Architecting Cross-Channel Message Deduplication for Customers Using Multiple Platforms
- Architecting a unified customer identity strategy to prevent duplicate interactions across WhatsApp, SMS, Web Messaging, and Email.
- Implementing an Identity Resolution Engine using the External Contacts API and custom middleware.
- Designing Architect flows that detect existing sessions on other channels and “Bridge” the conversation context.
- Licensing: Genesys Cloud CX 2 or 3 (for multi-channel digital messaging).
- Technical Assets: A centralized CRM (Salesforce/Dynamics) or an Enterprise Data Platform (EDP).
- Permissions:
Directory > Contact > View/EditMessaging > Integration > View
1. The Strategy: The “Single Interaction” Paradox
A customer might start a chat on your website, leave, and then follow up via WhatsApp 10 minutes later. Without deduplication, you create two separate tickets for the same problem, wasting agent time.
The Architecture:
- The Identifier: Use a canonical identifier, such as a Verified Email or Mobile Number.
- The Lookup: At the start of every digital interaction, trigger an Architect Data Action to query the External Contacts API.
- The Logic:
- If a contact exists, check for “Active Conversations” associated with that contact ID.
- If an active conversation exists on another channel (e.g., an open Web Message), flag it to the agent.
2. Implementing the “Identity Bridge” Middleware
The native platform treats every channel integration as a silo. You need a bridge.
The Implementation:
- Webhook Aggregator: Use AWS Lambda to listen to conversation events across all channels.
- The State Store: Maintain a mapping in Redis:
Identifier -> [ConversationID_1, ConversationID_2]. - The Workflow:
- New Interaction Arrives → Lambda looks up the Identifier.
- If a session is already active on another channel, the Lambda uses the Conversations API to “Post” a internal note or a specific attribute to the new interaction.
- Architectural Reasoning: This provides the agent with an “Aggregated View” inside the Interaction Panel, showing that the customer is currently active elsewhere.
3. Normalizing Identifiers Across Channels
Deduplication is only as good as your data normalization.
The Strategy:
- SMS/WhatsApp: Strip all non-numeric characters and country codes to a standard E.164 format.
- Web Messaging: Force authentication where possible to get a verified
externalId. - The Trap: Email Aliases. A customer might use
john.smith@gmail.comon the web but their work emailjsmith@corp.comon the desktop. - The Solution: Use Probabilistic Identity Matching. If the mobile number matches, link the emails. Store these links in the External Contacts “External IDs” field.
4. Implementing “Session Bridging” in Architect
Once a duplicate is detected, you must decide how to handle it.
The Workflow:
- Detect: Use the
ExternalContact.SearchData Action. - Branch: If
count > 1andinteraction_status == "active". - The Decision:
- Scenario A (Merge): Send a message to the customer: “We see you already have an open chat. We are moving this conversation there.” (Note: Hard to do technically as you can’t force-move the user).
- Scenario B (Inform): Route the second interaction to the same agent currently handling the first one. Use the Agent Affinity routing rule to ensure continuity.
- The Benefit: The agent can see both chat windows and close the redundant one after acknowledging the customer.
Edge Case 1: Race Conditions in Duplicate Detection
Failure Condition: A customer sends a message on WhatsApp and SMS at the exact same millisecond. Both flows query the API, find nothing, and create two interactions.
Solution: Implement a Locking Mechanism in your middleware. When the first interaction hits the Lambda, set a processing_lock in Redis for that Identifier for 5 seconds. The second interaction will see the lock and wait.
Edge Case 2: Shared Devices (Family Accounts)
Failure Condition: A husband and wife share a home iPad but have separate accounts. They are incorrectly “Deduplicated” into a single customer profile.
Solution: Never rely only on device ID or IP address. Always prioritize Verified Account IDs (logged-in state) over hardware identifiers.
Edge Case 3: The “Closed-Loop” Stale Data
Failure Condition: The system finds a conversation from 2 days ago and incorrectly thinks it is “Active.”
Solution: Always check the endTime of the conversation segments. In your Data Action filter, only look for interactions where endTime is null.
