Archiving Genesys Cloud Routing Strategies with Go: Automated Cleanup, Validation, and Webhook Synchronization
  • A Go module that identifies inactive routing strategies, constructs archive payloads with retention directives, validates dependencies, and executes atomic PATCH operations against the Genesys Cloud CX API.
  • The implementation uses the Genesys Cloud CX Routing Strategy API and standard HTTP clients with custom retry, audit, and webhook synchronization logic.
  • The tutorial covers Go 1.21+ with net/http, encoding/json, and slices for production-grade strategy lifecycle management.
  • OAuth 2.0 client credentials grant with scopes: routing:strategy:view, routing:strategy:edit
  • Genesys Cloud CX API v2
  • Go 1.21 or later
  • Dependencies: github.com/google/uuid, github.com/cenkalti/backoff/v4 (for exponential backoff retry logic)
Genesys Cloud CX requires OAuth 2.0 client credentials for server-to-server API access. The following function implements token acquisition, caching, and automatic refresh logic.
package main
import (
	"context"
	"crypto/sha256"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"net/url"
	"strings"
	"sync"
	"time"
type OAuthConfig struct {
	ClientID     string
	ClientSecret string
	Environment  string // e.g., "mypurecloud.com"
type TokenResponse struct {
	ExpiresIn   int    `json:"expires_in"`
	TokenType   string `json:"token_type"`
type TokenCache struct {
	mu      sync.RWMutex
	token   string
	expires time.Time
func (c *TokenCache) IsExpired() bool {
	c.mu.RLock()
	defer c.mu.RUnlock()
	return time.Now().After(c.expires)
func (c *TokenCache) Set(token string, expiresAt time.Time) {
	c.mu.Lock()
	defer c.mu.Unlock()
	c.token = token
	c.expires = expiresAt
func (c *TokenCache) Get() string {
	c.mu.RLock()
	return c.token
func NewAuthClient(cfg OAuthConfig) *http.Client {
	cache := &TokenCache{}
	return &http.Client{
		Timeout: 30 * time.Second,
		Transport: &authRoundTripper{
			base:    http.DefaultTransport,
			cfg:     cfg,
			cache:   cache,
			headers: make(http.Header),
type authRoundTripper struct {
	base    http.RoundTripper
	cfg     OAuthConfig
	cache   *TokenCache
	headers http.Header
func (t *authRoundTripper) RoundTrip(req *http.Request) (*http.Response, error) {
	if t.cache.IsExpired() {
		token, err := t.fetchToken()
		if err != nil {
			return nil, fmt.Errorf("oauth token refresh failed: %w", err)
		t.cache.Set(token, time.Now().Add(50*time.Minute))
	req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", t.cache.Get()))
	return t.base.RoundTrip(req)
func (t *authRoundTripper) fetchToken() (string, error) {
	form := url.Values{}
	form.Set("grant_type", "client_credentials")
	form.Set("client_id", t.cfg.ClientID)
	form.Set("client_secret", t.cfg.ClientSecret)
	form.Set("scope", "routing:strategy:view routing:strategy:edit")
	resp, err := http.PostForm(fmt.Sprintf("https://api.%s/api/v2/oauth/token", t.cfg.Environment), form)
	if err != nil {
		return "", err
	defer resp.Body.Close()
		return "", fmt.Errorf("oauth error %d: %s", resp.StatusCode, string(body))
	var tokenResp TokenResponse
		return "", err
	return tokenResp.AccessToken, nil
OAuth Scopes Required: routing:strategy:view, routing:strategy:edit
Endpoint: POST https://api.{environment}/api/v2/oauth/token
Step 1: Fetch and Filter Inactive Strategies with Pagination
The Routing Strategy API supports pagination via pageSize and pageNumber query parameters. This step retrieves all strategies and filters for inactive candidates based on last usage timestamps.
type Strategy struct {
	ID        string    `json:"id"`
	Name      string    `json:"name"`
	Enabled   bool      `json:"enabled"`
	Version   int       `json:"version"`
	LastUsed  time.Time `json:"lastUsed"`
	CreatedAt time.Time `json:"createdAt"`
type StrategyPage struct {
	Entities []Strategy `json:"entities"`
	Page     int        `json:"page"`
	PageSize int        `json:"pageSize"`
	Total    int        `json:"total"`
func FetchStrategies(client *http.Client, environment string) ([]Strategy, error) {
	var allStrategies []Strategy
	page := 1
	pageSize := 250
	for {
		reqURL := fmt.Sprintf("https://api.%s/api/v2/routing/strategies?pageNumber=%d&pageSize=%d", environment, page, pageSize)
		req, err := http.NewRequestWithContext(context.Background(), http.MethodGet, reqURL, nil)
		if err != nil {
			return nil, err
		resp, err := client.Do(req)
		if err != nil {
			return nil, err
			return nil, fmt.Errorf("rate limited on strategy fetch")
			return nil, fmt.Errorf("strategy fetch failed %d: %s", resp.StatusCode, string(body))
		var pageResp StrategyPage
		if err := json.NewDecoder(resp.Body).Decode(&pageResp); err != nil {
			return nil, err
		allStrategies = append(allStrategies, pageResp.Entities...)
		if page >= int(pageResp.Total/pageSize)+1 {
			break
		page++
	// Filter inactive strategies based on last usage matrix
	var inactive []Strategy
	cutoff := time.Now().Add(-90 * 24 * time.Hour)
	for _, s := range allStrategies {
		if !s.Enabled || s.LastUsed.Before(cutoff) {
			inactive = append(inactive, s)
	return inactive, nil
Endpoint: GET https://api.{environment}/api/v2/routing/strategies
Step 2: Validate Dependencies and Construct Archive Payloads
Before archiving, you must verify that the strategy is not actively referenced by queues or routing rules. The payload construction includes strategy ID references, last usage timestamp matrices, and retention policy directives. Schema validation ensures compliance with routing engine constraints and maximum archive storage limits.
type ArchivePayload struct {
	StrategyID      string    `json:"strategyId"`
	LastUsageMatrix []UsageRecord `json:"lastUsageMatrix"`
	RetentionPolicy RetentionPolicy `json:"retentionPolicy"`
	ArchiveReason   string    `json:"archiveReason"`
	Timestamp       time.Time `json:"timestamp"`
type UsageRecord struct {
	CallCount int       `json:"callCount"`
type RetentionPolicy struct {
	MaxAgeDays int `json:"maxAgeDays"`
	StorageLimitMB int `json:"storageLimitMB"`
func ValidateStrategyDependencies(client *http.Client, environment, strategyID string) error {
	// Check queue associations
	reqURL := fmt.Sprintf("https://api.%s/api/v2/routing/queues", environment)
	req, _ := http.NewRequestWithContext(context.Background(), http.MethodGet, reqURL, nil)
	if err != nil {
		return err
		return fmt.Errorf("dependency check failed: %d", resp.StatusCode)
	var queues struct {
		Entities []struct {
		} `json:"entities"`
	json.NewDecoder(resp.Body).Decode(&queues)
	for _, q := range queues.Entities {
		if q.StrategyID == strategyID {
			return fmt.Errorf("strategy %s is actively referenced by queue %s", strategyID, q.Name)
	return nil
func BuildArchivePayload(strategy Strategy, retention RetentionPolicy) (ArchivePayload, error) {
	// Validate schema against routing engine constraints
	if retention.MaxAgeDays <= 0 || retention.MaxAgeDays > 365 {
		return ArchivePayload{}, fmt.Errorf("retention maxAgeDays must be between 1 and 365")
	if retention.StorageLimitMB <= 0 || retention.StorageLimitMB > 512 {
		return ArchivePayload{}, fmt.Errorf("storage limit exceeds maximum archive storage constraints")
	payload := ArchivePayload{
		StrategyID: strategy.ID,
		LastUsageMatrix: []UsageRecord{
			{Timestamp: strategy.LastUsed, CallCount: 0},
		RetentionPolicy: retention,
		ArchiveReason:   "inactive_cleanup",
		Timestamp:       time.Now().UTC(),
	return payload, nil
Endpoint: GET https://api.{environment}/api/v2/routing/queues
Step 3: Execute Atomic PATCH Operations with Retry and Format Verification
This step performs the atomic archive operation. It uses JSON merge patch semantics, verifies response format, handles automatic index removal triggers, and implements exponential backoff for 429 rate limits.
type AuditLog struct {
	Action      string    `json:"action"`
	Status      string    `json:"status"`
	LatencyMs   int64     `json:"latencyMs"`
	StorageReclaimed bool `json:"storageReclaimed"`
func PatchArchiveStrategy(client *http.Client, environment string, payload ArchivePayload, version int) error {
	patchBody := map[string]interface{}{
		"enabled": false,
		"metadata": map[string]interface{}{
			"archivePayload": payload,
		"version": version,
	jsonData, err := json.Marshal(patchBody)
	if err != nil {
		return err
	reqURL := fmt.Sprintf("https://api.%s/api/v2/routing/strategy/%s", environment, payload.StrategyID)
	// Retry logic for 429
	maxRetries := 5
	for attempt := 0; attempt < maxRetries; attempt++ {
		req, err := http.NewRequestWithContext(context.Background(), http.MethodPatch, reqURL, strings.NewReader(string(jsonData)))
		if err != nil {
			return err
		start := time.Now()
		if err != nil {
			return err
			retryAfter := 2 << attempt
			time.Sleep(time.Duration(retryAfter) * time.Second)
		if resp.StatusCode == http.StatusConflict {
			return fmt.Errorf("version conflict on strategy %s, current version: %d", payload.StrategyID, version)
			return fmt.Errorf("patch failed %d: %s", resp.StatusCode, string(body))
		// Format verification
		var result Strategy
		if err := json.NewDecoder(resp.Body).Decode(&result); err != nil {
			return fmt.Errorf("response format verification failed: invalid JSON structure")
		if result.Enabled {
			return fmt.Errorf("archive operation did not disable strategy")
		// Automatic index removal trigger simulation
		fmt.Printf("Index removal triggered for strategy %s\n", payload.StrategyID)
		return nil
	return fmt.Errorf("max retries exceeded for strategy %s", payload.StrategyID)
OAuth Scopes Required: routing:strategy:edit
Endpoint: PATCH https://api.{environment}/api/v2/routing/strategy/{id}
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
This step orchestrates the full pipeline, fires archive completion webhooks to external storage monitors, tracks latency, calculates storage reclamation success rates, and writes governance audit logs.
type ArchiverConfig struct {
	Client            *http.Client
	Environment       string
	WebhookURL        string
	AuditLogPath      string
type StrategyArchiver struct {
	cfg ArchiverConfig
	latencies []int64
	successes int
	failures  int
func NewStrategyArchiver(cfg ArchiverConfig) *StrategyArchiver {
	return &StrategyArchiver{cfg: cfg}
func (a *StrategyArchiver) ProcessStrategy(strategy Strategy) AuditLog {
	logEntry := AuditLog{
		Action:     "archive",
	if err := ValidateStrategyDependencies(a.cfg.Client, a.cfg.Environment, strategy.ID); err != nil {
		logEntry.Status = "skipped_dependency_conflict"
		a.failures++
		return logEntry
	payload, err := BuildArchivePayload(strategy, a.cfg.RetentionPolicy)
	if err != nil {
		logEntry.Status = "payload_validation_failed"
		a.failures++
		return logEntry
	start := time.Now()
	err = PatchArchiveStrategy(a.cfg.Client, a.cfg.Environment, payload, strategy.Version)
	latency := time.Since(start).Milliseconds()
	a.latencies = append(a.latencies, latency)
	if err != nil {
		logEntry.Status = fmt.Sprintf("failed_%s", strings.ReplaceAll(err.Error(), " ", "_"))
		a.failures++
	} else {
		logEntry.Status = "success"
		logEntry.StorageReclaimed = true
		a.successes++
	logEntry.LatencyMs = latency
	// Write audit log
	a.writeAuditLog(logEntry)
	// Synchronize with external storage monitor via webhook
	if logEntry.Status == "success" {
		a.fireWebhook(payload)
	return logEntry
func (a *StrategyArchiver) writeAuditLog(entry AuditLog) {
	data, _ := json.MarshalIndent(entry, "", "  ")
	// In production, append to file or send to syslog/S3
	fmt.Printf("AUDIT_LOG: %s\n", string(data))
func (a *StrategyArchiver) fireWebhook(payload ArchivePayload) {
	webhookPayload := map[string]interface{}{
		"event":      "strategy.archived",
		"strategyId": payload.StrategyID,
		"timestamp":  payload.Timestamp.Format(time.RFC3339),
		"retention":  payload.RetentionPolicy,
	jsonData, _ := json.Marshal(webhookPayload)
	req, _ := http.NewRequestWithContext(context.Background(), http.MethodPost, a.cfg.WebhookURL, strings.NewReader(string(jsonData)))
	req.Header.Set("X-Archive-Signature", fmt.Sprintf("%x", sha256.Sum256(jsonData)))
	resp, err := http.DefaultClient.Do(req)
	if err != nil || resp.StatusCode >= 400 {
		fmt.Printf("Webhook sync failed for %s: %v\n", payload.StrategyID, err)
func (a *StrategyArchiver) GetEfficiencyMetrics() map[string]interface{} {
	total := a.successes + a.failures
	var avgLatency float64
	if len(a.latencies) > 0 {
		sum := int64(0)
		for _, l := range a.latencies {
			sum += l
		avgLatency = float64(sum) / float64(len(a.latencies))
	return map[string]interface{}{
		"totalProcessed":   total,
		"successRate":      float64(a.successes) / float64(total),
		"avgLatencyMs":     avgLatency,
		"storageReclaimed": a.successes,
The following script combines all components into a runnable automated routing strategy management tool. Replace placeholder credentials with your OAuth client details.
package main
import (
	"fmt"
	"os"
	"time"
func main() {
	cfg := OAuthConfig{
		ClientID:     os.Getenv("GENESYS_CLIENT_ID"),
		ClientSecret: os.Getenv("GENESYS_CLIENT_SECRET"),
		Environment:  os.Getenv("GENESYS_ENVIRONMENT"), // e.g., mypurecloud.com
	if cfg.ClientID == "" || cfg.ClientSecret == "" || cfg.Environment == "" {
		fmt.Println("Required environment variables: GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_ENVIRONMENT")
		os.Exit(1)
	client := NewAuthClient(cfg)
	archiver := NewStrategyArchiver(ArchiverConfig{
		Client:      client,
		Environment: cfg.Environment,
		WebhookURL:  os.Getenv("ARCHIVE_WEBHOOK_URL"),
		RetentionPolicy: RetentionPolicy{
			MaxAgeDays:     90,
			StorageLimitMB: 256,
		AuditLogPath: "audit.log",
	strategies, err := FetchStrategies(client, cfg.Environment)
	if err != nil {
		fmt.Printf("Failed to fetch strategies: %v\n", err)
		os.Exit(1)
	fmt.Printf("Found %d inactive strategies for archiving\n", len(strategies))
	for _, strategy := range strategies {
		entry := archiver.ProcessStrategy(strategy)
		fmt.Printf("Processed %s: %s\n", entry.StrategyID, entry.Status)
		// Prevent cascading rate limits
		time.Sleep(200 * time.Millisecond)
	metrics := archiver.GetEfficiencyMetrics()
	fmt.Printf("Archiving Complete. Metrics: %+v\n", metrics)
  • Cause: OAuth token expired or client credentials are invalid.
  • Fix: Verify environment variables. The authRoundTripper automatically refreshes tokens, but initial validation failures will halt execution. Check the client ID and secret against the Genesys Cloud admin console.
  • Code Fix: Ensure the fetchToken function handles 401 responses gracefully and logs the raw error body for credential debugging.
Error: 403 Forbidden
  • Cause: Missing routing:strategy:edit scope or the OAuth client lacks application permissions for routing configuration.
  • Fix: Navigate to Admin > Security > OAuth 2.0 and verify the client has routing:strategy:edit granted. Revoke and reauthorize if necessary.
  • Code Fix: The token request explicitly requests both routing:strategy:view and routing:strategy:edit. Confirm the scope string matches exactly.
Error: 409 Conflict
  • Cause: Version mismatch during the PATCH operation. Another process modified the strategy between fetch and archive.
  • Fix: Implement optimistic locking by re-fetching the strategy, updating the local version field, and retrying the PATCH.
  • Code Fix: The PatchArchiveStrategy function returns a specific conflict error. Wrap the call in a retry loop that increments the version number before retrying.
  • Cause: Exceeding Genesys Cloud CX rate limits (typically 100 requests per second per client).
  • Fix: The implementation includes exponential backoff in PatchArchiveStrategy. For bulk operations, increase the sleep interval between iterations in the main loop.
  • Code Fix: The maxRetries loop sleeps 2 << attempt seconds. Adjust time.Sleep(200 * time.Millisecond) in main to 1 * time.Second for safer bulk execution.
