Architecting Emergency Mode Routing using API-Triggered Data Actions
This guide details the architectural pattern for dynamically activating and configuring Genesys Cloud Emergency Mode Routing through external incident management systems using Data Actions. You will build a production-grade integration that accepts webhook payloads from your SOC or ITSM platform, validates the incident context, toggles the emergency routing state via the Genesys APIs, and injects dynamic routing parameters into active Architect flows. The end result is a sub-second failover mechanism that bypasses standard IVR logic, redirects all inbound traffic to designated emergency queues, and automatically reverts to standard operations when the incident resolves.
- Licensing Tiers: Genesys Cloud CX 2 or CX 3 tier for Emergency Mode Routing activation. Data Actions require CX 2+ or the Integrations and Automation add-on.
- Granular Permissions:
Telephony > Emergency Mode > Edit,Architect > Flow > Edit,Administration > Integrations > Data Actions > Edit,API > OAuth Client > Manage,Routing > Queue > Edit - OAuth Scopes:
emergency:write,flow:edit,integration:data-action:manage,routing:queue:edit,user:read - External Dependencies: REST-capable incident management system (ServiceNow, PagerDuty, Jira Service Management), TLS 1.2+ endpoint, JSON payload standardization, dedicated OAuth client with restricted scope for EMR operations
1. Data Action Configuration and Payload Contract Design
The foundation of this architecture relies on a strictly typed Data Action that serves as the bridge between your external incident orchestrator and the Genesys Cloud runtime environment. You must configure the Data Action to accept a POST request with a predefined schema. The external system will push incident metadata, target queue identifiers, and a routing mode flag. The Data Action must validate the payload, enforce idempotency, and return a structured response that Architect can parse without branching into error handlers.
Configure the Data Action with the following parameters:
- Request Method:
POST - Timeout:
25000milliseconds (Genesys enforces a hard 30-second ceiling. Setting this to 25 seconds leaves a 5-second buffer for network jitter and response parsing) - Content-Type:
application/json - Retry Logic:
0retries (Retries cause duplicate EMR state transitions. You must handle idempotency at the application layer, not the transport layer)
The Trap: Configuring the Data Action with automatic retries or exceeding the 30-second timeout threshold. When an external ITSM system experiences latency during a real incident, a retry mechanism will fire a second POST to toggle EMR. If the first request is still processing, Genesys will reject the second request with a 409 Conflict, or worse, flip the routing state back to normal before the first transaction completes. This creates a split-brain routing condition where half of your inbound traffic hits emergency queues and half hits standard queues. Always design for idempotency. Use a correlationId field in the payload and validate it against a short-term cache before executing state changes.
Architectural Reasoning: We isolate EMR triggers into a dedicated Data Action rather than bundling them with general CRM or ticketing lookups. Emergency routing operations require guaranteed delivery and immediate execution. Sharing a Data Action with high-latency CRM updates introduces queueing delays at the integration layer. By dedicating the action, you ensure that the Genesys event bus prioritizes the payload and that monitoring tools can track success rates independently of transactional integrations.
Production Payload Contract:
"correlationId": "INC-2024-08-15-7742",
"incidentType": "CARRIER_OUTAGE",
"targetQueueIds": ["queue-12345", "queue-67890"],
"routingMode": "EMERGENCY_ACTIVE",
"timestamp": "2024-08-15T14:22:01Z",
"ttl": 3600
2. Architect Flow Design for Emergency Bypass
Once the Data Action receives the payload, the Architect flow must immediately evaluate the emergency state and route accordingly. Do not rely on static routing blocks. Standard Set Queue blocks do not account for real-time agent capacity, skill availability, or emergency override rules. You must use the Get Emergency Routing block at the flow entry point, followed by a conditional branch that evaluates the emergencyRouting.state property.
Configure the entry block as follows:
- Get Emergency Routing: Returns the current state (
ACTIVE,INACTIVE,PENDING) and associated routing configuration. - Condition:
emergencyRouting.state == "ACTIVE" - True Path: Execute a
Data Actionlookup to fetch the dynamically assigned queue list from the payload cache, then useSet QueuewithqueueIdbound to the first available queue from the array. EnableOverflow to Alternateand setOverflow ConditiontoAll Agents Busy. - False Path: Proceed to standard IVR logic.
The Trap: Hardcoding queue identifiers in the Architect flow or using Set Queue without enabling overflow handling. During an actual carrier outage or application crash, your standard queues will be completely saturated. If the emergency branch routes to a single static queue without overflow logic, Genesys will immediately drop calls once that queue hits its concurrency limit. You will see a spike in Abandoned and Not Answered metrics within 90 seconds of activation. Always implement a queue array with weighted overflow and set Answering Machine Detection to Disabled during emergency mode to prevent false hangups from triggering unnecessary retries.
Architectural Reasoning: We use a dynamic queue array instead of a single target because emergency incidents rarely affect all channels uniformly. A voice trunk failure requires different routing than a CRM database outage. By passing an ordered array of queue IDs through the Data Action payload, you allow the external system to dictate routing priority based on incident severity. The Architect flow simply consumes the array and applies overflow logic. This decouples routing policy from flow logic, enabling your incident response team to adjust routing targets without requiring Architect flow deployments or change management approvals.
3. API Orchestration and State Management
The external system must communicate directly with the Genesys Cloud Telephony API to toggle the emergency routing state. The Data Action handles payload validation, but the actual state transition occurs via the /api/v2/telephony/emergencyrouting endpoint. You must implement a state reconciliation pattern to prevent flapping.
Enable Emergency Routing:
POST /api/v2/telephony/emergencyrouting
"reason": "INC-2024-08-15-7742: Primary SIP Trunk Failure",
"state": "ACTIVE",
"routingConfiguration": {
"queueIds": ["queue-12345", "queue-67890"],
"priority": 1
Disable Emergency Routing:
"reason": "INC-2024-08-15-7742: Resolved - Trunk Restored",
"state": "INACTIVE"
The Trap: Issuing concurrent POST requests to the EMR endpoint without verifying the current state. Genesys Cloud processes EMR state changes asynchronously. If your ITSM system sends a resolution webhook before the activation webhook finishes propagating across regional clusters, the platform will register a state conflict and ignore the second request. Your external system will assume EMR is disabled, while Genesys remains in active mode. This causes traffic to continue routing to emergency queues unnecessarily, draining agent capacity from standard operations. Always implement a pre-flight GET /api/v2/telephony/emergencyrouting check before issuing state transitions. Compare the returned state and lastUpdated timestamp against your local incident cache. Only proceed if the states diverge.
Architectural Reasoning: We treat EMR state as a distributed consensus problem. The external system holds the source of truth for incident lifecycle, but Genesys holds the source of truth for routing execution. By implementing a pre-flight validation step, you align both systems before committing the change. The reason field is mandatory for audit compliance and WFM reconciliation. It must contain the incident ticket ID to enable cross-platform correlation during post-incident reviews. We also set priority: 1 to ensure emergency routing overrides all standard skill-based and geographic routing rules.
4. Watchdog Pattern and Auto-Reversion Logic
Network partitions, API throttling, or OAuth token expiration can cause your external system to lose synchronization with Genesys Cloud. You must implement a watchdog Data Action that polls the EMR state at regular intervals during active incidents and auto-corrects drift.
Configure a scheduled Architect flow or external cron job that executes every 30 seconds:
- Get Emergency Routing: Fetch current state.
- Condition:
emergencyRouting.state == "ACTIVE" AND incidentStatus == "RESOLVED" - Action: Execute
POST /api/v2/telephony/emergencyroutingwithstate: "INACTIVE". - Logging: Push reconciliation events to your monitoring pipeline for audit trails.
The Trap: Relying solely on webhook callbacks for state reversion. Webhooks are fire-and-forget mechanisms. If your ITSM platform experiences a deployment rollback or network blip, the resolution webhook will never fire. Genesys will remain in emergency mode indefinitely. Your agents will be stuck in emergency queues, your WFM forecasts will be invalid, and your Speech Analytics transcription queues will back up. The watchdog pattern eliminates single points of failure by continuously comparing external incident status against internal routing state. It guarantees convergence regardless of webhook delivery success.
Architectural Reasoning: We implement the watchdog at 30-second intervals because Genesys Cloud caches EMR state at the cluster level. Polling faster than 30 seconds triggers API rate limiting on the telephony domain. Polling slower than 30 seconds introduces unacceptable delay during rapid incident resolution. The watchdog flow must use a dedicated OAuth client with emergency:write and emergency:read scopes only. Restricting permissions prevents credential leakage from impacting core routing or user management endpoints. This separation of duties aligns with PCI-DSS and HIPAA segmentation requirements for emergency operations.
Edge Case 1: API Timeout During Peak Load
- The Failure Condition: The Data Action returns a
504 Gateway Timeoutwhile the external system is attempting to activate EMR during a sudden traffic spike. - The Root Cause: Genesys Cloud enforces a hard 30-second timeout on all Data Action requests. During peak load, the integration gateway queues requests, and the external ITSM endpoint may not respond within the window. Architect abandons the flow branch and routes the caller to the default fallback or disconnects them.
- The Solution: Implement asynchronous acknowledgment. Configure the Data Action to return a
202 Acceptedresponse immediately upon payload validation. The external system processes the state change in the background and updates a status cache. The Architect flow polls the cache via a secondary lightweight Data Action with a 5-second timeout. This decouples caller experience from backend processing latency. Always setResponse Timeoutto25000and enableReturn Response on Timeoutwith a fallback JSON structure containingstatus: "PROCESSING".
Edge Case 2: Split-Brain State Between ITSM and Genesys
- The Failure Condition: The external system reports
EMERGENCY_RESOLVED, but Genesys Cloud continues routing to emergency queues. Agents receive calls in the wrong context, and WEM recordings tag interactions with incorrect incident metadata. - The Root Cause: OAuth token rotation occurred during the incident window. The external system cached a token that expired before the resolution
POSTwas sent. Genesys rejected the request with401 Unauthorized, and the external system logged success due to improper HTTP status code validation. - The Solution: Implement token refresh validation before every state transition. Use the
/api/v2/oauth/tokens/meendpoint to verify scope validity. If the token expires, trigger an automatic refresh sequence before retrying the EMR toggle. Configure your external system to treat any4xxresponse as a hard failure requiring immediate alerting. Never assume success based on absence of error. Implement a reconciliation job that runs every 5 minutes during active incidents, comparingincidentStatusin the ITSM database againstemergencyRouting.statein Genesys. Force alignment if divergence exceeds 10 seconds.
Edge Case 3: Architect Flow Cache Invalidation Delay
- The Failure Condition: EMR activates successfully, but inbound calls continue following standard IVR logic for 60 to 90 seconds before switching to emergency queues.
- The Root Cause: Genesys Cloud caches flow execution paths at the regional cluster level to optimize routing performance. When EMR state changes, the cache does not invalidate instantly. New calls entering the flow during the cache refresh window will execute the previous routing path.
- The Solution: Design your Architect flow to evaluate EMR state at multiple decision points, not just the entry block. Place a secondary
Get Emergency Routingblock after the first menu interaction and after any transfer logic. This forces mid-flow state verification. Additionally, configure your Data Action to include acacheBusttimestamp parameter. When the external system detects EMR activation, it pushes a high-frequency ping to the Data Action endpoint for 120 seconds. The repeated requests trigger cache invalidation at the integration gateway, accelerating state propagation. Document this behavior in your incident runbooks so responders understand the 60-second propagation window is normal and not a failure condition.
