Architecting Recording Redundancy Strategies with Dual-Write to Primary and Backup Storage
This guide details the engineering of a dual-write recording pipeline that captures contact center media and simultaneously persists it to a primary object storage endpoint and a geographically isolated backup store. The completed architecture guarantees zero data loss during primary storage control-plane failures, satisfies immutable audit requirements for regulated industries, and maintains strict idempotency across both storage tiers without platform rate-limit exhaustion.
- Genesys Cloud CX: CX 2 or CX 3 license tier. Organization-level permissions:
Recordings > Recording Storage Providers > Edit,Integrations > Webhooks > Manage,API > OAuth Client > Create/Manage. - NICE CXone: CXone Platform license with
Recording StorageandAPI Integrationsadd-ons. System Administrator role withSystem > Integrations > APIandRecordings > Storage > Configureprivileges. - OAuth Scopes:
recording:read,recording:write,integration:write,webhook:manage,api:read - External Dependencies: Two independent object storage buckets or containers (e.g., AWS S3 in us-east-1 and Azure Blob in eastus2). IAM service accounts with
PutObject,GetObject,ListBucket, andDeleteObjectpermissions. Outbound network routes permitting TCP 443 from the platform edge to both storage endpoints. An external orchestration service (Node.js, Python, or Go) capable of handling webhook ingestion, parallel media streaming, and idempotency tracking. - Compliance Dependencies: If operating under HIPAA or PCI-DSS, storage endpoints must support server-side encryption (SSE-KMS or SSE-C) and object versioning. Cross-reference the Speech Analytics data pipeline guide to ensure backup stores mirror primary tagging for downstream ML model training.
1. Storage Provider Provisioning & Credential Isolation
Platform-native storage integration relies on a single primary provider per organization. Achieving true redundancy requires decoupling credential management and isolating access policies. You must provision two distinct IAM identities, one for each storage tier. Each identity receives the minimum required permissions scoped to its specific bucket. Cross-account or cross-tenant trust policies are unnecessary and introduce audit complexity.
Configure the primary bucket with standard lifecycle rules aligned to your retention policy. Configure the backup bucket with identical retention rules but disable automatic deletion. The backup store acts as a cold archive until a reconciliation job confirms primary store integrity. Enable object versioning on both endpoints to prevent accidental overwrite during pipeline retries.
The Trap: Sharing a single IAM role or access key across both storage providers. When credentials rotate, expire, or get compromised, both the primary and backup stores become inaccessible simultaneously. This defeats the redundancy objective and triggers platform-level recording failures that cascade into queue timeout errors.
Architectural Reasoning: Isolating credentials ensures that a security incident or credential misconfiguration on one tier does not cascade to the other. It also allows independent rotation schedules without disrupting the active recording pipeline. Platform storage integrations cache credentials for up to 24 hours. Independent rotation prevents cache invalidation storms during maintenance windows.
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": [
"s3:PutObject",
"s3:GetObject",
"s3:ListBucket"
"Resource": [
"arn:aws:s3:::gen-primary-recordings-prod",
"arn:aws:s3:::gen-primary-recordings-prod/*"
"Condition": {
"StringEquals": {
"aws:RequestedRegion": "us-east-1"
2. Webhook Event Routing & Recording Metadata Capture
The platform emits a RECORDING_COMPLETED event when media processing finishes. You must configure a webhook endpoint that captures this event before the platform purges temporary cache files. The webhook payload contains the recording ID, media format, duration, participant list, and a signed URL for media retrieval. The orchestration service consumes this payload, extracts the recording ID, and initiates the dual-write sequence.
Register the webhook through the platform API. Set the event type to RECORDING_COMPLETED. Configure the delivery method as POST with a JSON content type. Enable retry logic with a maximum of three attempts and a backoff interval of 15 seconds. Disable signature validation only during initial testing. Production deployments must enforce HMAC-SHA256 signature verification to prevent webhook spoofing.
The Trap: Configuring the webhook to trigger on RECORDING_STARTED instead of RECORDING_COMPLETED. The started event contains no media URL or final duration. Attempting to fetch media at this stage returns 404 errors and consumes API rate limits. The platform only generates the finalized media object after codec transcoding and participant metadata attachment complete.
Architectural Reasoning: The completed event guarantees that the media file exists, is fully transcoded, and contains accurate participant routing data. Fetching before completion introduces race conditions where the orchestration service downloads partial files. The platform rate limits recording metadata API calls to 10 requests per second per organization. Triggering on completion aligns fetch operations with available media, preventing unnecessary API consumption and reducing orchestration latency.
POST /api/v2/integrations/webhooks
Authorization: Bearer <ACCESS_TOKEN>
"name": "Dual-Write Recording Orchestrator",
"url": "https://orchestrator.internal/api/v1/webhooks/recording-complete",
"event": "RECORDING_COMPLETED",
"enabled": true,
"contentType": "application/json",
"retryCount": 3,
"retryDelay": 15000,
"headers": {
"X-Webhook-Source": "GenesysCloud",
"X-Environment": "production"
3. Dual-Write Orchestration Logic
The orchestration service receives the webhook payload, validates the HMAC signature, and extracts the recording ID. It then initiates two parallel media fetch operations. The first request targets the primary storage endpoint. The second request targets the backup storage endpoint. Both requests use the same recording ID as a routing key. The service streams the media directly from the platform CDN to both storage buckets without buffering locally.
Use HTTP range requests to handle large media files exceeding 500 MB. Configure chunk sizes of 8 MB to optimize throughput across varying network conditions. Implement a circuit breaker pattern for each storage endpoint. If the primary endpoint returns 5xx errors, the circuit opens for 30 seconds, allowing the backup write to proceed independently. If both endpoints fail, the service queues the recording ID for asynchronous retry and returns a 200 OK to the platform to acknowledge webhook receipt.
The Trap: Implementing sequential blocking writes where the backup operation waits for the primary operation to complete. Under peak IVR traffic, primary storage latency spikes cause backup writes to queue behind primary retries. This creates a cascading delay that exceeds the platform webhook timeout threshold. The platform marks the webhook as failed, triggers its own retry loop, and duplicates orchestration requests. Rate limit exhaustion follows within minutes.
Architectural Reasoning: Parallel non-blocking writes decouple the success of each storage tier from the other. The circuit breaker prevents network congestion from propagating between endpoints. Returning 200 OK to the platform acknowledges receipt and stops platform-side retries. The orchestration service assumes responsibility for persistence. This pattern aligns with event-driven architecture principles where the producer platform decouples from consumer durability guarantees. Cross-reference the WEM agent performance monitoring guide to understand how recording latency impacts real-time supervisor dashboards.
const fetchMedia = async (recordingId, storageConfig) => {
const url = `https://api.us.genesyscloud.com/api/v2/analytics/icapdata/recordings/${recordingId}/media`;
const response = await fetch(url, {
headers: {
'Authorization': `Bearer ${storageConfig.token}`,
'Accept': 'audio/mp4'
if (!response.ok) throw new Error(`Primary fetch failed: ${response.status}`);
const uploadStream = storageConfig.client.putObject({
Bucket: storageConfig.bucket,
Key: `recordings/${recordingId}.mp4`,
Body: response.body
return await uploadStream;
const dualWrite = async (recordingId, primaryConfig, backupConfig) => {
const results = await Promise.allSettled([
fetchMedia(recordingId, primaryConfig),
fetchMedia(recordingId, backupConfig)
const primarySuccess = results[0].status === 'fulfilled';
const backupSuccess = results[1].status === 'fulfilled';
if (!primarySuccess && !backupSuccess) {
await queueForRetry(recordingId, results);
4. Idempotency Enforcement & Retry Architecture
Recording pipelines experience duplicate webhook deliveries due to network partitions or platform retry logic. The orchestration service must enforce strict idempotency. Use the recording ID as the idempotency key across all database records, storage keys, and audit logs. Before initiating any media fetch, query the orchestration database for an existing completed record matching the recording ID. If a record exists and both storage flags are true, skip the pipeline entirely.
Implement exponential backoff for failed writes. Base delay starts at 5 seconds, multiplies by 2 for each retry, and caps at 5 minutes. Track retry counts per recording ID. After three consecutive failures on a single storage tier, mark that tier as degraded and route future recordings to the healthy tier only. Generate a reconciliation job that runs hourly to compare primary and backup inventories. The job identifies missing files, triggers targeted re-fetches, and updates compliance audit logs.
The Trap: Retrying writes without checking idempotency state or overwriting existing objects. Duplicate media files consume storage quotas, break cryptographic hash verification for compliance audits, and corrupt downstream speech analytics pipelines. Overwriting objects during active writes causes partial file corruption that fails codec validation during playback.
Architectural Reasoning: Idempotency guarantees that multiple webhook deliveries result in exactly one persistent media file per storage tier. The orchestration database acts as the source of truth for pipeline state. Storage endpoints become append-only targets. Exponential backoff prevents thundering herd problems during storage provider outages. The reconciliation job compensates for transient failures that fall outside the retry window. This design satisfies PCI-DSS requirement 10.7 for audit trail preservation and ensures speech analytics ingestion pipelines receive consistent file hashes.
"recordingId": "rec-8a7f3b2c-9d4e-4f1a-b5c6-7e8d9f0a1b2c",
"status": "completed",
"primaryStorage": {
"bucket": "gen-primary-recordings-prod",
"key": "recordings/rec-8a7f3b2c-9d4e-4f1a-b5c6-7e8d9f0a1b2c.mp4",
"etag": "d41d8cd98f00b204e9800998ecf8427e",
"timestamp": "2024-05-12T14:32:18Z"
"backupStorage": {
"bucket": "gen-backup-recordings-prod",
"timestamp": "2024-05-12T14:32:19Z"
"idempotencyKey": "rec-8a7f3b2c-9d4e-4f1a-b5c6-7e8d9f0a1b2c",
"retryCount": 0
Edge Case 1: Primary Storage Throttling During Peak IVR Traffic
- The failure condition: The primary storage endpoint returns 429 Too Many Requests errors during high-concurrency call bursts. The orchestration service queues retries, but the retry queue grows faster than the processing capacity. Backup writes succeed, but primary writes stall for hours.
- The root cause: Platform recording completion events fire in rapid succession during IVR overflow or campaign launches. The orchestration service lacks request rate limiting aligned with storage provider API quotas. Sequential retry logic blocks new webhook processing threads.
- The solution: Implement a token bucket rate limiter at the orchestration ingress layer. Cap primary write requests to 50% of the storage provider documented limit. Route excess traffic directly to the backup store while queuing primary writes for off-peak processing. Configure the circuit breaker to open immediately on 429 responses rather than waiting for 5xx errors. Adjust the reconciliation job to prioritize primary store backfill during low-traffic windows.
Edge Case 2: Webhook Delivery Timeout Masking Successful Writes
- The failure condition: The platform marks webhook deliveries as failed after 30 seconds. The orchestration service successfully writes to both stores but fails to return a 200 OK response before the platform timeout expires. The platform triggers duplicate webhook deliveries, causing the orchestration service to process the same recording ID multiple times despite idempotency checks.
- The root cause: Network latency between the platform edge and the orchestration service exceeds the platform webhook timeout threshold. Database transaction commits for idempotency state updates run synchronously after media writes, delaying the HTTP response.
- The solution: Decouple the HTTP response from the media write operation. Acknowledge the webhook with 200 OK immediately after signature validation and database insertion of a pending state. Offload media fetching to an asynchronous worker queue. Update the idempotency check to allow concurrent pending states but block duplicate completed states. Configure the platform webhook retry delay to exceed the maximum expected worker queue processing time.
Edge Case 3: Cross-Region Network Partition During Dual-Write Commit
- The failure condition: A regional internet routing failure isolates the backup storage endpoint from the orchestration service. Primary writes succeed. Backup writes fail with connection timeouts. The reconciliation job detects missing backup files but cannot reach the backup endpoint to trigger re-fetches. Compliance audits flag the backup store as non-compliant.
- The root cause: Single-region orchestration service deployment creates a network dependency on the backup storage region. DNS resolution or BGP routing failures prevent outbound connectivity. The reconciliation job runs in the same isolated environment as the orchestrator.
- The solution: Deploy the orchestration service across two availability zones with active-active load balancing. Configure the reconciliation job to run in a separate region with direct cross-region VPC peering or ExpressRoute to both storage endpoints. Implement DNS failover routing that detects regional connectivity loss and redirects orchestration traffic to the secondary region. Add health check probes that monitor storage endpoint latency and automatically adjust routing weights before complete partition occurs.
