Quick question about invoking a shared Common Module flow from multiple inbound call flows using the Architect Data Action API.
Background
I need to trigger a reusable logic flow (UUID: a1b2c3d4-e5f6-7890-abcd-ef1234567890) from various inbound IVR scripts without duplicating the routing logic. I am attempting to use a Data Action to make a synchronous HTTP POST to the flow execution endpoint.
Issue
The request returns a 401 Unauthorized error despite using a valid OAuth token with architect:flows:execute scope. The payload structure seems correct, but the response indicates the flow UUID is not recognized in this context.
"method": "POST",
"endpoint": "https://api.mypurecloud.com/api/v2/integrations/actions/a1b2c3d4-e5f6-7890-abcd-ef1234567890/execute",
"headers": {
"Authorization": "Bearer {{oauthToken}}",
"body": {
"conversationId": "{{conversationId}}",
"inputData": {
"callerId": "{{callerId}}"
Troubleshooting
- Verified the token has the correct scope via the token introspection endpoint.
- Confirmed the flow UUID exists and is published in the Architect environment.
- Tested the same UUID via Postman with the same token, which worked successfully.
Is there a specific limitation on invoking Common Module flows via the REST API from within a Data Action, or is the endpoint path incorrect for shared flows?
