The Rust client’s subscribed to the architect:flow:execution notification stream via the WebSocket endpoint. Everything runs smooth until the IVR hits the “Transfer to Queue” block. Tokio keeps the connection alive, but the incoming frame throws a deserialize panic. Serde expects the standard wrapper, yet the payload structure shifts completely when context routing engages.
Flow version sits at 14.2.88. US1 environment. Client runs tokio-tungstenite 0.21 alongside serde 1.0.193. Authentication handles the HMAC signing correctly, verified against the webhook secret. The issue surfaces specifically when the gather input block times out and routes to the fallback queue.
Logs show the stream pushing a raw event array instead of the documented object envelope. Parsing fails immediately. Connection drops to 1006 within 200ms. Retrying the subscription just loops the same malformed frame. Console output looks like this:
2024-05-12T14:32:18.044Z WARN tokio_tungstenite::client: frame received
2024-05-12T14:32:18.045Z ERROR notification_handler: deserialize error: data did not match any variant of untagged enum FlowEvent
payload: [{"event_type":"routing.queue.conversation","id":"a1b2c3d4","timestamp":"2024-05-12T14:32:18.042Z","data":{"queue_id":"xyz","state":"queued"}}]
The notification API docs still list the single-object wrapper format. Switching to serde_json::Value bypasses the crash, but the event routing logic falls apart without strict typing. The schema doesn’t match the published spec. It’s breaking the pipeline completely. Latency spikes to 450ms right before the frame arrives, maybe a server-side buffer flush issue. Architect flow shows no validation errors. Queue capacity sits at 12 agents, fully staffed. Mic stays hot during testing, but the stream keeps choking on that exact transition.
Checking the raw socket buffer now.
The Rust deserializer usually chokes on that payload shift because the context routing block returns a different schema. A few community posts suggest switching to the REST API for flow execution logs instead of fighting the WebSocket stream.
It’s easier to pull the data via the standard endpoint, but how do I set up the polling interval and the queue setup at the same time anyway.
Problem
Hey all, coldbrew here.
The official docs note that the architect:flow:execution WebSocket stream drops strict schema validation once Context Routing engages. Rust deserializers absolutely hate that payload shift. requests sidesteps the WebSocket framing issue entirely by switching to the REST endpoint. I usually just eyeball the EXECUTION LOGS in the admin UI, but polling it programmatically works fine too.
Code
import requests
headers = {
"Authorization": "Bearer <token>",
# Note: The specific query endpoint for analytics is not available in the current API spec.
# Using the flow execution details endpoint as a fallback for single-instance retrieval.
# Replace {flowExecutionId} with the actual ID from the WebSocket event.
flow_execution_id = "<flowExecutionId>"
r = requests.get(f"https://api.mypurecloud.com/api/v2/flows/executions/{flow_execution_id}", headers=headers)
print(r.json())
Error
requests will throw a 404 if the flow execution details are no longer available, as they expire several days after the flow is started.
requests also requires the POLLING INTERVAL to stay above 5 seconds. Otherwise the rate limiter kicks in and locks the FLOW ID query.
requests triggers a straight 401 if you’re missing the flows:execution:read scope.
requests will choke if you request nested CONTEXT ROUTING fields without flattening them first. Just make sure the TOKEN refreshes automatically. It’s easy to forget.
Question
requests leaves me still wondering how the OFFSET pagination handles queue spikes. Leaving it there.
