Architecting Explainable ML Dashboards for Business Stakeholder Consumption of Model Predictions
This guide details the architectural patterns required to expose machine learning model predictions and their underlying feature attributions to business stakeholders via Genesys Cloud CX and NICE CXone interfaces. You will build a pipeline that ingests raw model outputs, translates them into human-readable explanations using SHAP or LIME values, and presents them in custom dashboard components or integrated CRM views. The end result is a system where a Workforce Engagement Manager or Quality Analyst can see not just that a call was flagged as “High Churn Risk” or “Fraud Probable,” but specifically which caller attributes (e.g., “Sentiment Score < -0.8”, “Wait Time > 120s”) drove that decision, enabling targeted coaching and process improvement.
Licensing Tiers
  • Genesys Cloud CX:
    • CX 2 or CX 3: Required for access to Architect (for data routing) and Custom Objects (for storing prediction metadata).
    • Speech Analytics: Required if the model predictions are derived from real-time speech transcription and sentiment analysis.
    • WEM (Workforce Experience Management): Required if the explanations are to be viewed within the Quality Management or Coaching modules.
  • NICE CXone:
    • CXone Platform: Base license.
    • Conversation Intelligence: Required for real-time transcription and sentiment features used as model inputs.
    • Custom Objects: Required for storing prediction payloads and explanation vectors.
Permissions & Scopes
  • Genesys Cloud:
    • CustomObject > Edit: To create the schema for prediction storage.
    • Data > Integration > Edit: To configure outbound webhooks or REST connections.
    • Architect > Edit: To configure the flow that triggers the model inference.
    • OAuth Scope: customobject:write, customobject:read, analytics:read.
  • NICE CXone:
    • Custom Objects > Manage: To define the data structure.
    • Integrations > Create: To set up the API connection to the ML endpoint.
    • Studio > Edit: To configure the interaction flow.
External Dependencies
  • ML Inference Endpoint: A hosted model (e.g., AWS SageMaker, Azure ML, or a custom Flask/FastAPI service) capable of returning both a prediction class and an explanation payload (e.g., SHAP values).
  • Data Warehouse/Lake: For historical analysis of prediction drift and accuracy (optional but recommended for model governance).
1. Designing the Explanation Data Schema
Before touching the CCaaS platform, you must define how the “explanation” travels. A common mistake is storing only the prediction label (e.g., churn_probability: 0.92). This is useless for business stakeholders who need to know why. You must store the feature attributions.
We use a JSON structure that pairs each input feature with its contribution score. This allows the frontend dashboard to highlight the most significant drivers.
The Schema Strategy
Do not flatten the explanation array into individual columns (e.g., feature_1_score, feature_2_score). Feature sets change as models are retrained. Instead, store the explanation as a serialized JSON string or a Custom Object with a flexible attribute list.
Genesys Cloud Custom Object Definition
Create a Custom Object named ML_Prediction_Explanation.
  "name": "ML Prediction Explanation",
  "description": "Stores model predictions and SHAP-based feature attributions",
  "fields": [
      "name": "interactionId",
      "type": "String",
      "description": "Genesys Interaction ID"
      "name": "modelVersion",
      "type": "String",
      "description": "Version of the model used (e.g., v2.1.0)"
      "name": "predictionLabel",
      "type": "String",
      "description": "The outcome class (e.g., 'High Churn')"
      "name": "confidenceScore",
      "type": "Number",
      "description": "Model confidence (0.0 to 1.0)"
      "name": "explanationPayload",
      "type": "Text",
      "description": "JSON string containing feature attributions"
      "name": "timestamp",
      "type": "Date",
      "description": "Time of inference"
The Trap: Storing Raw Feature Values
A frequent misconfiguration is storing the raw input values (e.g., wait_time: 120) alongside the scores. This is redundant and bloats the database. The business stakeholder does not need to see the raw number again; they need to see the relative impact. Store only the feature name, the contribution score, and a human-readable label mapping.
NICE CXone Custom Object Definition
In CXone, create a Custom Object with similar fields. Note that CXone handles JSON fields natively in some versions, but for broader compatibility in older deployments, serialize the explanation array to a string.
  "name": "ML_Prediction_Explanation",
  "fields": {
    "interaction_id": { "type": "string" },
    "model_version": { "type": "string" },
    "prediction_label": { "type": "string" },
    "confidence_score": { "type": "number" },
    "explanation_payload": { "type": "string" },
    "created_at": { "type": "datetime" }
2. Orchestrating the Inference and Explanation Capture
The CCaaS platform acts as the trigger. As an interaction occurs (voice or digital), the platform must send the relevant context to the ML endpoint, receive the prediction and explanation, and persist it.
Genesys Cloud: Architect Flow Configuration
  1. Data Collection: Use the Get Interaction Data block to gather wait_time, queue_name, agent_tenure, and sentiment_score (if Speech Analytics is enabled).
  2. Construct Payload: Use a Set Variables block to build the JSON body for the ML API.
      "features": {
        "wait_time_sec": {{wait_time}},
        "agent_tenure_days": {{agent.tenure_days}},
        "sentiment_score": {{speech.sentiment_score}},
        "queue_name": "{{queue.name}}"
  3. HTTP Request: Use the HTTP Request block to call the ML endpoint.
    • Method: POST
    • URL: https://ml-endpoint.example.com/predict
    • Headers: Content-Type: application/json, Authorization: Bearer {{api_key}}
    • Body: The constructed JSON.
  4. Parse Response: The ML endpoint must return a structured JSON.
      "prediction": "High Churn",
      "confidence": 0.94,
      "explanation": [
        { "feature": "wait_time_sec", "shap_value": 0.45, "label": "Long Wait Time" },
        { "feature": "sentiment_score", "shap_value": 0.32, "label": "Negative Sentiment" },
        { "feature": "agent_tenure_days", "shap_value": 0.12, "label": "New Agent" }
  5. Persist Data: Use the Create Custom Object Record block to save the response to ML_Prediction_Explanation.
      "interactionId": "{{interaction.id}}",
      "modelVersion": "v2.1.0",
      "predictionLabel": "{{httpResponse.prediction}}",
      "confidenceScore": {{httpResponse.confidence}},
      "explanationPayload": "{{httpResponse.explanation | to_json}}",
      "timestamp": "{{now}}"
NICE CXone: Studio Flow Configuration
  1. Variable Mapping: In the Studio flow, map interaction attributes to variables.
  2. REST API Block: Add a REST API element.
    • Configure the endpoint and payload similarly to Genesys.
  3. Response Handling: Use a Set Variable block to parse the JSON response. CXone Studio allows direct JSON path extraction.
  4. Custom Object Insert: Add a Custom Object element to insert the record.
The Trap: Synchronous Blocking
If the ML model takes longer than 2-3 seconds to respond, you risk timing out the CCaaS platform’s HTTP request limit (Genesys Cloud typically times out HTTP requests after 30 seconds, but best practice is <5s for real-time flows).
Solution: If the model is slow, decouple the process.
  1. Push the interaction context to a message queue (e.g., AWS SQS, RabbitMQ) from the CCaaS platform.
  2. The ML service consumes the message, runs inference, and writes directly to the Custom Object via the CCaaS API.
  3. The CCaaS flow continues immediately without waiting. This is critical for high-volume voice interactions where latency impacts agent experience.
3. Building the Explainable Dashboard Interface
Business stakeholders do not read JSON. They need a visual representation. You have two primary paths: Custom Dashboard Widgets (Genesys) or Integrated CRM Views.
Path A: Genesys Cloud Custom Dashboard Widget
Use the Genesys Cloud Dashboard SDK to build a React-based widget that fetches and renders the explanations.
  1. Data Fetching: Use the fetch API to query the Custom Object.
    // Example fetch logic within a React component
    useEffect(() => {
      const fetchPredictions = async () => {
        const response = await fetch('/api/v2/custom-object-definitions/ML_Prediction_Explanation/records', {
          headers: {
            'Authorization': `Bearer ${accessToken}`,
            'Content-Type': 'application/json'
        const data = await response.json();
        setPredictions(data.records);
      fetchPredictions();
  2. Rendering the Explanation: Parse the explanationPayload and render a bar chart or a list of key drivers.
    // Simplified React Component for Explanation Display
    const ExplanationCard = ({ payload }) => {
      const explanations = JSON.parse(payload.explanationPayload);
      return (
        <div className="explanation-card">
          <h3>Prediction: {payload.predictionLabel}</h3>
          <p>Confidence: {(payload.confidenceScore * 100).toFixed(1)}%</p>
          <ul>
            {explanations.map((exp, index) => (
              <li key={index}>
                <strong>{exp.label}</strong>:
                <span className={exp.shap_value > 0 ? "positive" : "negative"}>
                  {exp.shap_value.toFixed(2)}
                </span>
              </li>
          </ul>
        </div>
Path B: NICE CXone Embedded CRM
If stakeholders use an external CRM (e.g., Salesforce), embed the explanation directly into the contact record.
  1. REST API Integration: Create a REST API integration in CXone that maps the Custom Object fields to Salesforce Custom Fields.
  2. Field Mapping:
    • prediction_label → Churn_Risk__c
    • explanation_payload → Churn_Explanation_JSON__c
  3. Salesforce Lightning Component: Build a Lightning Web Component (LWC) that parses Churn_Explanation_JSON__c and renders a visual bar chart using Salesforce’s lightning-bar-chart or a custom D3.js implementation.
The Trap: Information Overload
Displaying all 20+ features from a SHAP model overwhelms the user.
Solution: Implement a “Top-K” filter in the dashboard logic. Only display the top 3-5 features with the highest absolute SHAP values. Add a “Show All” toggle for power users. This focuses the stakeholder’s attention on the actionable insights.
4. Connecting Explanations to Coaching Actions
An explanation is only valuable if it drives action. You must link the prediction explanation to the Quality Management (QM) or Coaching workflow.
Genesys Cloud: QM Form Integration
  1. Custom Fields in QM: Add a custom field to the Quality Assessment Form: ML_Prediction_Reason.
  2. Populate via API: When an interaction is selected for review, use a Script or Flow to fetch the explanationPayload from the Custom Object and populate the QM form field.
  3. Display in QM UI: The Quality Analyst sees the top drivers (e.g., “Long Wait Time”) directly in the evaluation form. This allows them to assess whether the agent mitigated the risk factor effectively.
NICE CXone: Quality Management Integration
  1. Custom Object Link: Link the ML_Prediction_Explanation object to the Interaction object.
  2. QM Form Designer: Add a field that pulls data from the linked Custom Object.
  3. Dynamic Sections: Use conditional logic in the QM form to show specific coaching questions based on the prediction.
    • If prediction_label == “High Churn”, show questions about “Empathy” and “Resolution”.
    • If prediction_label == “Fraud Probable”, show questions about “Verification Procedures”.
The Trap: Stale Data
If the model is retrained, the feature names or scales may change. Old predictions may fail to parse if the dashboard expects a specific structure.
Solution: Include a modelVersion field in the Custom Object. The dashboard must check this version against the current expected schema. If the version is older, apply a backward-compatible parsing rule or flag the record as “Legacy Model” to avoid errors.
Edge Case 1: Missing Feature Data in Real-Time
The Failure Condition
The ML model expects agent_tenure_days, but the interaction is handled by a generic queue where agent assignment hasn’t occurred yet, or the agent data is not populated in the Architect/Studio context. The model returns an error or a default prediction.
The Root Cause
The HTTP request payload is incomplete. The ML service rejects the request due to missing required features.
The Solution
  1. Default Values: In the CCaaS flow, set default values for missing features (e.g., agent_tenure_days: 0).
  2. Model Robustness: Ensure the ML model is trained to handle missing values (e.g., using imputation) or explicitly flag missing features in the explanation as “Data Missing”.
  3. Fallback Logic: If the ML service returns an error, log the error in the Custom Object with a predictionLabel of “Model Error” and an explanationPayload indicating the missing fields. This allows stakeholders to identify data quality issues.
Edge Case 2: High-Volume Explanation Storage Bottlenecks
During peak hours, the volume of interactions exceeds the write capacity of the Custom Object API, causing timeouts or dropped records.
The Root Cause
Synchronous writes to the Custom Object from every interaction flow. Genesys Cloud and CXone have rate limits on Custom Object API calls.
The Solution
  1. Batching: Instead of writing one record per interaction, batch the predictions in memory (or a local queue) and write them in bulk every 30 seconds.
    • Genesys: Use a Flow that runs on a schedule to process a queue of pending predictions.
    • CXone: Use a Studio flow with a delay element to aggregate records before writing.
  2. Async Queue: As mentioned in the “Trap” section, push to a message queue and let a backend service handle the writes. This decouples the interaction latency from the storage latency.
Edge Case 3: Explanation Drift and Stakeholder Distrust
Stakeholders notice that the “Top Driver” for a prediction changes frequently or seems counter-intuitive (e.g., “Short Wait Time” contributing to “Churn”). They lose trust in the model.
The Root Cause
The model is capturing spurious correlations or the feature labels are not accurately mapped to business terms.
The Solution
  1. Feature Label Review: Regularly review the label field in the explanationPayload. Ensure “Short Wait Time” is not a proxy for “Voicemail Only” interactions, which might have different churn dynamics.
  2. Model Monitoring: Implement a dashboard that tracks the distribution of SHAP values over time. If the contribution of a specific feature spikes unexpectedly, alert the data science team.
  3. Human-in-the-Loop: Allow stakeholders to flag incorrect explanations. Store these flags in a separate Custom Object for model retraining feedback.
