Architecting Knowledge Base Import and Sync Pipelines from Confluence, SharePoint, and Zendesk
You will build a delta-aware, version-controlled synchronization pipeline that extracts content from Confluence, SharePoint, and Zendesk, normalizes it into a canonical schema, and ingests it into Genesys Cloud Knowledge. The end result is a resilient integration that preserves metadata, handles rich media attachments, resolves concurrent edit conflicts, and maintains strict auditability across all three source systems.
- Genesys Cloud Licensing: CX 2 or higher. Knowledge base creation and management are available on CX 1, but agent assist routing, AI suggestions, and advanced analytics require CX 2 or CX 3.
- Genesys Permissions:
Knowledge > Space > Edit,Knowledge > Article > Edit,Knowledge > Article > Publish,Knowledge > Label > Edit,Assets > Asset > Edit - OAuth Scopes:
knowledge:space:read,knowledge:space:write,knowledge:article:read,knowledge:article:write,knowledge:article:version,assets:asset:upload - Source API Access:
- Confluence Cloud:
readandwritescopes for content and attachments - Microsoft Graph (SharePoint):
Sites.ReadWrite.All,Files.ReadWrite.All - Zendesk Guide: OAuth with
readandwritefor articles and attachments
- Confluence Cloud:
- Orchestration Layer: Persistent queue system (AWS SQS, Azure Service Bus, or RabbitMQ) paired with a state store (PostgreSQL or DynamoDB) for cursor tracking. Do not run sync logic in ephemeral serverless functions without external state persistence.
1. Source Abstraction and Metadata Normalization
You cannot map each source system directly to Genesys Cloud Knowledge. Confluence uses page trees and labels, SharePoint relies on list columns and folder hierarchies, and Zendesk organizes content by categories and sections. Direct 1:1 mapping creates a maintenance nightmare when source APIs deprecate fields or change naming conventions. You must implement a canonical intermediate schema that translates source-specific identifiers into Genesys-compatible metadata.
Genesys Knowledge requires a spaceId to route content. Your pipeline must maintain a deterministic mapping between source namespaces and target spaces. Store this mapping in your state store as a JSON configuration object. When the pipeline ingests a new document, it resolves the source path to a target spaceId before proceeding.
"space_mappings": {
"confluence://wiki/spaces/OPS": "gen-space-ops-procedures",
"sharepoint://sites/HR/Shared Documents": "gen-space-hr-policies",
"zendesk://guide/categories/12345": "gen-space-customer-support"
"metadata_translations": {
"confluence_labels": "gen_custom_label",
"sharepoint_department": "gen_department_tag",
"zendesk_section_id": "gen_source_reference"
The Trap: Hardcoding space IDs directly in transformation scripts without a fallback resolution mechanism. When a space is archived in Genesys or a source team restructures folders, the pipeline throws 404 errors and silently drops content.
Architectural Reasoning: We use a resolution layer instead of direct mapping because enterprise content reorganization is inevitable. The abstraction layer allows you to update routing rules without redeploying the entire pipeline. It also enables content merging when multiple source paths should feed a single Genesys space. You validate the mapping against the Genesys Space API before processing any batch. If the space does not exist, the pipeline quarantines the payload and triggers an alert rather than failing the entire run.
2. Delta Detection and Versioning Strategy
Full resynchronization is architecturally unsustainable. A mid-sized enterprise maintains tens of thousands of knowledge documents. Polling for every record on every run will exhaust API quotas and introduce unacceptable latency. You must implement cursor-based delta detection combined with source-specific change logs.
Each source system provides a revision mechanism. Confluence exposes changelog endpoints that return modified content IDs since a timestamp. SharePoint offers list/getChanges for incremental updates. Zendesk provides updated_at filtering on article endpoints. Your pipeline stores a last_sync_cursor per source in your state store. On each execution, you query the source change log, extract modified or deleted records, and process only that subset.
Genesys Cloud Knowledge enforces strict versioning. Every article carries a version integer that increments on each draft or publish action. You must track the source revision ID alongside the target Genesys version. When a source document updates, your pipeline fetches the current Genesys article, compares the stored source revision against the latest source revision, and only proceeds if they differ.
GET https://{subdomain}.mygenesys.com/api/v2/knowledge/articles/{articleId}
Authorization: Bearer {access_token}
Accept: application/json
Response payload includes:
"id": "art-12345",
"version": 4,
"spaceId": "gen-space-ops-procedures",
"title": "Server Maintenance Window",
"status": "published",
"createdDate": "2023-08-12T10:00:00.000Z",
"modifiedDate": "2024-01-15T14:30:00.000Z"
The Trap: Relying exclusively on modifiedDate for delta detection without accounting for timezone normalization and clock skew. Source systems often store timestamps in local time or use different precision. A one-second discrepancy causes duplicate publications or missed updates.
Architectural Reasoning: We reject timestamp-only synchronization because it violates eventual consistency guarantees. Instead, we combine cursor tracking with source revision IDs. The cursor determines the polling window. The revision ID determines whether the content actually changed. This two-layer approach prevents phantom updates and ensures idempotent processing. You must store cursors with millisecond precision and always convert timestamps to UTC before comparison. If a source system lacks a revision ID, you compute a SHA-256 hash of the raw payload and store that hash as the revision identifier.
3. Payload Transformation and Rich Text Sanitization
Genesys Cloud Knowledge expects clean HTML with specific structural requirements. Confluence outputs ac:structured-macro tags and ac:link references. SharePoint renders tables with tr and td elements that include inline styling. Zendesk produces standard HTML but injects proprietary classes like prose and inline-code. Passing raw source HTML directly to Genesys breaks rendering, introduces cross-site scripting vulnerabilities, and fails platform validation.
You must implement a server-side HTML sanitization engine that strips source-specific macros, normalizes attributes, and preserves semantic structure. Use a library like DOMPurify (Node.js) or bleach (Python) with a strict allowlist. The allowlist must include h1 through h6, p, ul, ol, li, table, tr, td, th, a, strong, em, code, pre, and img. All other tags are removed. Attributes are restricted to href, src, alt, class, style, and data-*.
Attachments require separate handling. Genesys Knowledge does not accept raw file uploads in article payloads. You must upload files to the Genesys Asset API first, retrieve the assetId, and reference it in the article HTML using the platform-specific image syntax.
POST https://{subdomain}.mygenesys.com/api/v2/assets
Content-Type: multipart/form-data
--boundary
Content-Disposition: form-data; name="file"; filename="network-diagram.png"
Content-Type: image/png
<binary_payload>
--boundary--
Response:
"id": "asset-98765",
"name": "network-diagram.png",
"mimeType": "image/png",
"size": 245632,
"createdDate": "2024-01-20T09:15:00.000Z"
You then inject the asset into the article body:
<img src="/api/v2/assets/asset-98765/download" alt="Network Architecture Diagram" data-asset-id="asset-98765" />
The Trap: Using client-side sanitization or passing unsanitized markdown directly to the Knowledge API. Genesys rejects markdown. It also rejects HTML containing script, iframe, or object tags. Unsanitized payloads trigger 400 Bad Request responses and halt the sync queue.
Architectural Reasoning: We enforce server-side sanitization because pipeline integrity depends on deterministic output. Client-side libraries cannot guarantee consistent parsing across different runtime environments. The Asset API separation ensures binary content is handled independently from metadata. This decoupling allows you to retry article creation without re-uploading large files. You must implement a retry policy with exponential backoff for asset uploads, as the Asset API enforces stricter rate limits than the Knowledge API.
4. Genesys Cloud Ingestion and Conflict Resolution
Genesys Cloud Knowledge operates on a draft-to-publish workflow. You cannot publish content directly on creation. The pipeline must create a draft, validate it, and then transition it to published status. Updates require optimistic concurrency control. You must fetch the current article version, increment it, and submit a PATCH request with an If-Match header containing the original version number.
PATCH https://{subdomain}.mygenesys.com/api/v2/knowledge/articles/{articleId}
If-Match: 4
"version": 5,
"title": "Server Maintenance Window (Updated)",
"body": "<p>Revised maintenance procedures for Q2 2024.</p>",
"status": "draft"
If a human author edits the article in the Genesys UI while the pipeline runs, the version will mismatch. The API returns a 409 Conflict. Your pipeline must catch this response, re-fetch the latest article, merge the changes, and retry the update.
For new articles, use POST:
POST https://{subdomain}.mygenesys.com/api/v2/knowledge/articles
"title": "New Onboarding Checklist",
"body": "<p>Step-by-step guide for new hires.</p>",
"status": "draft",
"labels": ["onboarding", "hr"],
"customMetadata": {
"source_system": "sharepoint",
"source_id": "sp-doc-445566"
After successful creation or update, trigger the publish action:
POST https://{subdomain}.mygenesys.com/api/v2/knowledge/articles/{articleId}/publish
The Trap: Using POST for updates or ignoring the version field in PATCH requests. This creates duplicate drafts, overwrites human edits, and breaks audit trails. Genesys will accept the request but silently discard previous draft history.
Architectural Reasoning: We enforce optimistic locking because knowledge content is frequently edited by both humans and automation. The If-Match header guarantees that updates only apply when the article has not changed since ingestion. When a 409 occurs, you implement a merge strategy that prioritizes human edits for title and body fields while preserving pipeline-managed metadata like source_id and sync_timestamp. You log all conflicts to a dedicated audit table for compliance review. This approach prevents data loss and maintains a clear lineage between source and target systems.
Edge Case 1: Attachment Reference Drift
The Failure Condition: The pipeline successfully syncs an article containing an embedded image. Six months later, the source system deletes the image file. The Genesys article still references the old assetId, but the underlying file returns a 404 in the UI.
The Root Cause: Source systems treat attachments as ephemeral resources tied to document lifecycles. Genesys Assets are permanent unless explicitly deleted. The pipeline never validates attachment existence before reference injection.
The Solution: Implement a pre-sync attachment validation step. Before processing an article, query the source API for each referenced attachment. If the attachment returns a 404, regenerate a placeholder image or strip the reference. For new syncs, always upload fresh copies to the Genesys Asset API rather than reusing existing assetId values. Store a hash of the source file in custom metadata. On subsequent runs, compare the hash. If it differs, upload a new asset and update the article body. This ensures attachment integrity matches source state.
Edge Case 2: Concurrent Author Edits Overwriting Pipeline Updates
The Failure Condition: A knowledge manager updates an article title directly in Genesys Cloud. Simultaneously, the pipeline detects a source update and attempts to overwrite the title. The 409 conflict triggers a merge, but the merge logic incorrectly prioritizes the pipeline payload, erasing the human edit.
The Root Cause: The merge strategy lacks field-level precedence rules. It treats the entire payload as a single unit rather than evaluating individual attributes.
The Solution: Implement a field-level merge matrix. Define which fields belong to the pipeline and which belong to human authors. Pipeline-owned fields include customMetadata.source_id, customMetadata.sync_cursor, and body (if source-controlled). Human-owned fields include title, labels, and customMetadata.approver. When a 409 occurs, fetch the current article, apply human-owned fields from the Genesys response, and apply pipeline-owned fields from the transformation output. Re-increment the version and retry. Document this precedence matrix in your pipeline configuration so developers understand edit boundaries. This pattern also applies when integrating with WFM routing rules that depend on knowledge labels, as covered in the Workforce Management Integration guide.
Edge Case 3: Rate Limit Throttling During Initial Full Sync
The Failure Condition: During a fresh deployment, the pipeline attempts to synchronize 15,000 articles. It fires concurrent requests to the Knowledge API and Asset API. Genesys returns 429 Too Many Requests responses. The queue backs up, timeouts occur, and the sync job fails after two hours.
The Root Cause: Burst traffic violates Genesys platform rate limits. The Knowledge API enforces 200 requests per minute per OAuth client. The Asset API enforces 50 uploads per minute. The pipeline lacks throttling and backoff logic.
The Solution: Implement a token bucket algorithm at the orchestration layer. Cap concurrent API calls to 80% of the documented limit to absorb traffic spikes. For the initial full sync, batch articles by space and process them sequentially. Insert a 300-millisecond delay between PATCH and POST requests. When a 429 response occurs, parse the Retry-After header. If the header is missing, apply exponential backoff starting at 2 seconds, doubling up to 60 seconds. After three consecutive 429s, pause the pipeline for five minutes and notify the operations team. Monitor X-RateLimit-Remaining headers to dynamically adjust concurrency. This approach guarantees completion without triggering platform-level throttling blocks.
