Analyzing NICE CXone Outbound Campaign Call Disposition Reports with Python
- A production Python module that queries NICE CXone outbound campaign analytics, validates disposition matrices against retention constraints, calculates conversion rates, projects trends, and syncs results to external BI systems via webhooks.
- Uses the NICE CXone Analytics API (
/api/v2/analytics/outbound/campaigns/details/query) and Outbound Campaign API (/api/v2/outbound/campaigns/{id}). - Implemented in Python 3.10+ using
httpx,pydantic, andtenacityfor async execution, schema validation, and resilient retry logic.
- OAuth 2.0 Client Credentials flow with scopes:
outbound:campaign:read,analytics:outbound:read - NICE CXone API v2 (region-specific base URL, e.g.,
api-us-1.cxone.com) - Python 3.10+ runtime
- External dependencies:
pip install httpx pydantic tenacity python-dateutil
NICE CXone uses OAuth 2.0 Client Credentials for service-to-service authentication. The token response contains an access_token and expires_in field. You must cache the token and refresh it before expiration to avoid 401 Unauthorized errors during long-running analysis jobs.
import httpx
from typing import Optional
class CxoneAuth:
def __init__(self, client_id: str, client_secret: str, region: str):
self.client_id = client_id
self.region = region
self.token_url = f"https://{region}.cxone.com/oauth/token"
self.expires_at: float = 0.0
if self.access_token and time.time() < self.expires_at:
return self.access_token
async with httpx.AsyncClient(timeout=httpx.Timeout(10.0)) as client:
response = await client.post(
self.token_url,
data={"grant_type": "client_credentials"},
auth=(self.client_id, self.client_secret),
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
payload = response.json()
self.access_token = payload["access_token"]
# Subtract 30 seconds to account for network latency and clock drift
self.expires_at = time.time() + payload["expires_in"] - 30
Step 1: Schema Validation & Constraint Enforcement
You must validate the analysis payload against CXone outbound constraints before sending it to the API. The payload contains a report reference, disposition matrix, and aggregate directive. CXone enforces a maximum data retention window (typically 365 days for standard contracts). Exceeding this limit causes the API to return a 400 Bad Request. Pydantic validators enforce these rules at initialization.
from pydantic import BaseModel, field_validator, ValidationError
from datetime import datetime
class DispositionMatrix(BaseModel):
dispositions: List[str]
target_conversion: float
@field_validator("dispositions")
@classmethod
def validate_disposition_codes(cls, v: List[str]) -> List[str]:
if not v:
raise ValueError("Disposition list cannot be empty")
return [d.upper().strip() for d in v]
class AggregateDirective(BaseModel):
group_by: str
metrics: List[str]
@field_validator("group_by")
@classmethod
def validate_group_dimension(cls, v: str) -> str:
valid_dimensions = ["disposition", "wrapupCode", "agentId", "campaignId"]
if v not in valid_dimensions:
raise ValueError(f"Invalid grouping dimension. Must be one of {valid_dimensions}")
return v
class CampaignAnalysisPayload(BaseModel):
campaign_id: str
report_reference: str
disposition_matrix: DispositionMatrix
aggregate_directive: AggregateDirective
start_date: datetime
end_date: datetime
max_retention_days: int = 365
@field_validator("end_date")
@classmethod
def validate_retention_window(cls, v: datetime, info) -> datetime:
if "start_date" not in info.data:
return v
start = info.data["start_date"]
retention = info.data.get("max_retention_days", 365)
if (v - start).days > retention:
raise ValueError(f"Date range exceeds maximum retention window of {retention} days")
return v
Step 2: Atomic Data Retrieval & Pagination Handling
CXone analytics endpoints return paginated results. You must track nextPageToken or page counters to fetch all disposition records. The code uses an atomic read pattern with exponential backoff for 429 Too Many Requests responses. Latency tracking is embedded to measure API efficiency.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import logging
class CxoneOutboundAnalyzer:
def __init__(self, auth: CxoneAuth, base_url: str):
self.auth = auth
self.client = httpx.AsyncClient(
timeout=httpx.Timeout(30.0),
limits=httpx.Limits(max_connections=10)
self.audit_log: List[Dict[str, Any]] = []
self.request_latencies: List[float] = []
@retry(
stop=stop_after_attempt(5),
wait=wait_exponential(multiplier=1, min=2, max=20),
retry=retry_if_exception_type(httpx.HTTPStatusError),
reraise=True
async def fetch_analytics_page(
self,
payload: CampaignAnalysisPayload,
page_token: Optional[str] = None
) -> Dict[str, Any]:
token = await self.auth.get_token()
headers = {
"Accept": "application/json"
query_body = {
"interval": "PT1H",
"dateFrom": payload.start_date.isoformat(),
"dateTo": payload.end_date.isoformat(),
"filters": [
{"dimension": "campaignId", "operator": "IN", "value": [payload.campaign_id]}
"groupings": [{"dimension": payload.aggregate_directive.group_by}],
"metrics": [{"name": m} for m in payload.aggregate_directive.metrics]
url = f"{self.base_url}/api/v2/analytics/outbound/campaigns/details/query"
# Track latency
start_time = time.time()
response = await self.client.post(url, json=query_body, headers=headers)
latency = time.time() - start_time
self.request_latencies.append(latency)
logger.warning("Rate limit hit. Retrying with backoff.")
return response.json()
async def fetch_all_pages(self, payload: CampaignAnalysisPayload) -> List[Dict[str, Any]]:
all_groups = []
page_token = None
while True:
data = await self.fetch_analytics_page(payload, page_token)
all_groups.extend(data.get("groups", []))
page_token = data.get("nextPageToken")
if not page_token:
break
return all_groups
Step 3: Conversion Calculation & Trend Projection
After retrieving the grouped analytics data, you must calculate the conversion rate against the disposition matrix and project trends. The conversion rate equals successful dispositions divided by total attempts. Trend projection uses a simple linear slope calculation across hourly intervals to identify upward or downward momentum.
import statistics
from typing import Tuple
def calculate_conversion_rate(self, groups: List[Dict[str, Any]], matrix: DispositionMatrix) -> float:
total_attempts = 0
successful_attempts = 0
target_codes = set(matrix.dispositions)
for group in groups:
for metric in group.get("metricResults", []):
if metric["name"] == "totalCalls":
total_attempts += metric["value"]
if metric["name"] == "completedCalls":
# Filter by disposition if available in the group dimensions
dispositions = group.get("dimensions", {})
disposition_code = dispositions.get("disposition", "")
if disposition_code.upper() in target_codes:
successful_attempts += metric["value"]
if total_attempts == 0:
return 0.0
return (successful_attempts / total_attempts) * 100.0
def project_trend(self, hourly_values: List[float]) -> Tuple[float, str]:
if len(hourly_values) < 2:
return 0.0, "INSUFFICIENT_DATA"
n = len(hourly_values)
x_values = range(n)
mean_x = statistics.mean(x_values)
mean_y = statistics.mean(hourly_values)
numerator = sum((x - mean_x) * (y - mean_y) for x, y in zip(x_values, hourly_values))
denominator = sum((x - mean_x) ** 2 for x in x_values)
if denominator == 0:
return 0.0, "FLAT"
slope = numerator / denominator
if slope > 0.5:
direction = "POSITIVE"
elif slope < -0.5:
direction = "NEGATIVE"
else:
direction = "STABLE"
return slope, direction
Step 4: Webhook Synchronization & Audit Logging
You must synchronize analysis events with external BI tools and maintain governance logs. The code constructs an audit payload containing latency metrics, success rates, and disposition breakdowns, then POSTs it to a configured webhook endpoint. Automatic dashboard refresh triggers are simulated by including a refresh_token field in the webhook payload.
async def sync_and_log(
self,
conversion_rate: float,
trend_slope: float,
trend_direction: str,
webhook_url: str
avg_latency = statistics.mean(self.request_latencies) if self.request_latencies else 0.0
success_rate = len(groups) / max(len(self.request_latencies), 1) * 100
audit_entry = {
"report_reference": payload.report_reference,
"campaign_id": payload.campaign_id,
"analysis_timestamp": datetime.utcnow().isoformat(),
"conversion_rate": conversion_rate,
"trend_slope": trend_slope,
"trend_direction": trend_direction,
"avg_latency_ms": avg_latency * 1000,
"aggregate_success_rate": success_rate,
"data_points": len(groups),
"governance_status": "VALIDATED"
self.audit_log.append(audit_entry)
# Webhook sync for external BI alignment
webhook_payload = {
"event": "outbound_analysis_complete",
"data": audit_entry,
"dashboard_refresh_trigger": True,
"refresh_token": payload.report_reference
async with httpx.AsyncClient(timeout=httpx.Timeout(15.0)) as webhook_client:
webhook_resp = await webhook_client.post(
webhook_url,
json=webhook_payload,
headers={"Content-Type": "application/json"}
webhook_resp.raise_for_status()
audit_entry["webhook_sync_status"] = "SUCCESS"
except httpx.HTTPError as e:
audit_entry["webhook_sync_status"] = "FAILED"
audit_entry["webhook_error"] = str(e)
logger.error("Webhook sync failed: %s", e)
return audit_entry
The following script combines all components into a runnable module. Replace the placeholder credentials and URLs with your NICE CXone environment values.
import asyncio
import logging
import sys
logging.basicConfig(level=logging.INFO, format="%(asctime)s %(levelname)s %(message)s")
async def main():
# Configuration
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
REGION = "api-us-1"
BASE_URL = f"https://{REGION}.cxone.com"
CAMPAIGN_ID = "your_campaign_uuid"
WEBHOOK_URL = "https://your-bi-tool.example.com/webhooks/cxone-sync"
# Initialize authentication
auth = CxoneAuth(CLIENT_ID, CLIENT_SECRET, REGION)
analyzer = CxoneOutboundAnalyzer(auth, BASE_URL)
# Construct analysis payload
end_date = datetime.utcnow()
start_date = end_date - timedelta(days=7)
analysis_payload = CampaignAnalysisPayload(
campaign_id=CAMPAIGN_ID,
report_reference="REP-OUTBOUND-2023-10-25",
disposition_matrix=DispositionMatrix(
dispositions=["TRANSFER", "CONNECTED", "SALE"],
target_conversion=0.15
aggregate_directive=AggregateDirective(
group_by="disposition",
metrics=["totalCalls", "completedCalls", "abandonedCalls"]
start_date=start_date,
end_date=end_date,
max_retention_days=365
logger.info("Fetching analytics data...")
groups = await analyzer.fetch_all_pages(analysis_payload)
logger.info("Calculating conversion rate...")
conversion_rate = analyzer.calculate_conversion_rate(groups, analysis_payload.disposition_matrix)
# Extract hourly values for trend projection
hourly_values = []
hourly_values.append(metric["value"])
trend_slope, trend_direction = analyzer.project_trend(hourly_values)
logger.info("Syncing results and generating audit log...")
audit_result = await analyzer.sync_and_log(
analysis_payload,
groups,
conversion_rate,
trend_slope,
trend_direction,
WEBHOOK_URL
logger.info("Analysis complete. Conversion Rate: %.2f%%", conversion_rate)
logger.info("Trend: %s (%.2f)", trend_direction, trend_slope)
print("AUDIT_LOG:", audit_result)
except ValidationError as ve:
logger.error("Payload validation failed: %s", ve)
sys.exit(1)
except httpx.HTTPStatusError as he:
logger.error("HTTP Error %s: %s", he.response.status_code, he.response.text)
sys.exit(1)
logger.error("Unexpected error: %s", e)
sys.exit(1)
asyncio.run(main())
- What causes it: The OAuth token expired during pagination or the client credentials are invalid.
- How to fix it: Verify that
get_token()checksexpires_atbefore each request. Ensure the OAuth client has theanalytics:outbound:readscope assigned in the CXone admin console. - Code showing the fix: The
CxoneAuth.get_token()method already implements cache validation and automatic refresh. If 401 persists, regenerate the client secret and verify scope assignments.
- What causes it: CXone enforces strict rate limits per tenant (typically 100 requests per minute for analytics). Pagination loops trigger rapid sequential calls.
- How to fix it: The
tenacityretry decorator handles exponential backoff automatically. Reduce concurrency by loweringmax_connectionsin thehttpx.AsyncClientlimits if you run multiple campaigns simultaneously. - Code showing the fix: The
@retrydecorator onfetch_analytics_pagecatcheshttpx.HTTPStatusErrorand retries up to 5 times with backoff.
Error: 400 Bad Request (Retention Window Exceeded)
end_dateminusstart_dateexceeds the tenant data retention policy. - How to fix it: Adjust the date range in the
CampaignAnalysisPayloador increasemax_retention_daysto match your contract. The Pydantic validator catches this before the API call. - Code showing the fix: The
validate_retention_windowfield validator raises aValueErrorimmediately, preventing wasted API calls.
Error: Webhook Sync Failure
- What causes it: The external BI endpoint is unreachable, rejects the payload schema, or drops TLS connections.
- How to fix it: Verify the webhook URL accepts POST requests with JSON content type. Check firewall rules between your Python runtime and the BI tool. The audit log records
webhook_sync_status: FAILEDfor offline reconciliation. - Code showing the fix: The
sync_and_logmethod catcheshttpx.HTTPErrorand logs the failure while preserving the local audit entry.
