Architecting Web Messaging Session Resumption for Long-Lived Customer Journeys
This masterclass details the implementation of Persistent Web Messaging Sessions. By the end of this guide, you will be able to configure your Web Messaging deployment to allow customers to resume conversations across different browser sessions, tabs, and devices without losing their interaction history. You will learn how to handle token persistence, configure session expiration timers, and ensure a seamless “Asynchronous” experience that aligns with modern messaging expectations (like WhatsApp or iMessage).
Session resumption requires coordination between the Genesys Cloud deployment and your website’s cookie/storage policy.
  • Licensing: Genesys Cloud CX 1, 2, or 3.
  • Permissions:
    • Messaging > Deployment > View/Edit
    • Architect > Flow > View/Edit
  • OAuth Scopes: messaging.
  • Infrastructure: A provisioned Web Messaging Deployment with the Messenger snippet installed.
1. Understanding the “Session” vs. “Conversation” Lifecycle
In Web Messaging, a Conversation is the multi-day interaction history, while a Session is the active WebSocket connection.
Architectural Reasoning:
By default, when a customer closes their browser tab, the WebSocket disconnects, but the Conversation remains in an “Asynchronous” state in Genesys Cloud. To allow the customer to “Resume” that conversation later, the browser must retain the Deployment Token.
2. Configuring Persistent Tokens in the Deployment
You must enable session persistence in the Genesys Cloud Admin UI.
Configuration Step:
  1. Navigate to Admin > Message > Messenger Deployments.
  2. Under the Messenger Configuration, look for Session Persistence.
  3. Enable Authenticated or Unauthenticated persistence depending on your security model.
  4. Set the Session Expiration (e.g., 7 days). This defines how long the conversation “waits” for the customer to return before it is considered closed.
3. Implementing Cross-Tab and Cross-Subdomain Resumption
If a customer starts a chat on support.example.com and navigates to account.example.com, the chat should follow them.
Implementation Pattern:
In your Messenger snippet, configure the cookieDomain to the root domain.
Genesys("command", "Messenger.configure", {
  deploymentId: "YOUR_DEPLOYMENT_ID",
  cookieDomain: "example.com" // Essential for cross-subdomain persistence
4. Handling “Authenticated” Resumption (Cross-Device)
To allow a customer to start a chat on their mobile phone and resume it on their desktop, you must use Authenticated Web Messaging.
The Implementation Pattern:
  1. JWT Generation: When the user logs into your site, your backend generates a Signed JWT containing the user’s sub (Subject ID).
  2. Token Injection: Pass this JWT to the Messenger SDK using the AuthProvider.reAuthenticate command.
  3. Identity Stitching: Genesys Cloud sees the same sub ID and automatically links the new session to the existing conversation history, regardless of the device.
Edge Case 1: The “Shared Computer” Privacy Risk
  • The failure condition: A customer uses a public library computer, starts a chat, and leaves. The next user opens the site and can see the previous user’s chat history.
  • The root cause: Long-lived persistent tokens stored in localStorage.
  • The solution: Implement an explicit Clear Session button or trigger the Messenger.clearSession command when the user logs out of your website. This wipes the deployment token and ensures the next user starts with a clean slate.
Edge Case 2: Expired Token “Ghosting”
  • The failure condition: A customer returns after 10 days (beyond the 7-day expiration). The chat widget shows the “Start New Conversation” screen, but the customer expects their old history.
  • The root cause: The deploymentId is valid, but the specific conversationId has been purged from the active cache.
  • The solution: Use the Conversation API to fetch historical transcripts if you need to display them outside the active chat widget. Within the widget, once a session expires, it is natively designed to start fresh to maintain performance and data privacy.
