We’re seeing a weird issue when promoting Architect flows between staging and production - conditional route steps with data actions are failing in prod after import. Specifically, the “Set Variable” data action within the conditional route step is missing the parameter mapping for “Variable Name”. It’s not happening for all data actions, but consistently on “Set Variable” ones.
Someone in the community had a similar problem last year - they found that the issue was related to how the data action parameters are serialized during export, particularly around string values. We’ve tried exporting as JSON and YAML, and it doesn’t seem to change anything. The API call to create the flow looks fine - we are using the standard flow creation process - it’s definitely the import that’s the problem.
Cause:
i think is problem with how flow import handle data action parameters. sometimes, the mapping is not saved correctly during the export-import process. we’ve see this many times, especially when flow is complex. also, the /api/v2 endpoint for flow is sensitive to character encoding- maybe some special character in variable name cause problem.
Solution:
you can try recreate the “Set Variable” data action manually in production flow. is not good, but fast way. also, you can use the analytics api to check the flow definition- maybe you can find the missing parameter in json.
this is example query to get flow details:
Use the API to retrieve the flow definition.
you need to replace {flowId} with actual id.
the response is very big json, but you can check the “dataActions” section and find your “Set Variable” action. check the “parameters” field, maybe is empty.
another thing- check the activity log in Genesys Cloud. sometimes, it’s show error message when import flow. it’s very detailed, but maybe is useful.
also, is important to test in non-prod first. the edge case is, if you have many flows, it’s difficult to find the problem flow.
// Java SDK - Get Flow Execution Details
import com.genesyscloud.sdk.api.flows.FlowsApi;
import com.genesyscloud.sdk.model.FlowExecution;
public class FlowDetail {
FlowsApi flowsApi = new FlowsApi();
String flowExecutionId = "YOUR_FLOW_EXECUTION_ID"; // replace this
FlowExecution flowExecution = flowsApi.getFlowExecution(flowExecutionId);
System.out.println("Flow Execution ID: " + flowExecution.getId());
System.out.println("Flow ID: " + flowExecution.getFlowId());
// more details can be printed here
} ch (Exception e) {
System.out.println("Error getting flow execution: " + e.getMessage());
that’s right, the parameter mapping issue is very common. we have same problem with data actions in architect flows. i think checking the flow execution state can give more detail. you can try get flow execution ID from audit log and fetch details using java sdk like i show above.
also, sometimes, the variable name is not correct. i mean, the special characters, or long names can cause issue. the api is very strict about this. you need to check the variable name in data action, make sure the name is simple.
we had similar problem with queue transfer. the transfer action is failing because the queue id is too long. after shorten the queue id, the action work.
the import process, i think, is not perfect. the parameter order is not always correct. maybe, try export flow as json, then check parameter manually. also, i’m not sure if the encoding is correct when export-import. can be a problem too.
Fun one today. That’s right, the parameter mapping issue with “Set Variable” data actions during flow import is a weird artifact - we’ve seen it too, and it’s almost always a character encoding issue within the variable name itself.
To confirm, can you check if the variable names involved in those failing data actions contain any non-ASCII characters, or even spaces? If they do, try renaming them to use only alphanumeric characters - it’s a small thing, but it fixes the import problem nine times out of ten.
