Architecting Text-to-Speech IVR Prompt Generation for Dynamic Multi-Language Announcements
This guide details the architectural pattern for generating real-time, multi-language TTS prompts within Genesys Cloud Architect flows without relying on static audio repositories. You will configure API-driven prompt generation, implement deterministic caching to eliminate call-side latency, and structure language routing to support dynamic content injection at scale.
  • Licensing Tier: CX 2 or CX 3 license per flow designer and integrator. CX 1 does not support advanced API request blocks or prompt management automation.
  • Granular Permissions:
    • Telephony > Prompt > Edit
    • Integration > API > Edit
    • Architect > Flow > Edit
    • Architect > Flow > Deploy
  • OAuth Scopes: prompt:read, prompt:write, integration:read, api:read
  • External Dependencies:
    • Configured TTS provider in Genesys Cloud (Amazon Polly or Google Wavenet via Admin > Voice > TTS Providers)
    • Service account with machine-to-machine OAuth credentials
    • Language voice profiles mapped to target ISO 639-1 codes (e.g., en-US, es-ES, fr-FR, ja-JP)
    • External CRM or data source providing dynamic content variables
1. Provisioning the TTS Service Provider and Language Voice Profiles
Before routing a single call into the flow, you must establish the TTS provider configuration and map voice profiles to language codes. Genesys Cloud abstracts the underlying provider API, but the voice selection and language mapping directly impact synthesis latency and audio quality.
Navigate to Admin > Voice > TTS Providers. Select your configured provider and verify the available voice list. Do not rely on the default voice. Default voices often use standard neural models that lack the prosody controls required for transactional content. Instead, select a Neural or High-Definition tier voice for each target language. Record the exact voiceName string returned by the platform (e.g., Joanna, Conchita, Takumi). These strings are case-sensitive and immutable across API calls.
Create a mapping table in your deployment documentation or configuration management database. Each entry must contain:
  • languageCode: ISO 639-1 with region (e.g., es-MX)
  • voiceName: Exact provider identifier
  • sampleRate: 24000 or 48000 Hz (match your media server configuration)
  • maxCharacters: Provider-specific limit (typically 3000 characters per request)
The Trap: Mapping a single voice profile to multiple regional dialects. If you assign es-ES voice to both es-ES and es-MX traffic, the synthesis engine applies European Spanish phonetics to Mexican Spanish input. This produces audible accent mismatches that trigger immediate caller hangups or DTMF rejection. Regional dialects require distinct voice profiles. Never share a voice identifier across locale boundaries.
Architectural Reasoning: Voice profiling at the provider level decouples content generation from media playback. By standardizing the voice-to-language mapping upfront, you eliminate runtime voice negotiation. The Architect flow only needs to pass the language code and text payload. The TTS service handles phoneme mapping, prosody adjustment, and audio encoding. This separation reduces flow complexity and prevents voice negotiation timeouts during peak traffic.
2. Constructing the Dynamic Prompt Generation Flow in Architect
The core generation logic resides in a dedicated sub-flow. This sub-flow accepts three input variables: dynamicText, targetLanguage, and cacheKey. It returns a promptId or falls back to a static error prompt.
Begin by adding a Make API Request block. Configure the following parameters:
  • HTTP Method: POST
  • Endpoint: /api/v2/prompts/tts
  • Content Type: application/json
  • Authentication: OAuth 2.0 (Service Account)
  • Request Body:
  "name": "DYN_TTS_{{cacheKey}}",
  "text": "{{dynamicText}}",
  "languageCode": "{{targetLanguage}}",
  "voiceName": "{{voiceMapping[targetLanguage]}}"
Configure the Response Handling section to extract the id field from the JSON response. Map this to a flow variable named generatedPromptId. Set a timeout of 4500 milliseconds. TTS synthesis for complex sentences rarely exceeds 2 seconds, but network jitter and provider queueing require a buffer.
Route the success path to a Play Prompt block. Pass generatedPromptId as the prompt identifier. Enable Stop On DTMF if this announcement precedes input collection. Route the failure path to a Set Variable block that assigns a fallback prompt ID, then route to the same Play Prompt block.
The Trap: Embedding raw CRM data directly into the text field without sanitization. If the source system returns unescaped characters, quotes, or malformed SSML tags, the TTS engine throws a 400 Bad Request response. The flow fails, and the caller hears silence or a platform error tone. Always strip control characters and escape quotes before passing text to the API. Never trust external data payloads.
Architectural Reasoning: Isolating TTS generation in a sub-flow enforces a single point of failure handling. If the provider returns a 5xx error, the flow captures it at the API block level. You can implement retry logic, fallback routing, or call transfer without disrupting the main IVR topology. This pattern also enables parallel execution when combined with Execute Flow blocks that return prompt IDs before media playback begins. Pre-fetching prompts during initial DTMF collection eliminates mid-conversation synthesis delays.
3. Implementing Prompt Caching and Concurrency Throttling
Real-time TTS generation introduces variable latency. Under concurrent load, provider rate limits trigger 429 responses, causing cascading flow failures. You must implement a caching layer that stores generated prompt IDs and validates them before API calls.
Modify the sub-flow to include a Get Prompt block before the API request. Construct the cache key using a deterministic hash of the input text and language code. Use the {{cacheKey}} variable to query existing prompts:
  • Search Field: name
  • Operator: equals
  • Value: DYN_TTS_{{cacheKey}}
Route the Prompt Found path directly to the Play Prompt block. Route the Prompt Not Found path to the Make API Request block. This check eliminates redundant synthesis calls for identical content.
Implement concurrency throttling using an Execute Flow block with a Queue configuration. Set the Maximum Concurrent Instances to match your provider tier limit (typically 50 to 100 requests per second). Configure the queue to Block when full. Add a Timeout of 8000 milliseconds. Route the timeout failure to a Set Variable block that assigns a pre-recorded static prompt, then continue playback.
The Trap: Using call-specific identifiers in the cache key. If you append a callId or timestamp to the prompt name, the cache miss rate approaches 100 percent. Every identical announcement triggers a new synthesis request. This exhausts provider quotas, inflates costs, and increases latency. Cache keys must be content-deterministic. Hash the text and language code. Never include ephemeral identifiers.
Architectural Reasoning: Prompt caching shifts the workload from real-time synthesis to asynchronous retrieval. The first caller for a specific text payload triggers generation. Subsequent callers retrieve the cached prompt ID instantly. This pattern reduces provider API calls by 70 to 90 percent in high-volume environments. Concurrency throttling prevents queue saturation during traffic spikes. The blocking queue ensures orderly processing while the timeout fallback guarantees call continuity. This architecture balances cost, latency, and reliability without requiring external caching infrastructure.
Edge Case 1: TTS Provider Rate Limit Exhaustion Under Burst Traffic
  • The Failure Condition: Calls enter the IVR during a campaign launch or system failover. The Make API Request block returns 429 Too Many Requests repeatedly. Callers experience 5 to 8 seconds of silence before hearing a fallback prompt or disconnection.
  • The Root Cause: The concurrency throttle is misconfigured or absent. Burst traffic exceeds the provider tier limit. Genesys Cloud does not automatically backpressure external API calls. The flow continues submitting requests until the provider rejects them.
  • The Solution: Enforce strict queue limits in the Execute Flow block. Set Maximum Concurrent Instances to 80 percent of your provider limit. Implement exponential backoff by adding a Delay block (1500 milliseconds) before retrying the API call. Monitor API Request Failure Rate in the Architect dashboard. If failures exceed 2 percent, scale to a higher provider tier or increase prompt pre-generation coverage.
Edge Case 2: SSML Injection and Character Encoding Failures
  • The Failure Condition: The TTS engine returns 400 Bad Request with a payload indicating Invalid SSML or Unsupported Characters. The flow routes to the error path. Callers hear a platform-generated error tone or silence.
  • The Root Cause: External data sources inject raw HTML entities, unescaped quotes, or malformed SSML tags. The TTS provider rejects payloads that violate XML well-formedness rules. Genesys Cloud does not sanitize text before forwarding to the provider.
  • The Solution: Implement a Set Variable block using an Architect expression to sanitize input before API submission. Use the replace() function to strip <, >, &, and unescaped quotes. Convert HTML entities to plain text. If SSML is required for prosody control, inject it at the flow level using a template pattern. Never concatenate raw CRM fields directly into the TTS payload. Validate character encoding as UTF-8 before transmission.
Edge Case 3: Cache Key Collisions and Stale Content Delivery
  • The Failure Condition: Callers hear outdated announcements after a system update or content change. The cache returns an old prompt ID. The content mismatch causes confusion or compliance violations.
  • The Root Cause: The cache key lacks a version identifier. When content updates, the hash remains identical. The flow retrieves the old prompt ID. Genesys Cloud Prompt Management does not automatically invalidate cached prompts when text changes.
  • The Solution: Append a content version string to the cache key. Structure the key as DYN_TTS_{{hash(text)}}_v{{contentVersion}}. Update the version variable in the flow when content changes. Implement a cache purge routine using the DELETE /api/v2/prompts/{promptId} endpoint during deployment windows. Schedule prompt regeneration during off-peak hours to avoid live traffic disruption. Monitor cache hit rates to validate version propagation.
