Architecting Scalable Storage for 10-Year Call Recording Retention
This guide details the architectural pattern for deploying a cost-optimized, compliance-ready storage layer that retains call recordings for a decade. You will configure object storage tiering, platform-native integration pipelines, immutable lifecycle rules, and metadata indexing strategies that prevent cost overruns and ensure audit-ready retrieval. The end result is a fully automated retention architecture that moves media from hot to cold storage without manual intervention while maintaining searchable metadata and strict regulatory compliance.
  • Licensing Tiers: Genesys Cloud CX 1 or higher with Cloud Recording add-on. NICE CXone Recording & Archival license. WEM/Quality Management licenses are not required for raw media retention but are required if you need automated transcription indexing.
  • Platform Permissions: Recording > Recording > Read, Recording > Recording > Edit, Integration > S3 > Edit (Genesys). CXone: Media > Recordings > View, Media > Storage > Configure.
  • OAuth Scopes: recording:read, recording:write, integration:s3:manage (Genesys). CXone REST API requires media.recordings.read and system.storage.write.
  • External Dependencies: AWS S3, Azure Blob Storage, or GCP Cloud Storage account with cross-account IAM role or managed identity. KMS encryption key (AWS KMS or Azure Key Vault). External metadata store (Elasticsearch, OpenSearch, or platform-native search index).
1. Storage Tiering & Object Store Selection
Ten-year retention demands a tiered storage architecture. Native platform storage charges premium rates for long-term media hosting. You must route recordings to an external object store immediately after processing. The architecture relies on three tiers: hot storage for active compliance windows (0 to 90 days), warm storage for mid-term retention (90 days to 3 years), and cold storage for archival (3 to 10 years).
Configure the object store bucket with lifecycle policies that enforce automatic transitions. In AWS S3, this requires a lifecycle configuration rule applied at the bucket level. The rule must specify transition actions based on object age. You will use STANDARD for hot, STANDARD_IA or ONEZONE_IA for warm, and GLACIER or DEEP_ARCHIVE for cold. Azure Blob Storage uses Hot, Cool, and Archive tiers with identical lifecycle transition logic.
The Trap: Configuring lifecycle transitions without accounting for minimum storage duration penalties. S3 and Azure charge early deletion fees if you remove or transition objects before the minimum tier duration expires. For S3 One Zone-IA, the minimum is 30 days. For Glacier Deep Archive, it is 180 days. If your compliance requirement mandates a 90-day active window followed by immediate archival, you will incur massive early deletion fees when the platform attempts to delete hot-tier copies after the retention window closes. The architectural solution is to align the platform retention policy with the cloud provider minimums. Set the platform hot retention to 90 days, then transition to warm storage at day 91, and transition to cold storage at day 1096. This prevents penalty triggers while maintaining compliance.
Create the S3 lifecycle configuration using the PUT Bucket lifecycle API. The payload defines the transition schedule and expiration rules.
PUT /?lifecycle HTTP/1.1
Host: your-bucket-name.s3.amazonaws.com
Authorization: AWS4-HMAC-SHA256 Credential=AKIAIOSFODNN7EXAMPLE/20231025/us-east-1/s3/aws4_request, SignedHeaders=content-type;host, Signature=...
  "Rules": [
      "ID": "RecordingRetentionTiering",
      "Status": "Enabled",
      "Filter": {
        "Prefix": "recordings/"
      "Transitions": [
          "Days": 91,
          "StorageClass": "STANDARD_IA"
          "Days": 1096,
          "StorageClass": "GLACIER"
      "Expiration": {
        "Days": 3650
The architectural reasoning for this approach isolates cost optimization from compliance enforcement. The platform handles media ingestion and initial processing. The object store handles the heavy lifting of long-term retention. By offloading tiering to the cloud provider, you eliminate the need for custom cron jobs or middleware to manage file movement. The cloud provider guarantees durability (99.999999999%) and handles the physical relocation of data blocks across availability zones. You only pay for the storage class and the API calls required to transition objects. This design scales linearly with call volume without requiring infrastructure provisioning.
2. Platform-Native Integration & Metadata Sync
Moving the media file is insufficient. A decade-old recording is useless without associated metadata. You must preserve caller ID, agent ID, queue name, call direction, start/end timestamps, and disposition. Genesys Cloud CX and NICE CXone both support external storage integration, but they differ in how they handle metadata persistence after the media leaves the native environment.
In Genesys Cloud CX, you configure an S3 integration under Admin > Integrations > S3. You must specify the bucket ARN, IAM role ARN, and regional endpoint. The platform uses this integration to push processed recordings to the external bucket. The critical configuration is the Storage Integration setting in Admin > Recordings > Settings. You must enable Store recordings in external storage and set the Retention period to your compliance window. When enabled, the platform writes the media to S3, updates the recording object with the external URI, and deletes the native copy after the retention period expires.
The Trap: Assuming the platform retains metadata indefinitely after deleting the native media copy. Genesys Cloud CX purges the recording record from its primary database after the retention period expires. If you set the retention to 90 days, the recordings API endpoint returns null for any recording older than 90 days. You lose the ability to search, filter, or audit historical calls through the platform UI or REST API. The architectural solution is to implement a metadata export pipeline. You must subscribe to the recording.created and recording.updated events via the Genesys Cloud Events API or use the GET /api/v2/recordings endpoint with pagination to export metadata to an external index like Elasticsearch or a data warehouse. The index must store the S3 URI, call UUID, agent ID, and all compliance fields. This decouples metadata longevity from platform retention limits.
Configure the metadata export using a serverless function triggered by the recording lifecycle. The function queries the recording details and writes to an external store.
GET /api/v2/recordings?view=full&date_from=2023-10-01T00:00:00.000Z&date_to=2023-10-02T00:00:00.000Z&division_id=all HTTP/1.1
Host: api.mypurecloud.com
Accept: application/json
The response payload contains the uri, id, created_date, updated_date, duration_millis, media_type, direction, participants, and transcript fields. You must flatten this JSON structure before indexing. Store the media_type and direction as filterable fields. Store the participants array as a nested object containing user.id, user.name, and role. This structure enables fast compliance queries without scanning the entire dataset.
NICE CXone handles this differently. The platform retains metadata longer than the media by default, but you must enable Archival Storage in Media > Settings. CXone pushes recordings to Azure Blob or AWS S3 via the Storage Integration tab. The platform maintains a reference table for up to 7 years by default. For 10-year requirements, you must export the media_recordings table to an external data lake. The export process uses the CXone Data Export API or scheduled SQL dumps if you utilize the CXone Data Warehouse connector. The architectural reasoning remains identical: platform databases are optimized for active operations, not historical compliance. You must treat the platform as an ingestion and processing engine, not a long-term archive.
3. Lifecycle Automation & Immutability Configuration
Compliance frameworks like HIPAA, PCI-DSS, and SOX require Write Once Read Many (WORM) capabilities. Standard object storage allows accidental deletion or overwriting. You must configure bucket-level immutability to prevent tampering. AWS S3 supports Object Lock with compliance mode. Azure Blob Storage supports Immutable Storage with legal hold or time-based retention policies.
Enable Object Lock on the S3 bucket during creation or via the PUT Bucket object-lock API. You must specify a default retention period that matches your maximum compliance requirement. The retention mode must be COMPLIANCE. This mode prevents any user, including root account owners, from deleting or overwriting the object until the retention period expires.
PUT /?object-lock HTTP/1.1
  "ObjectLockEnabled": "Enabled",
  "Rule": {
    "DefaultRetention": {
      "Mode": "COMPLIANCE",
      "Years": 10
The Trap: Applying Object Lock before testing the platform integration pipeline. Genesys Cloud CX and NICE CXone storage integrations use IAM roles or service principals to write objects. If the IAM role lacks the s3:PutObject permission with the s3:ObjectLockRetainUntilDate header, the platform will fail to upload recordings. The error manifests as a 403 Forbidden response in the platform logs, but the platform does not retry with exponential backoff.
