Architecting SCIM (System for Cross-domain Identity Management) for Automated User Lifecycle Management
This masterclass details the implementation of Automated User Provisioning in Genesys Cloud using the SCIM 2.0 protocol. By the end of this guide, you will be able to architect a system that automatically creates, updates, and deactivates agent accounts in Genesys Cloud based on changes in your corporate identity provider (e.g., Azure AD, Okta, or Ping Identity). You will learn how to implement Attribute Mapping, architect Group-Based Division Assignment, and ensure that your license consumption is optimized through automated “Just-in-Time” deprovisioning.
SCIM provisioning requires coordination between your Identity Team and the Genesys Cloud Admin.
  • Licensing: Genesys Cloud CX 1, 2, or 3.
  • Permissions:
    • Security > SSO > View/Add
    • Security > User > Add/Edit/Delete
  • OAuth Scopes: users, groups, authorization.
  • Infrastructure: An active Identity Provider (IdP) that supports the SCIM 2.0 standard.
1. Activating the SCIM Integration
Genesys Cloud provides a dedicated SCIM endpoint for each organization.
Implementation Step:
  1. Navigate to Admin > Integrations > Add Integration.
  2. Install the Genesys Cloud SCIM (Identity Management) integration.
  3. Generate a Client ID and Client Secret with the User Management role.
  4. The Endpoint: Your SCIM URL will be https://scim.{region}.mypurecloud.com/api/v2/scim/v2/.
2. Implementing Attribute Mapping
Mapping your corporate directory fields to Genesys Cloud attributes ensures that agent profiles are accurate.
Architectural Reasoning:
Do not just map Name and Email. To automate security, you must map directory groups to Genesys Cloud Roles and Divisions.
  • Example Mapping:
    • AD.Department → Genesys.Division
    • AD.JobTitle → Genesys.Roles (e.g., “Level 2 Support” → “Quality Evaluator”)
  • The Benefit: When an agent is promoted in HR, their Genesys Cloud permissions update automatically within minutes, without manual IT tickets.
3. Group-Based Provisioning and De-Provisioning
The most powerful feature of SCIM is the ability to manage access via Security Groups.
Implementation Pattern:
  1. Create a group in your IdP called Genesys_Cloud_Users.
  2. Configure the IdP to only sync users who are members of this group.
  3. De-Provisioning Logic: When a user is removed from the Genesys_Cloud_Users group (or their account is disabled in AD), the IdP sends a DELETE or PATCH (active=false) request to Genesys Cloud.
  4. License Optimization: Genesys Cloud immediately frees up the assigned license (e.g., CX 3), preventing “Ghost Licenses” from being billed for terminated employees.
4. Handling SCIM Rate Limits and Sync Errors
Large organizations with 10,000+ users can hit API rate limits during major reorganizations.
The Strategy:
  1. Monitor the Integration Audit Log for 429 Too Many Requests errors.
  2. Batching: Configure your IdP to send updates in batches of 50-100 users.
  3. Conflict Resolution: If a user already exists in Genesys Cloud with the same email but a different ExternalID, the SCIM sync will fail. You must implement a “Cleanup Script” to reconcile these accounts before enabling the automated sync to prevent duplicate profile creation.
Edge Case 1: The “Soft-Delete” vs. “Hard-Delete”
  • The failure condition: An agent is terminated, but their Genesys Cloud account remains “Active” because the IdP only performed a “Soft Delete.”
  • The root cause: The SCIM integration is configured to “Disable” users instead of “Deleting” them.
  • The solution: In the Genesys Cloud SCIM settings, decide if you want active=false to simply lock the user out or if you want to trigger a full deletion. Most enterprise security policies require active=false to immediately revoke all active sessions.
Edge Case 2: Multi-Org Sync Loops
  • The failure condition: A user is provisioned from AD to Org A and then synchronized to Org B, creating an infinite loop of identity updates.
  • The root cause: Circular trust relationships in a multi-org environment.
  • The solution: Always use a Source of Truth (SoT) tag. Add an attribute like urn:ietf:params:scim:schemas:extension:genesys:2.0:User:sourceOrg to every user profile. The provisioning middleware should ignore any user whose sourceOrg does not match the expected primary directory.
