This guide details the architecture for implementing a resilient disaster recovery (DR) strategy for Genesys Cloud CX and NICE CXone screen recording data using cross-region replication. You will configure automated data replication pipelines, define Recovery Point Objectives (RPO) and Recovery Time Objectives (RTO) for media assets, and implement failover logic that ensures agent activity remains auditable during primary region outages. The end result is a production-grade system where screen recording metadata and binary media files survive regional infrastructure failures without manual intervention.
- Licensing: Genesys Cloud CX 3 or WEM Add-on with Screen Capture enabled; NICE CXone with Interaction Recording and Advanced Analytics.
- Permissions:
- Genesys:
Administration > Settings > Edit,Reporting > Data Export > Edit,Telephony > Trunk > View. - NICE CXone:
Admin > Users > Edit,Admin > Integrations > Edit,Admin > Data Management > Edit.
- Genesys:
- OAuth Scopes:
data:export:read,data:export:write,media:recordings:read,media:recordings:write. - External Dependencies:
- AWS S3 or Azure Blob Storage with Cross-Region Replication (CRR) enabled.
- Genesys Cloud Data Export Service or NICE CXone Data Hub.
- Network connectivity allowing outbound HTTPS (443) from platform regions to storage endpoints.
- IAM roles with
s3:PutObject,s3:GetObject, ands3:Replicatepermissions.
1. Storage Architecture and Cross-Region Replication Setup
Screen recording data consists of two distinct components: metadata (JSON/XML structures containing timestamps, agent IDs, session IDs, and compliance tags) and binary media (H.264/MP4 video streams). Treating these as a monolithic backup target is a critical architectural error. Metadata requires low-latency access for reporting and compliance queries, while binary media requires high-throughput storage for archival.
The Trap: Configuring simple cross-region replication on a single bucket without lifecycle policies leads to exponential cost growth and compliance violations. If you replicate raw video files to a secondary region without tiering, you pay for hot storage on data that is rarely accessed. Furthermore, if the replication rule is applied to the root bucket, small metadata files and large video files compete for IOPS, causing latency spikes during peak call volumes.
The Solution: Implement a dual-bucket strategy with granular replication rules.
- Primary Bucket Structure: Create two buckets in the primary region (e.g.,
us-east-1).gen-screen-meta-primary: Stores JSON metadata.gen-screen-media-primary: Stores MP4 video files.
- Secondary Bucket Structure: Create corresponding buckets in the DR region (e.g.,
eu-west-1).gen-screen-meta-drgen-screen-media-dr
- Configure Cross-Region Replication (CRR):
- Enable versioning on all four buckets. Versioning is mandatory for CRR to function correctly.
- Define replication rules based on object prefixes. For example, replicate objects starting with
metadata/to the meta-dr bucket andvideo/to the media-dr bucket. - Critical Configuration: Set the
StorageClassfor the destination buckets. UseSTANDARD_IA(Infrequent Access) orGLACIERfor the media-dr bucket to reduce costs. UseSTANDARDfor the meta-dr bucket to ensure low-latency access for compliance reports during a failover.
Architectural Reasoning: By separating metadata and media, you optimize for access patterns. Metadata is small and frequently queried; media is large and rarely queried. This separation allows you to apply different lifecycle policies. For instance, you can transition media to Glacier after 30 days in the DR region, while keeping metadata in Standard-IA for 90 days. This reduces DR storage costs by up to 60% while maintaining RPO compliance.
API Configuration Example:
To configure replication via AWS CLI or Terraform, use the following S3 bucket replication configuration:
"Role": "arn:aws:iam::123456789012:role/s3-replication-role",
"Rules": [
"ID": "ScreenMetadataReplication",
"Status": "Enabled",
"Filter": {
"Prefix": "metadata/"
"Destination": {
"Bucket": "arn:aws:s3:::gen-screen-meta-dr",
"StorageClass": "STANDARD_IA",
"ReplicationTime": {
"Time": {
"Minutes": 15
"DeleteMarkerReplication": {
"Status": "Enabled"
"ID": "ScreenMediaReplication",
"Filter": {
"Prefix": "video/"
"Destination": {
"Bucket": "arn:aws:s3:::gen-screen-media-dr",
"StorageClass": "GLACIER",
"Time": {
"Minutes": 60
"Status": "Enabled"
The Trap: Ignoring DeleteMarkerReplication. If an agent or system deletes a recording in the primary region, the deletion marker is not replicated by default. This creates a “phantom data” scenario where the DR region retains deleted recordings, leading to compliance audits failing because the DR site contains data that was legally required to be purged in the primary site. Always enable delete marker replication.
2. Platform Integration and Data Export Configuration
Genesys Cloud and NICE CXone do not natively replicate screen recordings across regions. They store data in the region where the interaction occurred. You must use the Data Export Service (Genesys) or Data Hub (NICE) to push data to your S3 buckets.
Genesys Cloud Configuration:
- Navigate to Admin > Reporting > Data Export.
- Create a new export with the following settings:
- Data Type: Screen Capture Recordings.
- Destination: Amazon S3.
- Bucket:
gen-screen-media-primary. - Prefix:
video/{date:yyyy/MM/dd}/. - Credentials: Use an IAM role with the necessary permissions defined in Prerequisites.
- Create a second export for Screen Capture Metadata (if available as a distinct data type, otherwise extract from Interaction Data).
- Destination:
gen-screen-meta-primary. - Prefix:
metadata/{date:yyyy/MM/dd}/.
- Destination:
The Trap: Relying on default file naming conventions. If you do not enforce a structured prefix (e.g., video/{date}/), the S3 bucket will flatten all files into a single directory. This causes performance degradation in S3 as the number of objects exceeds 10,000, leading to throttling on ListObjects calls. Always use date-partitioned prefixes.
NICE CXone Configuration:
- Navigate to Admin > Data Management > Data Hub.
- Create a new data pipeline for Screen Recordings.
- Map the output to your S3 bucket
gen-screen-media-primary. - Enable Compliance Retention Policies within the pipeline to ensure data is tagged with retention periods before export.
Architectural Reasoning: By pushing data to S3 immediately upon export, you decouple the platform’s internal storage from your DR strategy. The platform acts as a transient buffer, while S3 becomes the system of record. This allows you to perform DR drills without impacting the live platform environment.
3. Failover Logic and Application Layer Integration
Replication at the storage layer is insufficient. Your applications (compliance portals, QA tools, audit systems) must be able to read from the DR bucket when the primary region is unavailable.
The Trap: Hardcoding S3 bucket endpoints in application code. If your QA portal reads directly from gen-screen-media-primary, it will fail when us-east-1 is down. You must implement a dynamic endpoint resolver.
The Solution: Implement a configuration-driven endpoint resolver in your application logic.
Configuration Service: Use a central configuration service (e.g., AWS Parameter Store, Azure App Configuration, or a simple JSON config file) to store the current active region.
Dynamic Endpoint Resolution:
import boto3 import json def get_s3_client(config_key='active_region'): # Fetch current active region from config service region = get_config_value(config_key) # Returns 'us-east-1' or 'eu-west-1' # Determine bucket based on region if region == 'us-east-1': media_bucket = 'gen-screen-media-primary' meta_bucket = 'gen-screen-meta-primary' else: media_bucket = 'gen-screen-media-dr' meta_bucket = 'gen-screen-meta-dr' return boto3.client('s3', region_name=region) def fetch_recording(session_id, region='us-east-1'): s3 = get_s3_client() # Construct key based on metadata lookup meta_key = f"metadata/{session_id}.json" try: meta_obj = s3.get_object(Bucket='gen-screen-meta-primary', Key=meta_key) meta = json.loads(meta_obj['Body'].read()) video_key = meta['video_key'] return s3.get_object(Bucket='gen-screen-media-primary', Key=video_key) except s3.exceptions.ClientError: # Failover logic: try DR region s3_dr = get_s3_client('eu-west-1') return s3_dr.get_object(Bucket='gen-screen-media-dr', Key=video_key) -
Health Checks: Implement a health check endpoint in your application that periodically verifies connectivity to the primary S3 bucket. If the health check fails for N consecutive attempts, automatically switch the configuration key to the DR region.
Architectural Reasoning: This approach ensures zero-downtime access to recordings during a regional outage. The application logic handles the failover transparently, so QA agents and compliance officers do not experience interruptions.
4. Compliance and Data Sovereignty Considerations
Screen recordings often contain PII (Personally Identifiable Information) and PCI (Payment Card Industry) data. Cross-region replication must comply with data sovereignty laws (e.g., GDPR in Europe, HIPAA in the US).
The Trap: Replicating data across borders without encryption or consent. If you replicate US-based agent recordings to a European DR region, you may violate GDPR if the data is not encrypted at rest and in transit, and if the DR region is not bound by a Standard Contractual Clause (SCC) or equivalent agreement.
The Solution:
- Encryption: Enable Server-Side Encryption (SSE-KMS) on all S3 buckets. Use a customer-managed KMS key for the primary bucket and a replicated key for the DR bucket.
- Access Control: Use IAM policies to restrict access to the DR bucket. Only specific roles (e.g.,
ComplianceAuditor,DRAdmin) should have access to the DR bucket. - Data Classification: Tag objects with data classification labels (e.g.,
PII:High,PCI:Present). Use these tags to enforce stricter access controls in the DR region.
To enforce encryption on the S3 bucket:
"Version": "2012-10-17",
"Statement": [
"Sid": "DenyUnencryptedUploads",
"Effect": "Deny",
"Principal": "*",
"Action": "s3:PutObject",
"Resource": "arn:aws:s3:::gen-screen-media-primary/*",
"Condition": {
"StringNotEquals": {
"s3:x-amz-server-side-encryption": "aws:kms"
Architectural Reasoning: By enforcing encryption and access controls, you ensure that even in a disaster scenario, data remains protected and compliant. This is critical for avoiding regulatory fines during a crisis.
Edge Case 1: Replication Lag During Peak Call Volumes
- The Failure Condition: During a high-volume event (e.g., Black Friday), the number of screen recordings generated exceeds the replication throughput of the CRR rules. The DR bucket falls behind, resulting in an RPO of several hours instead of minutes.
- The Root Cause: AWS CRR has a default throughput limit. If the primary bucket receives a burst of large video files, the replication service may throttle.
- The Solution: Enable S3 Replication Time Control (RTC). This ensures that 99.9% of objects are replicated within 15 minutes. For even stricter RPOs, consider using S3 Cross-Region Replication with S3 Transfer Acceleration to speed up the initial upload to the primary bucket, reducing the window for replication lag. Alternatively, implement a secondary replication mechanism using AWS Lambda triggered by
s3:ObjectCreatedevents to manually copy critical metadata files to the DR region.
Edge Case 2: Corrupted Video Files in DR Region
- The Failure Condition: QA agents attempt to play a video from the DR region, but the file is corrupted or incomplete.
- The Root Cause: Network interruptions during the initial upload to the primary bucket can result in partial files being written. If the platform does not validate the file integrity before exporting, the corrupted file is replicated to the DR region.
- The Solution: Implement a validation step in the Data Export pipeline. Use a Lambda function or a serverless job to verify the MD5 checksum of the video file after upload. If the checksum fails, delete the object and trigger a re-export. Additionally, enable S3 Object Lambda to perform on-the-fly validation when objects are accessed from the DR region.
Edge Case 3: Metadata Mismatch Between Regions
- The Failure Condition: The application retrieves metadata from the DR region, but the corresponding video file is missing or has a different key.
- The Root Cause: Race conditions in the export process. If the metadata export completes before the video export, the metadata may point to a video file that has not yet been replicated.
- The Solution: Implement a wait-and-verify mechanism in the application. When fetching metadata, check if the corresponding video file exists in the DR bucket. If not, retry after a short delay. Alternatively, use EventBridge to trigger a notification when both metadata and video files are confirmed to be present in the DR region.
