Architecting SDK Pagination Helpers for Transparently Iterating Over Large Result Sets
This guide details the construction of a production-grade pagination helper that abstracts platform-specific cursor and offset mechanics, enforces memory-safe streaming, and handles rate limiting without blocking the calling thread. You will implement an async iterator pattern that transparently fetches, normalizes, and yields records from Genesys Cloud CX and NICE CXone APIs until exhaustion.
  • Genesys Cloud CX: CX 2 or CX 3 license tier, Platform API access enabled, OAuth scope api:platform:read, and entity-specific scopes (e.g., interaction:read, user:read).
  • NICE CXone: CXone Platform license, API credentials configured in the Admin portal, Read permission on target data domains, and awareness of tenant-level API quotas.
  • External Dependencies: HTTP client with promise-based response handling, async/await runtime environment, and a rate limit tracking mechanism.
  • Architectural Context: Familiarity with REST pagination models, backpressure concepts in streaming data, and exponential backoff algorithms.
1. Normalizing Platform-Specific Pagination Contracts
Genesys Cloud and NICE CXone expose fundamentally different pagination mechanics. Genesys Cloud primarily uses page-based pagination (pageSize and pageNumber) with a hard maximum of 1000 records per page, while newer endpoints transition to cursor-based navigation using continuationToken. NICE CXone relies on offset-based pagination (limit and offset) for legacy endpoints, with a maximum limit of 2000, while modern endpoints use cursor and nextCursor fields. A transparent helper must abstract these differences behind a single normalized interface.
We construct a pagination strategy resolver that inspects the endpoint metadata or response headers to determine the active pagination model. The resolver returns a configuration object containing the maximum page size, the parameter keys to inject into subsequent requests, and the extraction function to locate the next pointer.
type PaginationModel = 'page' | 'offset' | 'cursor';
interface PaginationConfig {
  model: PaginationModel;
  maxPageSize: number;
  paramKeys: { size: string; pointer: string; nextPointer: string };
  extractNextPointer: (response: any) => string | null;
function resolvePaginationConfig(platform: 'genesys' | 'cxone', endpoint: string): PaginationConfig {
  if (platform === 'genesys') {
    const isCursorEndpoint = endpoint.includes('/api/v2/interactions') || endpoint.includes('/api/v2/analytics');
    return isCursorEndpoint
      ? { model: 'cursor', maxPageSize: 1000, paramKeys: { size: 'pageSize', pointer: 'continuationToken', nextPointer: 'continuationToken' }, extractNextPointer: (res: any) => res.continuationToken || null }
      : { model: 'page', maxPageSize: 1000, paramKeys: { size: 'pageSize', pointer: 'pageNumber', nextPointer: 'pageNumber' }, extractNextPointer: (res: any) => res.pageNumber ? String(res.pageNumber + 1) : null };
  if (platform === 'cxone') {
    const isCursorEndpoint = endpoint.includes('/api/v2/interactions') || endpoint.includes('/api/v2/agents');
      ? { model: 'cursor', maxPageSize: 2000, paramKeys: { size: 'limit', pointer: 'cursor', nextPointer: 'nextCursor' }, extractNextPointer: (res: any) => res.nextCursor || null }
      : { model: 'offset', maxPageSize: 2000, paramKeys: { size: 'limit', pointer: 'offset', nextPointer: 'offset' }, extractNextPointer: (res: any) => res.records ? String(res.records.length + Number(res.offset || 0)) : null };
  throw new Error('Unsupported platform');
The Trap: Hardcoding pagination parameters at the SDK layer without validating endpoint support causes silent data loss. Genesys Cloud endpoints that do not support pageSize will ignore it and return a default of 25 records. CXone endpoints that reject offset will throw a 400 Bad Request. If your helper assumes a static model, it will either underfetch data or crash mid-extraction. Always validate the maxPageSize against the official endpoint documentation and implement a fallback to the platform default when the parameter is unsupported.
Architectural Reasoning: We normalize at the resolver layer rather than the request layer to maintain separation of concerns. The pagination helper only cares about the normalized contract. This design allows the same iteration logic to operate across platforms without conditional branching inside the core loop. It also enables runtime switching if a platform migrates from offset to cursor pagination without requiring SDK version upgrades.
2. Implementing Memory-Safe Async Iteration with Backpressure
Loading millions of interaction records or agent performance metrics into memory will trigger out-of-memory exceptions in Node.js or garbage collection pauses in Java. A transparent pagination helper must stream records to the consumer instead of buffering them. We use async generators to provide a pull-based iteration model that respects consumer backpressure.
The async generator yields individual records or small batches. It maintains state between yields, tracking the current pointer and detecting exhaustion. When the consumer pauses iteration (e.g., to write to a database), the generator suspends execution without blocking the event loop. This pattern prevents memory bloat while preserving execution context.
async function* paginateRecords<T>(
  baseUrl: string,
  config: PaginationConfig,
  fetcher: (url: string, params: Record<string, string>) => Promise<any>,
  batchSize: number = 100
): AsyncGenerator<T, void, unknown> {
  let pointer = config.model === 'page' ? '1' : '0';
  let exhausted = false;
  while (!exhausted) {
    const params: Record<string, string> = { [config.paramKeys.size]: String(config.maxPageSize) };
    if (config.model !== 'cursor') {
      params[config.paramKeys.pointer] = pointer;
    } else {
    const response = await fetcher(baseUrl, params);
    const records = response.entities || response.records || response.data || [];
    if (records.length === 0) {
      exhausted = true;
      break;
    for (const record of records) {
      yield record as T;
    const nextPointer = config.extractNextPointer(response);
    if (!nextPointer || nextPointer === pointer) {
      exhausted = true;
    } else {
      pointer = nextPointer;
The Trap: Using Promise.all or concurrent fetchers to accelerate pagination violates platform rate limits and breaks cursor consistency. Genesys Cloud cursors are strictly sequential. Fetching page 3 before page 2 completes invalidates the cursor state in the platform’s session store, causing the next request to return stale or duplicate records. CXone offset pagination suffers from the same issue when concurrent requests modify the underlying dataset during extraction. Always enforce strict sequential fetching.
Architectural Reasoning: Async generators provide native backpressure handling. The JavaScript engine pauses the generator function at each yield until the consumer requests the next value via next(). This eliminates the need for manual queue management or thread pools. The helper maintains only the current pointer and the active response payload in memory. When combined with a streaming consumer (e.g., fs.createWriteStream or a database bulk insert queue), memory consumption remains constant regardless of total dataset size.
3. Embedding Rate Limit Handling and Exponential Backoff
Contact center APIs enforce strict rate limits to protect backend search clusters and database shards. Genesys Cloud returns a 429 status with a Retry-After header. NICE CXone returns a 429 status with a X-RateLimit-Reset header or a Retry-After fallback. A transparent helper must intercept these responses, calculate the delay, and retry without exposing the retry logic to the consumer.
We implement a retry wrapper that parses platform-specific rate limit headers, applies exponential backoff with jitter, and caps retries to prevent infinite loops. The jitter prevents thundering herd scenarios when multiple SDK instances resume simultaneously.
async function fetchWithRetry(
  baseUrl: string,
  params: Record<string, string>,
  maxRetries: number = 5
): Promise<any> {
  let attempt = 0;
  while (attempt <= maxRetries) {
      if (response.status === 429) {
        const retryAfter = response.headers['retry-after'] || response.headers['x-ratelimit-reset'];
        const delayMs = retryAfter ? parseInt(retryAfter, 10) * 1000 : Math.pow(2, attempt) * 1000 + Math.random() * 1000;
        await new Promise(resolve => setTimeout(resolve, delayMs));
        attempt++;
        continue;
      if (response.status >= 400 && response.status < 500) {
        throw new Error(`Client error ${response.status}: ${response.statusText}`);
      return response.data || response;
    } catch (error: any) {
      if (error.code === 'ECONNRESET' || error.status === 503) {
        const delayMs = Math.pow(2, attempt) * 1000 + Math.random() * 1500;
        attempt++;
      } else {
        throw error;
  throw new Error(`Max retries exceeded after ${maxRetries} attempts`);
The Trap: Ignoring the Retry-After header and relying solely on exponential backoff causes unnecessary delays. Genesys Cloud explicitly calculates the exact time until the rate limit window resets. If you apply a hardcoded backoff curve, you will either retry too early (triggering repeated 429s) or wait far longer than necessary, degrading extraction throughput. Always prioritize platform-provided headers over algorithmic estimates.
Architectural Reasoning: We isolate rate limit handling in a dedicated fetch wrapper rather than embedding it in the generator loop. This keeps the pagination logic clean and testable. The wrapper handles both 429 rate limits and 503 service unavailable errors using the same backoff mechanism, since both indicate temporary backend saturation. The jitter component is mathematically necessary to distribute retry requests across time, preventing synchronized client bursts that exacerbate backend load.
4. Building the Transparent Helper Interface
The final helper composes the resolver, generator, and retry wrapper into a single, consumable interface. It accepts a platform identifier, endpoint, authentication handler, and optional query parameters. It returns an async iterator that yields normalized records. The helper abstracts all pagination mechanics, rate limit negotiation, and memory management.
interface PaginationHelperOptions {
  platform: 'genesys' | 'cxone';
  endpoint: string;
  authHeader: () => Promise<string>;
  queryParams?: Record<string, string>;
  maxRetries?: number;
async function createPaginationHelper<T>(options: PaginationHelperOptions) {
  const { platform, endpoint, authHeader, queryParams = {}, maxRetries = 5 } = options;
  const config = resolvePaginationConfig(platform, endpoint);
  const authenticatedFetcher = async (url: string, params: Record<string, string>) => {
    const token = await authHeader();
    const response = await fetchWithRetry(
      async (baseUrl: string, p: Record<string, string>) => {
        const urlParams = new URLSearchParams({ ...queryParams, ...p });
        const fullUrl = `${baseUrl}?${urlParams.toString()}`;
        const res = await fetch(fullUrl, {
          headers: { Authorization: `Bearer ${token}`, Accept: 'application/json' }
        return { status: res.status, headers: Object.fromEntries(res.headers), data: await res.json() };
      url,
      params,
      maxRetries
    return response;
  return paginateRecords<T>(endpoint, config, authenticatedFetcher);
The Trap: Baking authentication token refresh logic directly into the pagination loop creates tight coupling and makes the helper unusable across different auth providers. OAuth tokens expire during long-running extractions. If the helper assumes a static token, it will fail with 401 Unauthorized after 3600 seconds. Always inject an async auth provider function that handles token caching, expiration detection, and refresh logic externally.
Architectural Reasoning: The factory pattern returns an async generator rather than executing it immediately. This defers execution until the consumer explicitly iterates, preventing unnecessary network requests during initialization. The authHeader injection point ensures the helper remains agnostic to authentication mechanisms, supporting OAuth 2.0, API keys, or SAML bearer tokens. The queryParams merge allows consumers to pass platform-specific filters (e.g., Genesys query parameters for search endpoints or CXone dateFrom/dateTo ranges) without breaking the pagination contract.
Edge Case 1: Cursor Drift During Long-Running Extraction
The failure condition: The extraction returns duplicate records or skips records after several hours of execution.
The root cause: Underlying data modifications during extraction invalidate the cursor state. Genesys Cloud cursors are point-in-time snapshots. If new interactions are created or existing ones are updated while the cursor is active, the platform may advance the cursor past modified records to maintain consistency. CXone offset pagination suffers from index shifting when records are deleted mid-extraction, causing offsets to misalign with the actual dataset position.
The solution: Implement cursor validation by tracking a monotonic sequence identifier. For Genesys Cloud, extract the lastModified timestamp or interaction ID and verify strict ordering. For CXone, use cursor-based pagination exclusively for long-running jobs and disable offset pagination for datasets exceeding 10,000 records. If drift is detected, halt the extraction, log the divergence point, and restart with a fresh cursor. Cross-reference with WFM data extraction patterns, which use similar snapshot validation to prevent schedule conflicts.
Edge Case 2: Silent Truncation at Platform Imposed Maximums
The failure condition: The iterator terminates early, returning fewer records than expected without throwing an error.
The root cause: Platform endpoints enforce undocumented hard limits on total retrievable records per query. Genesys Cloud search endpoints cap results at 10,000 records per query string. CXone analytics endpoints limit result sets to 50,000 rows per extraction. When the helper reaches the limit, the platform returns an empty continuationToken or nextCursor without indicating truncation. The helper interprets this as natural exhaustion and stops iteration.
The solution: Query the total record count before initiating pagination. Genesys Cloud provides total and count fields in response metadata. CXone returns totalRecords in the wrapper object. Compare the extracted count against the reported total. If they diverge, switch to a date-range or ID-range partitioning strategy. Split the extraction into multiple parallel cursors bounded by createdAt timestamps or agent IDs. Aggregate the results post-extraction. This approach bypasses hard limits while maintaining memory safety.
