Architecting Multi-Region Edge Tie Lines for Global Call Center Resilience
This guide details the configuration and routing logic required to establish synchronous call bridging between Genesys Cloud CX organizations across distinct AWS regions using Edge Tie Lines. When complete, your environment will route calls to a primary region, automatically fail over to a secondary region during localized outages, and maintain caller context without dropping SIP sessions.
- Licensing: Genesys Cloud CX 1 or higher for both Primary and Secondary organizations. Edge Tie Lines require the Edge Tie Line add-on license per organization. The feature does not consume standard UC or WEM licenses.
- Permissions:
Telephony > Trunk > Edit,Telephony > Edge Tie Line > Manage,Architect > Flow > Edit,Administration > Organization > Edit,Telephony > Routing Strategy > Edit. - OAuth Scopes:
edge_tie_line:read,edge_tie_line:write,telephony:read,telephony:write,flow:read,flow:write. - External Dependencies: Cross-region VPC peering or AWS Transit Gateway is not required for the SIP signaling path. Genesys routes Edge Tie Line traffic over its internal mesh network. A global load balancer or DNS failover mechanism is required for web and chat channels, but this guide focuses strictly on the voice SIP path. Both organizations must share a common
SIP Domainsuffix for successful INVITE routing.
1. Establishing the SIP Trunk Pairing & Edge Tie Line Provisioning
Edge Tie Lines function as encrypted, bidirectional SIP trunks that connect two Genesys Cloud organizations. They do not traverse the public internet. The signaling path terminates at the Genesys platform edge in each region, and media streams are routed through the platform’s internal codec gateway when transcoding is required.
Begin by provisioning the logical link. Navigate to Admin > Telephony > Trunks in the Primary organization. Select Create Trunk and set the Trunk Type to Edge Tie Line. The platform will prompt for the Secondary organization identifier. You must input the exact Organization ID from the target region. Once linked, the platform generates a unique SIP Domain for the tie line. This domain must be identical in both organizations for SIP routing to resolve correctly.
The Trap: Misaligning the Contact Center URI with the generated SIP Domain. If the SIP domain does not match the tenant’s ccapi.mypurecloud.com base structure, the initial INVITE fails with a 404 Not Found. Additionally, configuring the trunk type as SIP Trunk instead of Edge Tie Line forces the platform to apply PSTN normalization rules. This strips E.164 formatting from the From and To headers, causing downstream CRM softphone pop-ups to fail and breaking compliance reporting.
Architectural Reasoning: We provision Edge Tie Lines as bidirectional logical links rather than unidirectional trunks to enable symmetric failover. A unidirectional configuration requires separate inbound and outbound routing strategies, doubling the maintenance surface and introducing asymmetric latency. Bidirectional provisioning allows the platform to negotiate session boundaries in a single transaction, reducing SIP handshake time by approximately 300ms.
Provision the tie line via the REST API to ensure version control and infrastructure-as-code compliance. Use the following payload:
POST /api/v2/telephony/providers/edge-tie-lines
"name": "US-East-EU-West-EdgeTie",
"primaryOrganizationId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"secondaryOrganizationId": "f9e8d7c6-b5a4-3210-fedc-ba9876543210",
"sipDomain": "us-east-eu-west.tenant.genesiscloud.com",
"enabled": true,
"maxConcurrentSessions": 500,
"codecPreferences": [
"PCMU",
"PCMA"
The maxConcurrentSessions parameter defines the circuit capacity. Set this value based on your Business Continuity Plan (BCP) requirements, not your peak concurrent call volume. During a regional outage, the secondary region must absorb overflow traffic. If you size this parameter to match normal operations, the secondary region will reject INVITEs with 486 Busy Here when the primary region fails. We typically provision Edge Tie Lines at 150% of the primary region’s peak concurrent capacity to accommodate burst traffic during failover events.
2. Configuring Cross-Region Routing Logic & Failover Triggers
Routing logic must implement a circuit-breaker pattern. The primary region evaluates call health and routes normally. When the platform detects a 503 Service Unavailable or 408 Request Timeout from the Edge Tie Line target, the flow must pivot immediately. We achieve this using the Transfer To block with explicit failover routing.
In Architect, add a Transfer To block. Set the Target Type to Edge Tie Line. Select the provisioned tie line from the dropdown. Configure the Failover property to Try Next. This setting instructs the platform to attempt the secondary routing target if the Edge Tie Line does not return a 200 OK within the specified timeout window. Set the Timeout to 3000 milliseconds. Values below 2000ms trigger premature failover during transient network jitter. Values above 5000ms violate FCC and GDPR response time requirements for critical services.
The Trap: Using Transfer To without configuring the Caller ID preservation policy. By default, Genesys Cloud replaces the P-Asserted-Identity header with the outbound trunk number of the primary region when crossing the Edge Tie Line. The secondary region receives the call with a masked caller ID. This breaks compliance frameworks like PCI-DSS and HIPAA, which require end-to-end caller identification. It also prevents the secondary region from applying accurate routing strategies based on geographic origin.
Architectural Reasoning: We implement explicit caller ID pass-through by setting the Caller ID policy to Pass Through on the Edge Tie Line trunk configuration. This preserves the original From header across the regional boundary. We pair this with a Set Attributes block upstream to tag the call with origin_region=primary and failover_attempt=1. These attributes allow the secondary region to apply region-specific routing logic without modifying the core flow. The circuit-breaker pattern prevents cascading failures by isolating regional degradation. If the primary region experiences a partial outage, only the affected call legs route to the secondary region. The platform does not drain the entire queue unless a full regional failure is detected.
Deploy the routing logic via the Flow API. The following JSON payload represents a Transfer To block configured for Edge Tie Line failover:
"id": "flow-edge-failover-001",
"name": "Primary Region Failover Strategy",
"type": "voice",
"blocks": {
"transfer-edge-tie": {
"type": "TransferTo",
"settings": {
"targetType": "EdgeTieLine",
"targetId": "edge-tie-us-east-eu-west",
"timeout": 3000,
"failover": "TryNext",
"callerIdPolicy": "PassThrough",
"preserveAttributes": true
"nextBlock": "fallback-queue",
"failoverBlock": "fallback-queue"
"fallback-queue": {
"type": "RouteToQueue",
"settings": {
"queueId": "queue-secondary-overflow",
"callerId": "secondary-compliance-number",
"maxWaitTime": 60000
"nextBlock": null
The preserveAttributes flag ensures that custom attributes set in the primary region survive the SIP boundary crossing. Without this flag, the platform strips non-standard headers to reduce payload size. We explicitly enable it because downstream CRM integrations depend on context preservation.
3. Implementing Call Context Preservation & SDP Negotiation
Media handling across regions requires strict codec alignment. Edge Tie Lines perform transcoding when the primary and secondary regions negotiate different codecs. Transcoding introduces 40 to 60 milliseconds of latency per hop and increases CPU utilization on the media servers. During a failover event, we cannot afford additional latency or processing overhead.
Configure the Codec Preferences on both the primary and secondary Edge Tie Line trunks to match exactly. We lock both regions to PCMU and PCMA. Opus and G.722 are excluded from the Edge Tie Line path. While Opus provides superior compression for webRTC clients, it requires complex payload format negotiation that fails unpredictably during high-concurrency failover events. G.711u provides lossless voice transmission with zero transcoding overhead when both endpoints support it.
The Trap: Relying on Custom Attributes without whitelisting them in the trunk configuration. Genesys Cloud strips non-standard SIP headers by default to prevent header injection attacks. If you do not explicitly whitelist headers in the Trunk > Advanced Settings > Allowed Headers configuration, the secondary region receives a clean SIP INVITE. All downstream routing context, including CRM session tokens and IVR navigation paths, is lost. This breaks softphone pop-ups and forces agents to manually reconcile call data.
Architectural Reasoning: We use X-Genesys-Context headers to pass critical routing metadata across the Edge Tie Line. We map these headers in the trunk configuration under Allowed Headers. We also implement a Set Attributes block immediately before the Transfer To block to serialize the IVR path into a base64-encoded string. The secondary region parses this string to resume the caller at the correct menu level. This prevents the frustrating user experience of returning to the IVR root after a regional failover.
Update the trunk configuration via the REST API to enforce header whitelisting and codec alignment:
PUT /api/v2/telephony/providers/edge-tie-lines/{id}
"allowedHeaders": [
"X-Genesys-Context",
"X-IVR-Path",
"X-Caller-Region"
"PCMU",
"PCMA"
"sdpNegotiation": {
"forceCodecAlignment": true,
"disableTranscoding": true
The disableTranscoding flag forces the platform to reject INVITEs that cannot negotiate a common codec. This is preferable to automatic transcoding because it triggers an immediate 488 Not Acceptable Here response. The Architect flow catches this response and routes to a localized announcement or the fallback queue. Automatic transcoding masks codec mismatches until media degradation occurs, which is difficult to diagnose in production.
Edge Case 1: SIP Loop Detection & Max Hops Exceeded
The Failure Condition: Calls bounce between the primary and secondary regions indefinitely. The platform logs 482 Loop Detected or Max Hop Count Exceeded errors. Callers hear silence followed by a disconnect tone.
The Root Cause: Symmetric failover routing without a visited state flag. Both regions configure identical Transfer To blocks pointing to each other. When Region A experiences a transient degradation, it routes to Region B. Region B evaluates health, sees Region A is also degraded (or misinterprets the incoming call as a failover trigger), and routes back to Region A. The SIP INVITE cycles until the platform terminates it.
The Solution: Implement a stateful routing guard. Add a Set Attributes block before the Transfer To block with the key region_failover_triggered and value true. In the secondary region’s Architect flow, add a Condition block that checks for this attribute. If the attribute exists, the flow bypasses the Edge Tie Line transfer and routes directly to the local queue. Alternatively, configure the Max Hop Count on the Edge Tie Line trunk to 2. This forces the platform to drop calls that exceed two regional boundaries. We recommend the attribute-based approach because it preserves call context and allows for manual override during planned maintenance windows.
Edge Case 2: Timezone & Holiday Calendar Desynchronization
The Failure Condition: Calls route to a closed secondary region during regional holidays or after business hours. Agents in the secondary region receive calls they cannot handle, increasing abandon rates and violating service level agreements.
The Root Cause: Edge Tie Lines do not inherit holiday calendars or business hours. They route based on SIP availability, not queue hours. When the primary region fails, the platform routes to the secondary region regardless of local operating schedules. This occurs frequently in global deployments where regional holidays do not align.
The Solution: Synchronize Holiday Calendar objects via the API and reference the same calendar ID in both regions’ routing strategies. Implement a Get Business Hours block before the Edge Tie Line transfer to validate target availability. The following logic prevents routing to closed regions:
- Retrieve the secondary region’s business hours using the
Get Business Hoursblock. - Evaluate the
isOpenproperty in aConditionblock. - If
isOpenisfalse, route directly to a localized voicemail or callback queue. - If
isOpenistrue, proceed to the Edge Tie LineTransfer Toblock.
This approach ensures that failover logic respects operational boundaries. We pair this with the WFM schedule synchronization process documented in the Workforce Management Calendar Replication guide to maintain consistency across voice, chat, and email channels.
