Archiving Genesys Cloud Flow Versions via Architecture API with C#
A production-grade C# module that safely archives Genesys Cloud flow versions by constructing archive payloads with freeze directives, validating dependency matrices against deployment constraints, enforcing version history limits, and triggering automatic rollback snapshots. The module synchronizes archiving events with external Git repositories via webhooks, tracks latency and freeze success rates, and generates structured audit logs for deployment governance. This tutorial uses the Genesys Cloud Architecture API and the official C# SDK.
- OAuth Client Type: Confidential Client (Client Credentials Grant)
- Required Scopes:
flow:read,flow:write,architect:flow:read,architect:flow:write,architect:webhook:write - SDK Version:
GenesysCloudPlatformClientv6.0+ - Runtime: .NET 8.0 LTS
- External Dependencies:
GenesysCloudPlatformClient,System.Text.Json,Serilog,Polly(for retry logic)
Genesys Cloud requires OAuth 2.0 Client Credentials authentication. The SDK handles token acquisition, but production systems must cache tokens and handle expiration. The following code initializes the platform client with token caching and automatic refresh.
using GenesysCloudPlatformClient;
using GenesysCloudPlatformClient.Auth;
using System;
using System.Collections.Concurrent;
using System.Net.Http;
using System.Threading.Tasks;
public class GenesysAuthManager
private static readonly ConcurrentDictionary<string, string> _tokenCache = new();
private readonly string _clientId;
private readonly string _clientSecret;
private readonly string _baseUrl;
public GenesysAuthManager(string clientId, string clientSecret, string baseUrl)
_clientId = clientId;
_clientSecret = clientSecret;
_baseUrl = baseUrl;
public async Task<PlatformClient> InitializePlatformClientAsync()
var auth = new OAuthClientCredentials(_clientId, _clientSecret);
var client = new PlatformClient(auth, _baseUrl);
client.SetDefaultHeader("Accept", "application/json");
client.SetDefaultHeader("Content-Type", "application/json");
// SDK automatically handles token acquisition and refresh
await client.AuthenticateAsync();
return client;
Step 1: Dependency Matrix and Version Limit Validation
Before archiving, you must verify that the flow does not exceed the maximum version history limit (10 versions per flow in Genesys Cloud) and that dependent resources remain reachable. The Architecture API exposes a validation endpoint that checks configuration drift and endpoint reachability.
using GenesysCloudPlatformClient.Api;
using GenesysCloudPlatformClient.Models;
using System.Collections.Generic;
using System.Linq;
public class FlowValidationEngine
private readonly ArchitectureApi _architectureApi;
private readonly int _maxVersionLimit = 10;
public FlowValidationEngine(ArchitectureApi architectureApi)
_architectureApi = architectureApi;
public async Task<ValidationResult> ValidateFlowForArchiveAsync(string flowId, int targetVersion)
var result = new ValidationResult { IsValid = true, Errors = new List<string>() };
// Fetch current flow metadata
var flow = await _architectureApi.GetArchitectFlowAsync(flowId);
// Check version history limit
var versionCount = flow.Versions?.Count ?? 0;
if (versionCount >= _maxVersionLimit)
result.IsValid = false;
result.Errors.Add($"Flow exceeds maximum version limit ({_maxVersionLimit}). Archive rejected.");
// Verify target version exists
var targetVersionExists = flow.Versions?.Any(v => v.Version == targetVersion) ?? false;
if (!targetVersionExists)
result.Errors.Add($"Version {targetVersion} does not exist on flow {flowId}.");
// Run Architecture API validation for endpoint reachability and configuration drift
try
var validateAction = new ValidateFlowAction { FlowVersion = targetVersion };
var validationResponse = await _architectureApi.PostArchitectFlowActionsValidateAsync(flowId, validateAction);
if (validationResponse.ValidationErrors?.Count > 0)
result.Errors.AddRange(validationResponse.ValidationErrors.Select(e => e.Message));
catch (ApiException ex) when (ex.Status == 400)
result.Errors.Add($"Validation failed: {ex.Message}");
return result;
public class ValidationResult
public bool IsValid { get; set; }
public List<string> Errors { get; set; } = new();
Step 2: Archive Payload Construction and Atomic Execution
Genesys Cloud does not support direct DELETE operations for flow versions. The platform uses an atomic archive action that transitions the version out of active routing. You must construct an ArchiveFlowAction payload with a freeze directive to prevent further modifications. The following code implements exponential backoff for 429 rate limits and format verification.
using Polly;
using System;
using System.Diagnostics;
public class FlowArchiveExecutor
private readonly ILogger _logger;
public FlowArchiveExecutor(ArchitectureApi architectureApi, ILogger logger)
_logger = logger;
public async Task<ArchiveExecutionResult> ExecuteArchiveAsync(string flowId, int version, string reason)
var stopwatch = Stopwatch.StartNew();
var result = new ArchiveExecutionResult { Success = false, LatencyMs = 0 };
// Construct archive payload with freeze directive
var archivePayload = new ArchiveFlowAction
FlowVersion = version,
Freeze = true,
Reason = reason,
FlowId = flowId
// Retry policy for 429 Too Many Requests
var retryPolicy = Policy.HandleResult<ApiResponse<ArchiveFlowAction>>(r => r.StatusCode == 429)
.WaitAndRetryAsync(3, retryAttempt => TimeSpan.FromSeconds(Math.Pow(2, retryAttempt)),
(exception, timeSpan, retryCount, context) =>
_logger.LogWarning($"Rate limit hit. Retrying in {timeSpan.TotalSeconds}s. Attempt {retryCount}.");
try
var response = await retryPolicy.ExecuteAsync(async () =>
await _architectureApi.PostArchitectFlowActionsArchiveAsync(flowId, archivePayload));
if (response.StatusCode == 200 || response.StatusCode == 201)
result.Success = true;
result.ArchivedVersion = response.Body?.FlowVersion;
result.FreezeApplied = response.Body?.Freeze ?? false;
else
result.ErrorMessage = $"Archive failed with status {response.StatusCode}: {response.Body?.Message}";
catch (ApiException ex) when (ex.Status == 409)
result.ErrorMessage = "Conflict: Flow version is already archived or locked by another process.";
catch (ApiException ex) when (ex.Status == 403)
result.ErrorMessage = "Forbidden: Missing architect:flow:write scope or insufficient permissions.";
catch (Exception ex)
result.ErrorMessage = $"Unexpected error: {ex.Message}";
finally
stopwatch.Stop();
result.LatencyMs = stopwatch.ElapsedMilliseconds;
return result;
public class ArchiveExecutionResult
public bool Success { get; set; }
public int ArchivedVersion { get; set; }
public bool FreezeApplied { get; set; }
public long LatencyMs { get; set; }
public string ErrorMessage { get; set; }
HTTP Request/Response Cycle Reference
The SDK call above translates to the following raw HTTP cycle:
POST /api/v2/architect/flows/{flowId}/actions/archive HTTP/1.1
Host: mycompany.mygenesiscLOUD.com
Accept: application/json
"flowVersion": 7,
"freeze": true,
"reason": "Production scaling event - archiving legacy routing logic",
"flowId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
Realistic Response:
"flowVersion": 7,
"freeze": true,
"flowId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"archivedTimestamp": "2024-05-15T14:32:10.000Z"
Step 3: Rollback Snapshot, Webhook Sync, and Audit Logging
Before the archive action commits, you must trigger a rollback snapshot. After execution, the module registers a webhook for Git synchronization and writes a structured audit log. This pipeline ensures deployment governance and external alignment.
using System;
using System.IO;
using System.Text.Json;
public class FlowArchiveOrchestrator
private readonly FlowValidationEngine _validator;
private readonly FlowArchiveExecutor _executor;
private readonly string _snapshotDirectory;
private readonly string _auditLogPath;
public FlowArchiveOrchestrator(ArchitectureApi api, ILogger logger, string snapshotDir, string auditLog)
_architectureApi = api;
_validator = new FlowValidationEngine(api);
_executor = new FlowArchiveExecutor(api, logger);
_logger = logger;
_snapshotDirectory = snapshotDir;
_auditLogPath = auditLog;
public async Task<OrchestrationResult> ArchiveFlowVersionAsync(string flowId, int version, string reason)
var result = new OrchestrationResult { Success = false };
// Step 1: Validation
var validation = await _validator.ValidateFlowForArchiveAsync(flowId, version);
if (!validation.IsValid)
result.ErrorMessage = string.Join("; ", validation.Errors);
return result;
// Step 2: Pre-archive rollback snapshot trigger
var snapshotPath = Path.Combine(_snapshotDirectory, $"flow_{flowId}_v{version}_prearchive.json");
try
var flowData = await _architectureApi.GetArchitectFlowAsync(flowId);
var json = JsonSerializer.Serialize(flowData, new JsonSerializerOptions { WriteIndented = true });
await File.WriteAllTextAsync(snapshotPath, json);
_logger.LogInformation("Rollback snapshot saved to {Path}", snapshotPath);
result.ErrorMessage = $"Snapshot generation failed: {ex.Message}";
return result;
// Step 3: Execute Archive
var archiveResult = await _executor.ExecuteArchiveAsync(flowId, version, reason);
result.Success = archiveResult.Success;
result.LatencyMs = archiveResult.LatencyMs;
result.FreezeSuccess = archiveResult.FreezeApplied;
result.ErrorMessage = archiveResult.ErrorMessage;
if (!result.Success)
return result;
// Step 4: Webhook Sync for Git Alignment
await RegisterArchiveWebhookAsync(flowId);
// Step 5: Audit Log Generation
await WriteAuditLogAsync(flowId, version, result);
return result;
private async Task RegisterArchiveWebhookAsync(string flowId)
var webhook = new Webhook
Name = $"FlowArchiveSync_{flowId}",
Enabled = true,
EventType = "flow.archived",
Url = "https://gitlab.example.com/api/v4/projects/123/hooks",
Headers = new Dictionary<string, string> { { "PRIVATE-TOKEN", "glpat-xxx" } },
FlowId = flowId
try
await _architectureApi.PostArchitectWebhookAsync(webhook);
_logger.LogInformation("Webhook registered for flow {FlowId}", flowId);
_logger.LogWarning("Webhook already exists for flow {FlowId}", flowId);
private async Task WriteAuditLogAsync(string flowId, int version, OrchestrationResult result)
var auditEntry = new
Timestamp = DateTime.UtcNow.ToString("o"),
FlowId = flowId,
Version = version,
Action = "ARCHIVE",
Success = result.Success,
LatencyMs = result.LatencyMs,
FreezeApplied = result.FreezeSuccess,
ErrorMessage = result.ErrorMessage
var json = JsonSerializer.Serialize(auditEntry);
await File.AppendAllTextAsync(_auditLogPath, json + Environment.NewLine);
public class OrchestrationResult
public bool FreezeSuccess { get; set; }
The following module combines authentication, validation, execution, and governance into a single runnable script. Replace credential placeholders before execution.
using System;
class Program
static async Task Main(string[] args)
const string clientId = "your_client_id";
const string clientSecret = "your_client_secret";
const string baseUrl = "https://api.mypurecloud.com";
const string flowId = "a1b2c3d4-e5f6-7890-abcd-ef1234567890";
const int versionToArchive = 5;
const string archiveReason = "Automated scaling cleanup";
var authManager = new GenesysAuthManager(clientId, clientSecret, baseUrl);
var platformClient = await authManager.InitializePlatformClientAsync();
var architectureApi = new ArchitectureApi(platformClient);
var logger = new ConsoleLogger();
var orchestrator = new FlowArchiveOrchestrator(
architectureApi,
logger,
"./snapshots",
"./archive_audit.log"
var result = await orchestrator.ArchiveFlowVersionAsync(flowId, versionToArchive, archiveReason);
Console.WriteLine($"Archive Operation Complete: Success={result.Success}, Latency={result.LatencyMs}ms, Freeze={result.FreezeSuccess}");
Console.WriteLine($"Error: {result.ErrorMessage}");
public class ConsoleLogger : ILogger
public void LogInformation(string message, params object[] args) => Console.WriteLine($"[INFO] {string.Format(message, args)}");
public void LogWarning(string message, params object[] args) => Console.WriteLine($"[WARN] {string.Format(message, args)}");
public void LogError(string message, params object[] args) => Console.WriteLine($"[ERROR] {string.Format(message, args)}");
public interface ILogger
void LogInformation(string message, params object[] args);
void LogWarning(string message, params object[] args);
void LogError(string message, params object[] args);
Error: 403 Forbidden
- Cause: The OAuth token lacks
architect:flow:writescope, or the client credentials are restricted to read-only operations. - Fix: Regenerate the OAuth token with the required scopes. Verify the client credentials configuration in the Genesys Cloud admin console.
- Code Fix: Ensure
PlatformClientis initialized with a token that includesarchitect:flow:write. The SDK throwsApiExceptionwith status 403, which the executor catches and reports.
Error: 409 Conflict
- Cause: The target version is already archived, locked by a concurrent deployment, or the flow is currently active in a running session.
- Fix: Query the flow versions to confirm state. Wait for active sessions to drain. Implement a lock check before calling the archive endpoint.
- Code Fix: The
FlowArchiveExecutorcatches 409 and returns a specific conflict message. Add a pre-check usingGetArchitectFlowAsyncto verifyflow.Statusis notactive.
- Cause: The Architecture API enforces rate limits per organization. Bulk archiving triggers throttling.
- Fix: Implement exponential backoff. The provided code uses Polly to retry 429 responses with increasing delays.
- Code Fix: The retry policy is already configured in
ExecuteArchiveAsync. Increase the retry count or base delay if operating at scale.
Error: Validation Drift / Endpoint Unreachable
- Cause: The
PostArchitectFlowActionsValidateendpoint detects broken web URLs, invalid queue references, or mismatched skill groups. - Fix: Review the
ValidationErrorsarray returned by the validation call. Update dependent resources before archiving. - Code Fix: The
FlowValidationEngineaggregates validation errors and blocks the archive pipeline. Log the specificValidationErrorsto identify the broken reference.
