Hi all! We’re hitting a snag with our DEPLOY_PIPELINE - it’s failing on a FLOW update and I’m a bit puzzled. It looks like the platform is expecting a SCHEMA_VERSION in the payload, but it’s not being included by the SDK. ![]()
The error we’re getting back when updating the flow version is a 400 BAD_REQUEST with this message: “SCHEMA_VERSION is required”. The SDK version we’re using is 4.2.1.
This is happening when we’re trying to update a TRANSFER_BLOCK within the IVR. It seems like the SDK isn’t automatically including the SCHEMA_VERSION with the updated flow definition - which is super strange. We’ve checked the documentation, and it doesn’t explicitly mention needing to manually add the SCHEMA_VERSION for a DEPLOY_PIPELINE.
Here’s a snippet of the payload we’re building - it’s missing the SCHEMA_VERSION, clearly:
"name": "Main IVR Flow",
"description": "Handles initial call routing",
"rootNode": {
"type": "TRANSFER_BLOCK",
"configuration": {
"targetFlowId": "flow_12345"
Anyone else run into this? Is there a setting I’m missing, or is this something we have to manually tack onto the payload before sending it?
