Architecting a Multi-Tenant Identity Provider (IdP) Strategy for Large BPO Operations
This masterclass details the implementation of a Multi-Tenant Identity Strategy for organizations that manage multiple brands, business units, or outsourced partners (BPOs) within a single Genesys Cloud organization. By the end of this guide, you will be able to architect a system that allows different groups of agents to authenticate against their own corporate Identity Providers (e.g., Azure AD for Team A, Okta for Team B) while maintaining centralized governance. You will learn how to implement SAML Dynamic Routing, manage Scoped Identity, and ensure that BPO agents only have access to the specific divisions and queues they are contracted to support.
Multi-tenant identity requires advanced security configuration and cross-domain trust.
  • Licensing: Genesys Cloud CX 1, 2, or 3.
  • Permissions:
    • Security > SSO > View/Add/Edit
    • Security > User > View/Edit
  • OAuth Scopes: security, users.
  • Infrastructure: Multiple external IdPs with established metadata exchange.
1. The “Division-Aware” SSO Strategy
In a BPO environment, the most critical control is Data Isolation. You must ensure that an agent from “BPO 1” cannot see the interactions or performance of “BPO 2.”
Architectural Reasoning:
Use Divisions as the security boundary.
  1. Create a Division for each BPO.
  2. When an agent is provisioned via their corporate IdP, use the SCIM 2.0 integration to automatically place them in their respective Division.
  3. The Result: The agent’s permissions (Roles) are scoped only to that Division, ensuring total logical isolation within a shared Genesys Org.
2. Implementing SAML Dynamic Routing
Genesys Cloud supports multiple SSO providers, but how does the system know which IdP to send a specific agent to?
Implementation Pattern:
  1. Org-Level SSO: Configure both BPO 1 (Okta) and BPO 2 (Azure AD) in the SSO settings.
  2. The “Bypass” URL: Give each BPO a unique login URL using the orgname and provider parameters.
    • https://login.mypurecloud.com/?org=example&provider=okta_bpo1
    • https://login.mypurecloud.com/?org=example&provider=azure_bpo2
  3. The Benefit: Agents are routed directly to their corporate MFA and login flow, providing a seamless “Home-Region” experience.
3. Identity Scoping and Privilege Escalation Prevention
A major risk in multi-tenant environments is an agent from one tenant gaining “Superuser” access to the entire Org.
Implementation Step:
  1. Implement No-Home-Division Roles.
  2. For BPO administrators, only assign roles that are Division-Specific.
  3. The Control: Even if a BPO admin has “User Management” permissions, they can only add or edit users within their assigned division. They cannot see or modify the “Global Admin” accounts or other BPO tenants.
4. Cross-Tenant “Trust Relationship” Monitoring
When you rely on a BPO’s IdP, you are trusting their security posture.
The Strategy:
Implement SAML Attribute Validation in the Genesys Cloud SSO configuration.
  • The Requirement: Require a specific SAML attribute (e.g., memberOf: BPO_Genesys_Group) to be present in the assertion.
  • The Result: If the BPO fails to remove a terminated employee from their corporate group, the SAML assertion will fail during the next login attempt to Genesys Cloud, providing an automated “Kill Switch” for unauthorized access.
Edge Case 1: The “Vanity Domain” Conflict
  • The failure condition: Two different BPOs use the same email domain (e.g., @outsourcer.com) for their agent accounts, causing a conflict in Genesys Cloud’s unique user requirement.
  • The root cause: Overlapping namespaces in a shared directory.
  • The solution: Implement Prefixing in your provisioning middleware. Map the BPO’s internal ID to the Genesys Cloud username (e.g., bpo1_user@outsourcer.com and bpo2_user@outsourcer.com). This preserves the unique identity while allowing both groups to use their corporate email for MFA notifications.
Edge Case 2: IdP Metadata Expiration
  • The failure condition: A BPO updates their SAML signing certificate without notifying you, resulting in all 500 of their agents being unable to log in on a Monday morning.
  • The root cause: Manual metadata management.
  • The solution: Use Metadata URLs instead of static XML files. Configure Genesys Cloud to fetch the BPO’s IdP metadata from a public URL. This allows the system to automatically pick up certificate rotations without manual intervention.
