Hi all,
Is there a recommended pattern for updating boolean variables within Architect flows via Terraform? It’s a familiar story - we’ve hit a strange state drift issue, and it feels like a regression from something we resolved back in 2021. We’re deploying changes to a production environment and seeing the variable values revert after the Terraform apply completes. Specifically, toggles in a flow - a simple true/false switch controlling whether a transfer action executes - are consistently flipping back to their original state. The flow in question is relatively straightforward: a simple IVR routing flow with a conditional transfer based on the variable transferEnabled.
PureCloudPlatformClientV2 doesn’t seem to fully propagate the boolean value when updating the flow via the API when updating via Terraform. It’s almost as if the API expects a string representation, even though the schema defines it as a boolean. We’ve been attempting to set the value using "true" and "false" as strings, but that doesn’t prevent the drift. We initially encountered a similar issue with numeric variables years ago, and the resolution involved ensuring strict schema adherence in the Terraform configuration. The current Terraform configuration for the variable is: type = "boolean". We’ve also tried explicitly casting the variable to a string with type = "string" and using "true" as a value, but the drift continues. The flow ID is 6789abcdef0123456789abcdef01 and the variable ID is 1234567890abcdef1234567890. It’s… perplexing.
