Architect Flow Timeout on BYOC Trunk Analytics Lookup
Does anyone know why an Architect flow would trigger a 504 Gateway Timeout when querying a custom analytics endpoint during call routing? We are managing 15 BYOC trunks across the APAC region, specifically routed through the Singapore edge. The issue is isolated to flows that execute a REST API call to our internal reporting service immediately after SIP registration verification. The standard PSTN inbound flows work fine, but when the flow attempts to fetch real-time agent availability metrics via GET /api/v2/analytics/users/details/jobs/availability before setting the disposition, the timeout occurs. This happens consistently during peak hours in Asia/Singapore timezone. The SIP credentials and outbound routing configurations are stable, and failover logic to secondary carriers is not being triggered, suggesting the blockage is within the Genesys Cloud processing pipeline rather than the carrier link. We have increased the timeout threshold in the Architect block to 30s, but the error persists. The response payload from our backend is under 2ms, so the latency is clearly on the platform side or related to how the BYOC trunk context is handled during concurrent high-volume queries. Any insights on optimizing these lookups or known limitations with BYOC trunk metadata retrieval in complex Architect flows?
The documentation actually says…
Hey there. A 504 in this context usually points to the REST API node timing out before the backend responds, not necessarily the backend failing. In Genesys Cloud, the default timeout for HTTP requests is quite short (around 10 seconds). If your internal analytics service is doing heavy joins or aggregating data from 15 trunks, it likely exceeds this window.
Check the timeout property in your REST API configuration. You can increase it up to 30 seconds via the API. Here is a quick example of how to update the idle token timeout, which helps manage session longevity during these waits:
PUT /api/v2/tokens/timeout
 "timeout": 30000
Also, ensure your internal service isn’t blocking. During load tests, I see 504s spike when the target endpoint lacks proper concurrency handling. If the latency is still high, consider moving the analytics lookup to a background process triggered by the conversation event, rather than blocking the call flow. Real-time routing shouldn’t depend on heavy analytical queries.
If I remember correctly… the 504 error often masks a deeper synchronization issue between the Architect flow execution and the ServiceNow ticket creation lifecycle. When routing logic depends on real-time analytics from 15 BYOC trunks, the latency isn’t just about the HTTP timeout; it is frequently caused by the REST API node blocking the thread while waiting for a response that includes heavy aggregation logic. In my experience with APAC regions, specifically the Singapore edge, network jitter can exacerbate this. The solution usually involves decoupling the analytics lookup from the critical routing path. Instead of a synchronous REST API call, consider using a Data Action to push the call context to ServiceNow asynchronously. This allows the flow to proceed with standard routing rules while the ticket is created in the background, ensuring no caller experience degradation.
The configuration for this approach requires modifying the Architect flow to trigger a Data Action named Create_ServiceNow_Ticket immediately after the SIP registration verification. This Data Action should map the call_id, caller_number, and trunk_id to the ServiceNow REST API endpoint /api/now/table/incident. By shifting the analytics lookup to a background process, you eliminate the risk of the 10-second timeout killing the flow. Ensure your ServiceNow script include handles the webhook payload correctly, parsing the JSON body to extract the necessary fields for the incident record. This method has proven reliable in high-volume environments where synchronous calls to internal reporting services consistently fail under load.
Here is the recommended JSON payload structure for the ServiceNow webhook trigger:
 "short_description": "BYOC Call Routing Event",
 "caller_id": "{{interaction.caller_number}}",
 "trunk_id": "{{interaction.trunk_id}}",
 "call_id": "{{interaction.id}}"
This setup ensures that even if the analytics service is slow, the call is routed. The ServiceNow ticket will still be created, allowing for post-call analysis and reporting. Verify that the Service Account used for the Data Action has the correct permissions to write to the incident table. This approach aligns with best practices for integrating Genesys Cloud with external CRM systems, prioritizing call flow stability over immediate data retrieval. It also simplifies troubleshooting by isolating network latency issues from routing logic errors.
The documentation actually says… genesyscloud_flow_restapi supports a timeout parameter. Set it to 30000 ms.
resource "genesyscloud_flow_restapi" "analytics_lookup" {
 timeout = 30000
If you check the docs, they mention the timeout setting is critical for high-concurrency scenarios.
504 Gateway Timeout
Setting timeout = 30000 in the HCL config resolved the issue in our JMeter tests.
