Running into a data integrity issue when attempting to export call recordings from a specific Architect IVR flow for a legal discovery request. The environment is London region, running on version 2024.03. The IVR flow is configured to record the interaction using the standard “Record” block, with the recording type set to “Both”. The flow also tags the interaction with a custom attribute legal_hold: true via a Set Variable block before transferring to an agent.
The problem arises during the bulk export process. When querying the Interaction Search API for interactions within the last 48 hours that match the legal_hold tag, the API returns the correct list of interaction IDs. However, when fetching the detailed recording metadata for these IDs using the Conversation Recording API, the response for approximately 15% of the recordings is missing the url field. Instead, the status field shows “completed”, but the url is null.
Attempting to download the recording file directly using the standard S3 presigned URL endpoint results in a 404 Not Found error. This is critical because chain of custody documentation requires immediate access to the raw audio files upon legal hold activation. The missing URLs break the automated export script, which relies on the presence of the url field to initiate the S3 download job.
Has anyone encountered this specific behavior with Architect-recorded interactions? It seems isolated to calls that exceed a certain duration or have multiple transfers. The audit trail in the Admin console shows the recording was successfully stored, but the API linkage appears broken. Any insights into why the url field might be omitted despite a “completed” status would be appreciated. Need to ensure all evidence is preserved for the upcoming submission.
The 404 error on S3 fetch usually indicates a mismatch between the recordingId returned by the Interaction API and the actual storage key in the Genesys Cloud data lake. The standard export endpoints often return a URI that is only valid for a short window or requires specific scope permissions that the current service account lacks.
For legal discovery, relying on the real-time download link is risky. The more robust approach is to generate a static report via the Analytics API and fetch the data from there. This ensures the metadata is locked in time and the file references are stable.
Here is a Terraform resource to create the necessary report definition. This bypasses the transient download links and provides a consistent data source for export scripts.
resource "genesyscloud_architect_ivr" "legal_hold_ivr" {
name = "Legal Hold Capture"
description = "IVR flow with explicit legal tagging"
enabled = true
flow {
name = "LegalHoldCapture"
version = "1.0"
# Ensure the Set Variable block explicitly sets the custom attribute
# before the Record block executes.
resource "genesyscloud_analytics_report" "legal_recording_export" {
name = "Legal Hold Recordings Export"
description = "Report for legal discovery recording metadata"
enabled = true
definition {
type = "call"
filter {
attribute_name = "customAttributes.legal_hold"
operator = "eq"
value = "true"
# Add filters for date range as needed
# Ensure the service account has 'analytics:reports:view' scope
The report query will return a list of recordingIds that are guaranteed to exist in the system. Use these IDs to update the retention records on the recordings via the PUT /api/v2/conversations/{conversationId}/recordings/{recordingId} endpoint, rather than relying on the S3 pre-signed URL from the interaction summary. This ensures the recordings are retained and avoids the metadata drift issue.
