Architecting Selective Recording Policies Based on Queue, Division, and Regulatory Jurisdiction
This guide details the architectural strategy for implementing granular, compliant call recording policies within Genesys Cloud CX. You will configure recording rules that dynamically activate based on Queue membership, Division hierarchy, and external regulatory jurisdiction signals passed via CTI data. The end result is a system that records high-risk interactions for PCI-DSS or HIPAA compliance while suppressing recording on internal or exempt queues, ensuring strict adherence to local “all-party consent” laws without manual agent intervention.
  • Licensing Tier: Genesys Cloud CX 1 (Standard) or higher. Recording functionality is core, but advanced retention and archiving features may require CX 2/3 or specific archiving add-ons.
  • Permissions:
    • Telephony > Recording > Edit (to modify recording rules)
    • Telephony > Queue > Edit (to assign queues to divisions)
    • Administration > Division > Edit (to structure divisional hierarchy)
    • Telephony > CTI > Edit (if using CTI data for jurisdiction routing)
  • External Dependencies:
    • A compliant storage backend (S3, Azure Blob, or Genesys Cloud Archive).
    • Defined regulatory zones mapped to specific Queue or Division attributes.
1. Establishing the Divisional Hierarchy for Data Segmentation
Before configuring recording rules, you must structure your Division hierarchy to support data isolation. Recording files are stored within the context of the Division where the interaction originated. If you attempt to apply recording policies across mixed divisions without proper hierarchy, you risk data leakage or permission errors during playback.
We utilize a Division-per-Regulatory-Zone strategy. Instead of relying solely on Queue attributes for storage location, we align Divisions with legal jurisdictions (e.g., Div_EU_GDPR, Div_US_California, Div_Internal_Support).
The Trap: Configuring recording rules at the global level without Division scoping.
If you create a global recording rule that applies to “All Queues,” Genesys Cloud will attempt to record every interaction. However, if an agent in Div_EU_GDPR handles a call from a queue in Div_US_California, the recording file is stored in the Division of the Queue. If your IAM policies restrict cross-division access, compliance officers in the EU division will not have read access to recordings of calls handled by US agents, even if those calls involved EU customers. This creates a critical compliance gap.
Architectural Reasoning: By aligning Divisions with regulatory boundaries, we ensure that the storage location of the recording file inherently matches the data sovereignty requirements. IAM policies then become straightforward: “Users in Div_EU_GDPR can only read recordings in Div_EU_GDPR.”
Configuration Steps:
  1. Navigate to Admin > Divisions.
  2. Create parent divisions for regions (e.g., Global_Recording_Root).
  3. Create child divisions for specific jurisdictions (e.g., Global_Recording_Root > EU_GDPR_Compliant).
  4. Assign Agents and Queues to these specific child divisions.
2. Configuring Queue-Level Recording Overrides
Queues are the primary unit of operational control. We use Queue settings to enforce recording requirements for specific business functions (e.g., Sales, Collections, Technical Support).
The Trap: Relying exclusively on Queue settings for “Do Not Record” exemptions.
A common misconfiguration is setting Recording Policy to Off on a Queue to suppress recording for internal transfers. However, if a Recording Rule exists at the Organization level that forces recording on, the Queue setting may not override it depending on the rule priority and scope. Genesys Cloud recording logic follows a hierarchy: Recording Rules > Queue Settings > Organization Defaults. If you have a global rule that says “Record All,” a Queue setting of “Off” will be ignored unless the Rule explicitly excludes that Queue.
Architectural Reasoning: We use Queue settings as the baseline expectation for operational teams, but we rely on Recording Rules for compliance enforcement. This separation allows business operations to toggle recording for coaching purposes (Queue level) while ensuring legal mandates (Rule level) cannot be accidentally disabled by a queue manager.
  1. Navigate to Admin > Telephony > Queues.
  2. Select a Queue (e.g., High_Risk_Collections).
  3. Scroll to the Recording section.
  4. Set Recording Policy to Record All Calls.
  5. For exempt queues (e.g., Internal_IT_Support), set Recording Policy to Do Not Record.
    • Critical Note: If you have global Recording Rules active, you must verify that these rules do not have a higher priority scope that overrides this setting. We will address this in Step 3.
3. Implementing Dynamic Recording Rules with CTI Data
This is the core of the selective architecture. We use Recording Rules to apply logic that transcends static Queue settings. This allows us to record based on dynamic factors, such as the customer’s location (passed via CTI) or specific call outcomes.
We will create a rule that records calls only if:
  1. The Queue is in a “Recordable” Division.
  2. The CTI data indicates a jurisdiction requiring recording (e.g., Jurisdiction: California).
  3. The call duration exceeds 10 seconds (to avoid recording abandoned calls).
The Trap: Using “Match All” conditions with overly broad scopes.
If you create a rule with Scope: All and Condition: True, you will record every interaction, including internal supervisor calls, test calls, and IVR navigation. This inflates storage costs by 300-500% and creates massive compliance liabilities in regions with strict “all-party consent” laws where the IVR prompt failed to play.
Architectural Reasoning: We use Negative Filtering. Instead of listing every Queue that should be recorded, we list every Queue and Division that should not be recorded, and apply the rule to the remainder. This is more maintainable as new recordable queues are added.
  1. Navigate to Admin > Telephony > Recording Rules.
  2. Click Add Rule.
  3. Name: Selective_Compliance_Recording.
  4. Priority: 1 (Highest).
  5. Scope: All (or specific Divisions if you want to isolate the rule).
  6. Conditions:
    • Add Condition: Queue → Is Not → Internal_IT_Support, QA_Testing_Queues.
    • Add Condition: Division → Is → EU_GDPR_Compliant, US_California_Compliant.
    • Add Condition: CTI Data → Jurisdiction → Equals → CA, EU.
      • Note: Ensure your CTI integration passes the Jurisdiction key-value pair.
    • Add Condition: Call Duration → Greater Than → 10 seconds.
  7. Action: Record.
  8. Save.
Code/JSON Representation of the Rule Logic:
While configured via UI, the underlying API payload for this rule looks like this:
POST /api/v2/telephony/recording/rules
Authorization: Bearer <token>
  "name": "Selective_Compliance_Recording",
  "priority": 1,
  "scope": "all",
  "conditions": [
      "field": "queue",
      "operator": "not_in",
      "values": ["Internal_IT_Support", "QA_Testing_Queues"]
      "field": "division",
      "operator": "in",
      "values": ["EU_GDPR_Compliant", "US_California_Compliant"]
      "field": "cti_data",
      "operator": "equals",
      "values": ["Jurisdiction:CA", "Jurisdiction:EU"]
      "field": "call_duration",
      "operator": "greater_than",
      "values": [10]
  "action": "record"
4. Handling “All-Party Consent” with IVR Prompts
Recording rules alone do not satisfy legal consent requirements. You must ensure the IVR plays the appropriate disclaimer before the call is connected to an agent. This requires coordination between Architect and Recording Rules.
The Trap: Disconnecting IVR logic from Recording Rules.
If your IVR plays a recording disclaimer for “California” but the Recording Rule does not trigger for that specific Queue/Division combination, you are playing a disclaimer for a recording that is not happening. Conversely, if the Recording Rule triggers but the IVR skipped the prompt (e.g., due to a fast transfer), you are recording without consent. Both scenarios are legally actionable.
Architectural Reasoning: We use Architect Data Variables to pass the “Consent Status” from the IVR to the Queue. The Recording Rule then checks this variable. If the variable is not set to CONSENTED, the recording rule explicitly excludes the call. This creates a closed-loop compliance system.
Implementation:
  1. In Architect, add a Set Data block after the IVR prompt.
    • Key: Consent_Status
    • Value: CONSENTED
  2. In the Recording Rule, add a condition:
    • CTI Data → Consent_Status → Equals → CONSENTED.
    • Note: Ensure the CTI data is being passed correctly from Architect to the Telephony layer. This often requires configuring the CTI Settings in the Queue to include custom data fields.
Edge Case 1: The “Silent” Transfer Recording Gap
The Failure Condition: An agent transfers a call to another agent in a different Division. The recording stops unexpectedly, or a new recording starts without the consent prompt.
The Root Cause: When a call is transferred, Genesys Cloud treats it as a new interaction leg. If the second agent is in a Division that is excluded from the Recording Rule, the recording stops. If the second agent is in a Division that is included, a new recording starts, but the IVR prompt is not played again because the call is already connected.
The Solution: Use Blind Transfer vs. Supervised Transfer strategically.
  • For Blind Transfers: Ensure the destination Queue is in a Division that is excluded from recording if the original consent is no longer valid.
  • For Supervised Transfers: Configure the IVR to play the consent prompt again if the transfer is to a different regulatory jurisdiction. Use Architect to detect the destination Division and insert a prompt block before completing the transfer.
Edge Case 2: CTI Data Latency and Race Conditions
The Failure Condition: The Recording Rule triggers based on CTI Data: Jurisdiction=CA, but the CTI data has not yet been populated by the CRM middleware when the recording rule evaluates the call. The recording fails to start, or starts too late.
The Root Cause: Genesys Cloud evaluates Recording Rules at the start of the interaction. If the CTI data is pushed asynchronously from a CRM (e.g., Salesforce) via API, there is a race condition. The rule evaluates before the data arrives.
The Solution:
  1. Pre-populate CTI Data: Push CTI data before the call is connected to the queue. Use the Transfer to Queue block in Architect to include the CTI data in the transfer payload.
  2. Fallback Logic: If CTI data is missing, default to the most restrictive policy (i.e., Do Not Record). Configure the Recording Rule to require the presence of the CTI key. If the key is absent, the condition CTI Data: Jurisdiction=CA will not match, and the recording will not start. This ensures compliance by defaulting to safety.
Edge Case 3: Retention Policy Conflicts Across Divisions
The Failure Condition: Recordings in EU_GDPR_Compliant are deleted after 30 days, but US_California_Compliant requires 7 years. A global retention policy sets all recordings to 30 days.
The Root Cause: Retention policies are applied at the Organization or Division level. A global policy overrides Division-specific settings if not scoped correctly.
The Solution:
  1. Navigate to Admin > Telephony > Recording > Retention Policies.
  2. Create separate Retention Policies for each Division.
    • Policy_EU_30Days: Applies to EU_GDPR_Compliant.
    • Policy_US_7Years: Applies to US_California_Compliant.
  3. Assign these policies to the respective Divisions.
  4. Verify: Use the Recording Search API to confirm that recordings in each Division have the correct expiry_date metadata.
GET /api/v2/recordings/search
  "query": "division.id:EU_GDPR_Compliant",
  "size": 10
Check the expiryDate field in the response to ensure it aligns with the Division’s retention policy.
