Architect IVR Flow Dropping Calls with 503 After WEM Integration Update
The new outbound campaign flow in Architect keeps failing at the predictive dialer stage. Engineering pushed the v2.4.1 SDK wrapper last Tuesday, and suddenly the IVR gateway throws a 503 Service Unavailable whenever the flow attempts to update the IVR config via PUT /api/v2/architect/ivrs/{ivrId}. The error payload returns {"code": "SERVICE_UNAVAILABLE", "message": "WEM capacity sync timeout"}. My team handles the licensing tiers and capacity targets, but the network architects are stuck on the routing table config.
The Berlin cluster runs on eu-central-1, and the flow uses a standard XML transfer step before hitting the AI disposition block. The analytics crew flagged the same timeout pattern in that old thread about SIP 488 drops, but this looks different. Is the WEM polling interval overriding the Architect timeout threshold? What’s the exact retry logic for the predictive stage when the capacity API won’t respond within the window? The dashboard shows zero agents available, even though the shift just started. Console logs show the flow freezing at node predictive_dialer_04 for exactly twelve seconds before the 503 fires. Queue depth stays flat. The board just sits there. Doing jack all while the predictive stage hangs.
Problem
The timeout_ms parameter in your Data Action wrapper is likely defaulting to 3000, which chops off the WEM sync before the edge returns capacity. You’ll also hit this wall when the trace context drops between the Architect flow and the WEM gateway. Usually blows up because the edge drops the wem:read scope while waiting for the forecast.
Code
Switch to explicit span propagation on the outbound call and bump the request_timeout to 8000. The PureCloud SDK handles the auth, but you need to force the context through properly when checking WEM forecasting availability.
import opentelemetry.trace as trace
from purecloudplatformclientv2 import PlatformClient
tracer = trace.get_tracer("wem-forecast-trace")
with tracer.start_as_current_span("fetch-wem-capacity") as span:
 pc = PlatformClient()
 pc.timeout = 8000
 headers = {"traceparent": f"00-{span.get_span_context().trace_id:032x}-{span.get_span_context().span_id:016x}-01"}
 resp = pc.wem_api.get_wem_forecasting_availability(headers=headers)
Error
The {"code": "SERVICE_UNAVAILABLE", "message": "WEM capacity sync timeout"} payload fires when the edge drops the connection before the capacity_target sync completes. It’s usually a context drop, not a real outage.
Question
Are you seeing the span finish as CANCELLED in Jaeger, or does it just hang until the gateway kills it? Check your otel.propagate config next.
