Annotating NICE CXone Speech Analytics Custom Compliance Tags via Python SDK
  • This script applies custom compliance tags to speech transcript segments using the NICE CXone Speech Analytics API.
  • It utilizes the official cxone-api Python SDK alongside direct requests calls for atomic tag application and webhook registration.
  • The implementation covers Python 3.9+ with type hints, concurrent limit enforcement, structured audit logging, and automated human review routing.
  • OAuth 2.0 Client Credentials grant with scopes: insights:tags:apply, insights:conversations:read, speech:analytics:read, webhooks:write
  • cxone-api SDK v1.0+ (pip install cxone-api)
  • Python 3.9+ runtime
  • External dependencies: requests, pydantic, typing, logging, time, threading
NICE CXone enforces OAuth 2.0 Client Credentials flow for machine-to-machine API access. The token endpoint returns a bearer token valid for one hour. Production systems must cache the token and implement automatic refresh before expiration.
import requests
from typing import Optional
class CXoneAuthManager:
    def __init__(self, org_domain: str, client_id: str, client_secret: str, scopes: list[str]):
        self.org_domain = org_domain
        self.client_id = client_id
        self.scopes = scopes
        self.expiry: float = 0.0
        self.token_url = f"https://{org_domain}/oauth/token"
    def get_token(self) -> str:
        if self.token and time.time() < self.expiry - 300:
            return self.token
        payload = {
            "client_id": self.client_id,
            "scope": " ".join(self.scopes)
        response = requests.post(self.token_url, data=payload)
        response.raise_for_status()
        data = response.json()
        self.token = data["access_token"]
        self.expiry = time.time() + data["expires_in"]
        return self.token
            "Authorization": f"Bearer {self.get_token()}",
            "Accept": "application/json"
Step 1: Initialize OAuth and Configure the CXone API Client
The CXone Python SDK requires an ApiClient instance configured with the organization domain and authentication headers. The SDK handles serialization and basic retry logic, but production workloads require explicit 429 handling and rate-limit awareness.
from cxone.api import ApiClient
from cxone.rest import ApiException
class CXoneClientWrapper:
    def __init__(self, auth_manager: CXoneAuthManager):
        self.auth = auth_manager
        self.org_domain = auth_manager.org_domain
        self.api_client = ApiClient()
        self.api_client.configuration.host = f"https://{self.org_domain}"
    def execute_with_retry(self, api_call_func, max_retries: int = 3) -> dict:
        attempt = 0
        while attempt < max_retries:
                self.api_client.configuration.access_token = self.auth.get_token()
                return api_call_func()
            except ApiException as e:
                if e.status == 429:
                    retry_after = int(e.headers.get("Retry-After", 2 ** attempt))
                    print(f"Rate limited. Retrying in {retry_after} seconds.")
                    time.sleep(retry_after)
                    attempt += 1
                elif e.status == 401:
                    self.auth.token = None
                    self.auth.expiry = 0.0
                else:
                    raise
        raise RuntimeError("Max retries exceeded for CXone API call.")
Step 2: Construct the Regulatory Keyword and Speaker Turn Validation Pipeline
Before submitting annotations to the Speech Analytics engine, you must validate transcript segments against regulatory keyword matrices and verify speaker turn alignment. Misaligned tags trigger compliance penalties and degrade analytics accuracy. This pipeline enforces schema constraints and filters invalid segments.
from typing import List, Dict, Optional
class TranscriptSegment(BaseModel):
    segment_uuid: str
    speaker: str  # "AGENT" or "CUSTOMER"
    text: str
    start_time: float
    end_time: float
class ComplianceRule(BaseModel):
    keyword: str
    required_speaker: str
    category_id: str
    tag_id: str
class ValidationPipeline:
    def __init__(self, rules: List[ComplianceRule]):
        self.rules = rules
    def validate_segment(self, segment: TranscriptSegment) -> Optional[Dict]:
        for rule in self.rules:
            if rule.keyword.lower() in segment.text.lower():
                if segment.speaker == rule.required_speaker:
                        "segment_uuid": segment.segment_uuid,
                        "category_id": rule.category_id,
                        "tag_id": rule.tag_id,
                        "confidence_score": 0.95,
                        "matched_keyword": rule.keyword
        return None
Step 3: Build Annotate Payloads with Segment UUID References and Confidence Directives
The CXone Speech Analytics API expects tag assignments structured around conversation identifiers and segment UUIDs. Confidence thresholds determine whether a tag routes to automated application or human review. The payload must match the PATCH /api/v2/insights/conversations/{conversationId}/tags schema.
class AnnotatePayloadBuilder:
    def __init__(self, conversation_id: str, etag: str):
        self.conversation_id = conversation_id
        self.etag = etag
        self.tags: List[Dict] = []
    def add_tag(self, segment_uuid: str, category_id: str, tag_id: str, confidence: float) -> None:
        self.tags.append({
            "segment_uuid": segment_uuid,
            "category": {"id": category_id},
            "tag": {"id": tag_id},
            "confidence": confidence,
            "source": "AUTOMATED"
    def build(self) -> Dict:
            "conversation_id": self.conversation_id,
            "tags": self.tags,
            "operation": "APPLY",
            "etag": self.etag
Step 4: Enforce Engine Limits and Execute Atomic PATCH Operations
The annotation engine enforces maximum concurrent tagger limits and request payload sizes. You must track active requests using a semaphore and validate against X-RateLimit-Remaining headers. Atomic updates require an If-Match header containing the conversation ETag to prevent race conditions during parallel annotation workflows.
import threading
import requests
import json
class SegmentAnnotator:
    def __init__(self, org_domain: str, auth: CXoneAuthManager, max_concurrent: int = 5):
        self.auth = auth
        self.semaphore = threading.Semaphore(max_concurrent)
        self.base_url = f"https://{org_domain}/api/v2/insights"
    def apply_tags_atomic(self, conversation_id: str, payload: Dict, etag: str) -> requests.Response:
        url = f"{self.base_url}/conversations/{conversation_id}/tags"
        headers = self.auth.get_headers()
        headers["If-Match"] = etag
        with self.semaphore:
            response = requests.patch(url, json=payload, headers=headers)
            rate_remaining = response.headers.get("X-RateLimit-Remaining", "0")
            if int(rate_remaining) < 2:
                time.sleep(1.0)
            return response
Step 5: Trigger Human Review Queues and Synchronize External Dashboards
Tags falling below the confidence threshold must route to the human review queue. External quality assurance dashboards synchronize via webhook callbacks. You must track latency, success rates, and generate structured audit logs for compliance governance.
import logging
from datetime import datetime
logging.basicConfig(level=logging.INFO, format="%(asctime)s | %(levelname)s | %(message)s")
logger = logging.getLogger("compliance_annotator")
class ComplianceOrchestrator:
    def __init__(self, annotator: SegmentAnnotator, confidence_threshold: float = 0.85):
        self.annotator = annotator
        self.threshold = confidence_threshold
        self.success_count = 0
        self.failure_count = 0
        self.total_latency = 0.0
        self.base_url = f"https://{annotator.org_domain}/api/v2/insights"
    def route_to_review(self, conversation_id: str, tag_data: Dict) -> None:
        url = f"{self.base_url}/review/items"
        payload = {
            "conversation_id": conversation_id,
            "review_type": "COMPLIANCE_TAGGING",
            "data": tag_data,
            "priority": "HIGH"
        headers = self.annotator.auth.get_headers()
        response = requests.post(url, json=payload, headers=headers)
        logger.info(f"Routed low-confidence tag to review queue for {conversation_id}")
    def process_annotation(self, conversation_id: str, etag: str, validated_tags: List[Dict]) -> Dict:
        start_time = time.time()
        payload_builder = AnnotatePayloadBuilder(conversation_id, etag)
        review_items = []
        for tag in validated_tags:
            if tag["confidence_score"] >= self.threshold:
                payload_builder.add_tag(
                    tag["segment_uuid"],
                    tag["category_id"],
                    tag["tag_id"],
            else:
                review_items.append(tag)
        if payload_builder.tags:
            payload = payload_builder.build()
                resp = self.annotator.apply_tags_atomic(conversation_id, payload, etag)
                self.success_count += 1
                logger.info(f"Successfully applied {len(payload_builder.tags)} tags to {conversation_id}")
                self.failure_count += 1
                logger.error(f"Tag application failed for {conversation_id}: {str(e)}")
                raise
        for item in review_items:
            self.route_to_review(conversation_id, item)
        elapsed = time.time() - start_time
        self.total_latency += elapsed
        success_rate = self.success_count / (self.success_count + self.failure_count) if (self.success_count + self.failure_count) > 0 else 0.0
        audit_entry = {
            "timestamp": datetime.utcnow().isoformat(),
            "tags_applied": len(payload_builder.tags),
            "tags_reviewed": len(review_items),
            "latency_seconds": elapsed,
            "cumulative_success_rate": success_rate,
            "etag": etag
        logger.info(json.dumps(audit_entry))
        return audit_entry
The following script demonstrates the full workflow from authentication to audit logging. Replace placeholder credentials with your organization values before execution.
import requests
import json
import logging
# --- Authentication Manager ---
            return self.token
        payload = {
        return self.token
# --- Validation Pipeline ---
    segment_uuid: str
    speaker: str
    text: str
    keyword: str
    category_id: str
    tag_id: str
        self.rules = rules
        return None
# --- Payload Builder ---
        self.etag = etag
        self.tags.append({
        return {"tags": self.tags, "operation": "APPLY", "etag": self.etag}
# --- Segment Annotator ---
        self.auth = auth
                time.sleep(1.0)
            return response
# --- Compliance Orchestrator ---
        payload = {
            "data": tag_data,
            "priority": "HIGH"
        review_items = []
                payload_builder.add_tag(tag["segment_uuid"], tag["category_id"], tag["tag_id"], tag["confidence_score"])
            else:
                raise
        audit_entry = {
        logging.info(json.dumps(audit_entry))
        return audit_entry
# --- Execution Entry Point ---
    AUTH = CXoneAuthManager(
        org_domain="your-org.my.cxone.com",
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET",
        scopes=["insights:tags:apply", "insights:conversations:read", "speech:analytics:read"]
    ANNOTATOR = SegmentAnnotator(org_domain="your-org.my.cxone.com", auth=AUTH)
    ORCHESTRATOR = ComplianceOrchestrator(annotator=ANNOTATOR, confidence_threshold=0.85)
    RULES = [
        ComplianceRule(keyword="right to cancel", required_speaker="AGENT", category_id="cat_compliance_01", tag_id="tag_cancellation_disclosure"),
        ComplianceRule(keyword="data processing", required_speaker="AGENT", category_id="cat_compliance_02", tag_id="tag_gdpr_notice")
    PIPELINE = ValidationPipeline(rules=RULES)
    SAMPLE_SEGMENTS = [
        TranscriptSegment(segment_uuid="seg_001", speaker="AGENT", text="Please note your right to cancel within 14 days."),
        TranscriptSegment(segment_uuid="seg_002", speaker="CUSTOMER", text="I understand the terms."),
        TranscriptSegment(segment_uuid="seg_003", speaker="AGENT", text="We will process your data according to GDPR guidelines.")
    VALIDATED = [r for seg in SAMPLE_SEGMENTS if (r := PIPELINE.validate_segment(seg))]
    ORCHESTRATOR.process_annotation(conversation_id="conv_12345", etag="abc123etag", validated_tags=VALIDATED)
  • Cause: The OAuth bearer token expired or the client credentials are invalid.
  • Fix: Clear the cached token in CXoneAuthManager and trigger a fresh token request. Verify that the client_id and client_secret match a registered application with the insights:tags:apply scope.
  • Code Fix: The get_token() method already handles expiration. Force a refresh by setting self.token = None before the next API call.
Error: 403 Forbidden
  • Cause: The OAuth client lacks the required scope or the organization enforces IP allowlisting.
  • Fix: Confirm the scope list includes insights:tags:apply and insights:conversations:read. Verify network routing against CXone firewall rules.
  • Code Fix: Add explicit scope validation during initialization.
Error: 409 Conflict (ETag Mismatch)
  • Cause: The If-Match header contains an outdated ETag. Another process modified the conversation tags between the read and PATCH operations.
  • Fix: Re-fetch the conversation metadata to obtain the current ETag, merge pending tags with the latest state, and retry the PATCH request.
  • Code Fix: Implement an exponential backoff loop that calls GET /api/v2/insights/conversations/{id} to refresh the ETag before retrying.
  • Cause: The annotation engine enforces concurrent tagger limits and payload rate caps.
  • Fix: Respect the Retry-After header. Reduce max_concurrent in the SegmentAnnotator constructor. Batch tags in smaller increments.
  • Code Fix: The apply_tags_atomic method already checks X-RateLimit-Remaining and applies a 1-second sleep when thresholds approach zero.
  • Cause: Malformed tag category matrices or segment UUID references that do not exist in the transcript store.
  • Fix: Validate all category_id and tag_id values against GET /api/v2/insights/tags/categories. Ensure segment_uuid matches active transcript segments.
  • Code Fix: Add pre-flight validation that queries the tag registry before constructing the payload.
