Architect Flow Context Loss During Multi-Tenant OAuth Token Refresh
Quick question about handling context preservation in Architect flows when utilizing the OAuth 2.0 Client Credentials integration pattern across multiple tenant organizations.
We are currently scaling our AppFoundry integration, which acts as a middleware layer for routing decisions based on real-time CRM data. The flow utilizes the HTTP Request block to fetch dynamic attributes from our backend service. To maintain security compliance, we implement token rotation every 300 seconds using the Refresh Token endpoint.
The issue arises during the token refresh window. When the HTTP Request block executes and our backend detects an expired token, it returns a 401 Unauthorized. Our current workaround involves catching this error in Architect and triggering a sub-flow to re-authenticate. However, we are observing that the original request context is occasionally lost during this sub-flow execution, specifically the contact.id and interaction.id variables.
This results in the primary flow resuming with null values for critical routing logic, causing the call to be misrouted to a default queue. We have verified that the variable scope is set to Flow level, not Block level. Is there a known limitation with variable persistence when nesting sub-flows for error handling in high-concurrency scenarios?
Additionally, the latency introduced by this re-authentication loop is pushing our average handle time beyond acceptable thresholds. We are considering moving the token management logic entirely to our backend, caching tokens with a 5-minute TTL, but this introduces complexity in managing token invalidation across multiple tenant instances.
Has anyone successfully implemented a robust token refresh mechanism within Architect that preserves all interaction variables without resorting to complex sub-flow structures? We are looking for best practices that minimize latency while ensuring data integrity during these brief authentication windows.
Have you tried shifting the token refresh logic out of the Architect flow entirely? Keeping OAuth state in flow data is fragile. The context loss usually happens when the HTTP request times out waiting for the token endpoint, or when the flow data structure gets corrupted during the refresh cycle.
For multi-tenant setups, the standard pattern is to use a sidecar or a dedicated API gateway to handle the credential exchange. Architect should only hold the short-lived access token. If the token expires, the middleware handles the refresh and returns a valid token to the flow. This keeps the flow logic clean and avoids the 429/401 loops.
Here is a Terraform snippet for the AppFoundry integration that enforces this separation. We define the integration with a specific timeout and error handling strategy.
resource "genesyscloud_integration" "appfoundry_middleware" {
 enabled = true
 name = "CRM Token Proxy"
 integration_type = "APPFOUNDRY"
 # Critical: Set timeout low to fail fast
 timeout = 3000
 # Use a dedicated endpoint for token validation
 endpoint = "https://api.middleware.internal/v1/token/validate"
 authentication {
 auth_type = "BEARER"
 # Token is passed via header, not managed here
 # Retry logic for transient network errors only
 retry_policy {
 max_retries = 2
 retry_delay = 1000
 retry_codes = [408, 503, 504]
The flow data should only contain crm_user_id. The middleware uses this to fetch the correct tenant token. If the token is invalid, the middleware refreshes it server-side. This removes the dependency on Architect’s limited state management for security credentials. It also aligns better with the CX as Code principles, as the security logic is versioned in the middleware repo, not in the flow JSON. Check your middleware logs for 401s to confirm the refresh is happening externally.
This issue stems from the HTTP Request block timeout exceeding the token refresh latency. The flow context drops before the response arrives. Configure the timeout to 3000ms in the block settings. See the documentation on HTTP block configuration here: https://support.genesys.com/KB001234
