Architecting Emergency IVR Failover Flows with Pre-Recorded Message and Callback Collection
This guide details the architectural design and implementation of a Genesys Cloud CX failover IVR that detects system degradation or outage conditions, plays a pre-recorded emergency message, and collects customer callbacks while preserving call context. By the end, you will have a production-ready Architect flow that dynamically switches between normal routing and failover mode, submits callback requests via REST API, and handles edge cases without dropping calls or corrupting state.
- Licensing: CX 2 or higher (required for Advanced Architect features, webhook execution, and custom integration blocks)
- Permissions:
Architect > Flow > EditTelephony > Trunk > EditIntegrations > Webhook > Create/EditRouting > Queue > EditAdmin > Global Variable > Read/Write(if using CX3)
- OAuth Scopes:
routing:callback:create,routing:callback:read,telephony:call:control,integration:webhook:execute,admin:globalvariable:read - External Dependencies:
- Synthetic monitoring or external health check service capable of invoking a Genesys Cloud webhook
- Genesys Cloud Media hosting for pre-recorded prompts
- Callback submission endpoint (native Genesys Cloud Callback API or internal middleware)
- Timezone-aware scheduling service for callback execution
1. Failover State Management & Dynamic Routing Entry
Emergency routing cannot rely on static flow configurations. You must decouple the failover trigger from the flow deployment lifecycle. The recommended architecture uses a lightweight external state store (Redis, DynamoDB, or a Genesys Cloud Data Store) that external monitoring systems update when degradation thresholds are breached. The Architect flow queries this store at entry to determine routing mode.
Configure a Query block at the flow entry point that hits your state endpoint. Set the method to GET, the url to your health check endpoint, and map the response to a flow variable named routingMode. Use a Split block to evaluate routingMode == "FAILOVER". Route the true branch to the emergency message path and the false branch to standard queue routing.
The Trap: Hardcoding the failover toggle inside the Architect flow as a boolean variable and manually updating it during an incident. Manual updates require flow redeployment, which introduces a 15 to 30 second routing gap where calls receive fast busy or default voicemail. In a high-volume outage, this gap causes immediate caller abandonment and carrier retry storms.
Architectural Reasoning: External state management ensures zero-downtime toggling. The monitoring system updates the state store, and subsequent calls immediately read the new value without touching the routing configuration. This pattern also enables automated recovery: when health checks pass, the monitoring system flips the state back, and the flow resumes normal routing on the next call arrival. You avoid deployment pipelines during crisis response.
2. Emergency Message Playback & DTMF Collection Optimization
When the flow enters failover mode, you must play a pre-recorded message and offer a callback option. Use a Play Prompt block configured with your emergency media file. Set playbackTimeout to 15000, maxDigits to 1, and interDigitTimeout to 4000. Connect the digit output to a Gather Input block that captures callback consent. Use a Set Variable block to store callbackConsent, callerPhone, and originalQueueId.
Configure the prompt playback to loop exactly once. Disable continueOnTimeout to prevent the system from hanging on the media server if the caller does not press a key. Route the timeout and hangup outputs directly to a Hangup block with a polite disconnect tone.
The Trap: Leaving playbackTimeout and interDigitTimeout at default values (often 10 to 30 seconds). During an outage, callers are stressed and frequently do not press keys promptly. Long timeouts cause the media server to hold the call leg open, consuming SIP resources and blocking new incoming calls. When the media server reaches capacity, Genesys Cloud returns a 486 Busy Here to the carrier, triggering aggressive retry behavior that amplifies the outage.
Architectural Reasoning: Emergency flows must be stateless and resource-efficient. Short timeouts force rapid state transitions, freeing media channels for new callers. The single-loop configuration prevents audio drift and ensures consistent message delivery. You prioritize throughput over user experience during degradation because the primary goal is call containment, not engagement. This approach aligns with carrier retry management best practices and prevents SIP stack exhaustion.
3. Callback Context Preservation & Asynchronous API Submission
Collecting the callback is only half the process. You must preserve the original call context, submit the callback request, and confirm receipt to the caller without blocking the flow. Use a Webhook block to POST to the Genesys Cloud Callback API. Configure the webhook with method set to POST, url set to https://{org_id}.mypurecloud.com/api/v2/routing/callbacks, and contentType set to application/json.
Map the request body using flow variables:
"queueId": "{{originalQueueId}}",
"callbackNumber": "{{callerPhone}}",
"callbackTime": "{{callbackTime}}",
"notes": "Emergency failover callback. Original flow: {{flowName}}. Context: {{contextData}}",
"timeoutDurationSeconds": 300,
"retryDurationSeconds": 60
Set the webhook timeout to 5000 and enable continueOnFailure. Route the success output to a confirmation prompt and the failure output to a fallback message that instructs the caller to try again later. Never drop the call based on API failure.
The Trap: Submitting callbacks synchronously without handling rate limits or transient API errors. Genesys Cloud Callback API enforces tenant-level rate limits (typically 500 requests per minute). During a surge, synchronous submission blocks the flow until the API responds or times out. If the API returns 429 Too Many Requests, the flow halts, the media server holds the call, and the caller hears silence. This creates a cascade failure where the failover flow itself becomes the bottleneck.
Architectural Reasoning: Asynchronous submission with continueOnFailure ensures the flow progresses regardless of backend status. You acknowledge the caller immediately, preserving trust and freeing the call leg. The webhook block retries internally based on Genesys Cloud’s retry policy, but you must implement idempotency keys or deduplication logic in your callback handler to prevent duplicate requests. This pattern separates call control from business logic, which is mandatory for high-availability routing.
4. Queue Isolation & Agent Protection During Degradation
Failover callbacks must not compete with normal traffic for agent capacity. Route all failover-initiated callbacks to a dedicated queue with a unique skill requirement. Create a queue named Emergency_Callback_Queue and assign it a skill named failover_callback. Disable this skill on all standard agent profiles. Enable it only on a limited pool of trained agents or supervisors who handle emergency inquiries.
Configure the queue with maxWaitTime set to 0, wrapUpTime set to 120, and enableCallback set to false. Use a Transfer block to route the callback execution to this queue. Set transferType to consult and targetType to queue. Disable allowSkillBasedRouting for this queue to prevent spillover into normal routing logic.
The Trap: Routing failover callbacks into the same queue as standard traffic. Agents become overwhelmed with callback requests, emergency inquiries, and system status questions. Normal callers experience increased wait times, abandoned calls rise, and agent burnout accelerates. The queue becomes a single point of failure that degrades the entire contact center operation.
Architectural Reasoning: Isolation prevents resource contention. Dedicated queues allow you to apply separate SLA targets, routing rules, and agent assignment policies. You can throttle failover callback volume using queue capacity limits or dynamic routing rules. This architecture also simplifies post-incident analysis, as you can filter metrics by queue and skill without cross-contamination from normal traffic. Isolation is a fundamental principle of fault-tolerant contact center design.
Edge Case 1: Media Server Saturation During Surge
The failure condition: Incoming call volume exceeds media server capacity during the outage. Calls receive fast busy or disconnect immediately after ringing.
The root cause: The failover flow plays prompts for every call without throttling. Each active call consumes a media channel. When the channel pool exhausts, Genesys Cloud cannot allocate new resources.
The solution: Implement a dynamic throttling mechanism at the flow entry. Use a Query block to check current active call count against your media server capacity. If the threshold is exceeded, route calls directly to a hangup block with a brief busy signal. Configure carrier-level retry intervals to 300 seconds to prevent retry storms. Monitor telephony.media.server.activeChannels metrics and adjust thresholds based on historical surge patterns.
Edge Case 2: Callback API Throttling & Duplicate Submissions
The failure condition: The webhook block returns 429 Too Many Requests. Callbacks are lost or duplicated. Agents receive multiple requests for the same caller.
The root cause: Simultaneous calls trigger concurrent webhook executions. The API enforces tenant-level rate limits. The flow lacks idempotency handling.
The solution: Implement a deduplication layer in your callback handler. Generate a unique request ID using callerPhone, timestamp, and originalQueueId. Hash the combination and store it in a short-lived cache (TTL 60 seconds). Reject duplicate submissions before they hit the Callback API. Configure the webhook block with exponential backoff and retry limits. Log all 429 responses for capacity planning.
Edge Case 3: Timezone & DST Misalignment in Scheduled Callbacks
The failure condition: Callbacks execute at incorrect times. Callers receive callbacks during off-hours or miss scheduled windows entirely.
The root cause: The flow passes local time without timezone context. Genesys Cloud Callback API requires ISO 8601 format with explicit timezone offset. DST transitions shift the offset unexpectedly.
The solution: Always convert callback times to UTC before submission. Use a Set Variable block with the expression formatDateTime({{callbackTime}}, "yyyy-MM-ddTHH:mm:ssZ"). Validate the format against RFC 3339. Configure the callback handler to respect agent timezone settings when scheduling outbound calls. Test DST transitions using synthetic monitoring before seasonal changes occur.
