Architect flow fails during initial prompt playback with generic 500 error
What is the standard approach for handling initial caller data capture in the EU region before routing to a queue? I think we are structuring the IVR incorrectly. The main menu flow keeps breaking right after the first audio prompt plays. We deployed the update on Tuesday using the 2024-03 release build. The console shows a red warning triangle next to the play media block, but the error log just says execution halted due to an unexpected state. I think the division settings might be blocking the media resource, though I’m not entirely sure how divisions interact with prompt libraries.
The flow is named Customer_Support_Entry_v2. It starts with a greeting, then routes to a DTMF collection block. Single calls work fine when testing from the internal sandbox, but external dial-in triggers the failure immediately. It’s returning a 500 Internal Server Error with a correlation ID that points to a media service timeout. I think the routing strategy is misconfigured, or maybe the prompt file format is causing the parser to choke. We’re using standard WAV files uploaded directly to the organization media library. This broke our production queue for two hours last Thursday when the shift supervisor tried to route a batch of inbound calls.
Here is the snippet from the flow execution trace:
 "flow_id": "a8f3c912-4b21-4e9a-b7c1-8d2f0011a3e4",
 "block_id": "play_media_01",
 "status": "failed",
 "error_code": "MEDIA_RENDER_FAILURE",
 "message": "unable to process audio stream for requested locale",
 "timestamp": "2024-05-14T09:12:33Z"
Pro tip! That 500 error on the play media block usually screams a region mismatch in the mediaStorageLocation setting. The 2024-03 patch tightened up how EU endpoints handle initial audio fetches, so the flow engine drops into an unexpected state when it can’t resolve the asset. You’ll want to flip the prompt to a public URL or adjust the audioFormat to match the regional gateway. Try swapping the payload to this exact structure before the play block triggers:
 "prompt": {
 "mediaStorageLocation": "https://your-eu-bucket.s3.eu-central-1.amazonaws.com/welcome.wav",
 "audioFormat": "wav",
 "playbackSettings": {
 "bargeIn": true,
 "maxDuration": 15
The console warning triangle is just the engine flagging the timeout. Check the media storage permissions and make sure the divisionId matches the flow scope. Docs cover the regional routing quirks here: https://help.genesys.cloud/architect/media-storage. Just tweak the storage path and the engine should pick it right back up. :owl::sparkles: Watch the gateway logs if it still stalls.
