveToExternalStore(payload, externalEndpoint, apiKey);
      auditEntry.status = 'archived';
      auditEntry.latencyMs = result.latencyMs;
      this.#metrics.success++;
      this.#metrics.avgLatency = (this.#metrics.avgLatency + result.latencyMs) / 2;
    } catch (error) {
      auditEntry.status = 'failed';
      auditEntry.errors.push(error.message);
      this.#metrics.failed++;
    this.#auditLog.push(auditEntry);
    return auditEntry;
  getMetrics() {
    return { ...this.#metrics };
  getAuditLog() {
    return [...this.#auditLog];
The TranscriptArchiver class registers the webhook, processes incoming events, tracks latency and success rates, and maintains an audit log. The conversation:transcript:stored event ensures synchronization with Genesys Cloud storage completion.
import { GenesysAuthManager } from './auth.js';
import { TranscriptArchiver } from './archiver.js';
import { fetchWebMessagingTranscripts, buildArchivePayload, validateArchivePayload, normalizeTranscriptText, extractMetadata } from './pipeline.js';
import { archiveToExternalStore } from './store.js';
async function main() {
  const baseUrl = 'https://api.mypurecloud.com';
  const clientId = process.env.GENESYS_CLIENT_ID;
  const clientSecret = process.env.GENESYS_CLIENT_SECRET;
  const externalEndpoint = process.env.EXTERNAL_ARCHIVE_ENDPOINT;
  const externalApiKey = process.env.EXTERNAL_API_KEY;
  const auth = new GenesysAuthManager(baseUrl, clientId, clientSecret);
  await auth.refreshIfExpired();
  const client = auth.getClient();
  const archiver = new TranscriptArchiver();
  // Register webhook for future transcripts
    await archiver.registerWebhook(client, 'https://your-server.com/webhooks/transcript-stored');
    console.log('Webhook registered successfully.');
  } catch (error) {
    console.error('Webhook registration failed:', error.message);
  // Process historical transcript
  const dateFrom = new Date(Date.now() - 24 * 60 * 60 * 1000).toISOString();
  const dateTo = new Date().toISOString();
    const transcripts = await fetchWebMessagingTranscripts(client, dateFrom, dateTo);
    for (const entity of transcripts.slice(0, 5)) { // Limit to 5 for demo
      await validateArchivePayload(payload, client, 10 * 1024 * 1024);
        ...msg,
      const result = await archiveToExternalStore(payload, externalEndpoint, externalApiKey);
      console.log(`Archived ${entity.id} successfully. Latency: ${result.latencyMs.toFixed(2)}ms`);
  } catch (error) {
    console.error('Archival pipeline failed:', error.message);
  console.log('Metrics:', archiver.getMetrics());
  console.log('Audit Log:', JSON.stringify(archiver.getAuditLog(), null, 2));
main().catch(console.error);
This script initializes authentication, registers the webhook, fetches recent transcripts, validates and normalizes them, compresses and archives them, and outputs metrics and audit logs. Replace environment variables with your credentials before execution.
  • Cause: OAuth token expired or missing required scopes.
  • Fix: Ensure the client credentials include analytics:query, webchat:read, retention:read, and webhook:write. Call auth.refreshIfExpired() before API calls.
  • Code Fix:
if (response.status === 401) {
  // Retry request with new token
  • Cause: Genesys Cloud rate limit exceeded or external store throttling.
  • Fix: Implement exponential backoff and respect Retry-After headers. The provided archiveToExternalStore function handles this automatically.
  • Debugging: Monitor Retry-After header values. Adjust batch size (size: 100) in the analytics query if cascading 429s occur.
Error: Schema Validation Failed
  • Cause: Transcript structure mismatch or missing required fields.
  • Fix: Verify the analytics query returns transcript arrays with timestamp, direction, type, and text fields. Add fallback logic for legacy transcript formats.
  • Code Fix:
const fallbackText = msg.text || msg.content || msg.body || '';
Error: Encoding Mismatch Detected
  • Cause: Invalid UTF-8 sequences from legacy systems or corrupted message payloads.
  • Fix: Use TextDecoder with { fatal: true } to catch invalid sequences. Replace invalid bytes with replacement characters (�) or skip the message.
  • Code Fix:
} catch {
  msg.text = msg.text.replace(/[^\x20-\x7E]/g, ''); // Strip non-ASCII
