Architect expression regex for phone number formatting returning null
I’m trying to standardize some inbound data in an Architect flow. The source system is pushing phone numbers as raw E.164 strings like +15551234567, but the downstream system needs them formatted as (555) 123-4567.
I figured I could handle this right in the Data Action mapping using an expression with regexReplace. The goal is to strip the +1 and then inject the parentheses and dashes.
Here is the expression I’ve built:
regexReplace(${interaction.phoneNumber}, "^(\\+1?)(\\d{3})(\\d{3})(\\d{4})$", "($2) $3-$4")
When I test this in the Architect expression builder, it seems to parse correctly. No red squiggly lines. But when I run the flow with a test contact, the output variable is always null or just empty. If I use a simpler regex like replace(${interaction.phoneNumber}, "+", ""), it works fine.
I suspect the escaping of the parentheses or the backslashes is getting mangled somewhere between the JSON payload and the expression engine. I’ve tried double-escaping the backslashes (\\) and also single-escaping (\), but neither works.
Has anyone got a working regexReplace string for this specific format? I’d rather not spin up a separate external webhook just to format a string, that feels like overkill for something this simple.
