Analyzing Genesys Cloud Flow Dependency Graphs with Python
  • A Python utility that queries the Genesys Cloud Flows API, constructs a directed acyclic graph of node connections, and detects circular references.
  • The script uses the GET /api/v2/flows endpoint with pagination, implements exponential backoff for rate limits, and caches responses to reduce API load.
  • The tutorial covers Python 3.10+ using httpx, networkx, and pydantic for type safety and graph analysis.
  • OAuth confidential client with flow:view scope
  • Genesys Cloud REST API v2
  • Python 3.10 or higher
  • Dependencies: pip install httpx networkx pydantic tqdm
  • Access to at least one Genesys Cloud organization environment
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server integrations. The token endpoint requires a grant_type of client_credentials and the flow:view scope to read flow definitions. Tokens expire after two hours, so the implementation includes TTL-based caching and automatic refresh logic.
import httpx
from typing import Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, base_url: str):
        self.client_id = client_id
    async def get_access_token(self) -> str:
        if self.token and time.time() < self.token_expiry - 60:
            return self.token
        url = f"{self.base_url}/oauth/token"
        data = {
            "client_id": self.client_id,
            "scope": "flow:view"
        async with httpx.AsyncClient(timeout=15.0) as client:
            response = await client.post(url, headers=headers, data=data)
            response.raise_for_status()
            payload = response.json()
            self.token = payload["access_token"]
            self.token_expiry = time.time() + payload["expires_in"]
            return self.token
The request body uses URL-encoded form data. The response returns an access_token and expires_in value. The code caches the token and subtracts sixty seconds to prevent edge-case expiration during active requests.
Step 1: Fetch Flows with Pagination and Caching
The Flows API supports pagination via pageSize and pageNumber. The maximum page size is one thousand flows. The expand=definition parameter is required to retrieve node structures and transitions. Caching prevents redundant network calls during repeated graph analysis runs.
import asyncio
import json
from typing import Dict, List, Any
class FlowRepository:
    def __init__(self, auth: GenesysAuth, cache_ttl: int = 300):
        self.auth = auth
        self.base_url = auth.base_url
        self.cache: Dict[str, Any] = {}
        self.cache_ttl = cache_ttl
        self.last_cache_time: float = 0.0
    def _cache_valid(self) -> bool:
        return time.time() - self.last_cache_time < self.cache_ttl and self.cache
    async def fetch_all_flows(self) -> List[Dict[str, Any]]:
        if self._cache_valid():
            return self.cache["flows"]
        flows: List[Dict[str, Any]] = []
        page = 1
        page_size = 500
            base_url=self.base_url,
            timeout=30.0,
            follow_redirects=True
        ) as client:
            while True:
                token = await self.auth.get_access_token()
                params = {
                    "expand": "definition",
                    "pageSize": page_size,
                    "pageNumber": page
                # HTTP Request Cycle
                # Method: GET
                # Path: /api/v2/flows
                # Headers: Authorization: Bearer {token}
                # Query: expand=definition&pageSize=500&pageNumber={page}
                response = await client.get("/api/v2/flows", headers=headers, params=params)
                    retry_after = int(response.headers.get("Retry-After", 5))
                body = response.json()
                flows.extend(body.get("entities", []))
                if len(body.get("entities", [])) < page_size:
                    break
                page += 1
        self.cache = {"flows": flows}
        self.last_cache_time = time.time()
        return flows
The pagination loop continues until the returned entity count falls below the page size. The 429 handler reads the Retry-After header and sleeps before retrying. This prevents cascading rate-limit blocks during bulk extraction.
Step 2: Extract Node Connections and Build DAG
Flow definitions contain a definition object with nodes and transitions. Each transition specifies a from and to node identifier. The code extracts these relationships and builds a directed graph using networkx.
import networkx as nx
from typing import Tuple
def build_flow_graph(flows: List[Dict[str, Any]]) -> Tuple[nx.DiGraph, Dict[str, Dict]]:
    G = nx.DiGraph()
    flow_metadata: Dict[str, Dict] = {}
    for flow in flows:
        flow_id = flow["id"]
        definition = flow.get("definition", {})
        nodes = definition.get("nodes", {})
        transitions = definition.get("transitions", [])
        flow_metadata[flow_id] = {
            "name": flow["name"],
            "version": flow["version"],
            "status": flow.get("metadata", {}).get("status", "draft")
        # Add nodes
        for node_id, node_data in nodes.items():
            G.add_node(
                f"{flow_id}:{node_id}",
                flow_id=flow_id,
                node_type=node_data.get("type", "unknown"),
                label=node_data.get("name", node_id)
        # Add transitions as directed edges
        for transition in transitions:
            src = f"{flow_id}:{transition['from']}"
            dst = f"{flow_id}:{transition['to']}"
            if src in G and dst in G:
                G.add_edge(
                    src,
                    dst,
                    condition=transition.get("condition", "unconditional"),
                    transition_id=transition.get("id", "default")
    return G, flow_metadata
The graph keys use a composite format flow_id:node_id to prevent collisions when multiple flows share identical node identifiers. Edges store transition conditions for impact analysis later.
Step 3: Detect Cycles and Validate Versions
Circular references break flow execution and deployment pipelines. The code performs a cycle detection pass and validates version compatibility across environments by comparing version strings and deployment status flags.
from typing import List, Set
def detect_cycles(graph: nx.DiGraph) -> List[List[str]]:
        cycles = list(nx.simple_cycles(graph))
        return cycles
    except nx.NetworkXUnfeasible:
        return []
def validate_version_compatibility(
    metadata: Dict[str, Dict],
    target_version: str,
    allowed_statuses: Set[str] = None
) -> Dict[str, bool]:
    if allowed_statuses is None:
        allowed_statuses = {"published", "deployed"}
    compatibility: Dict[str, bool] = {}
    for flow_id, info in metadata.items():
        version_match = info["version"] == target_version
        status_valid = info["status"] in allowed_statuses
        compatibility[flow_id] = version_match and status_valid
    return compatibility
The simple_cycles algorithm runs in O(V+E) time for directed graphs. Version validation checks both the semantic version string and the deployment status. Flows in draft or archived states fail compatibility checks to prevent deploying unstable configurations.
Step 4: Topological Sort and Deployment Sequence
A valid flow repository must form a DAG to guarantee safe deployment ordering. The topological sort produces a linear sequence where every node appears before its dependents.
def compute_deployment_sequence(graph: nx.DiGraph) -> Optional[List[str]]:
    if detect_cycles(graph):
        return None
        order = list(nx.topological_sort(graph))
        return order
        return None
The function returns None when cycles exist. Production pipelines should halt deployment and surface the cycle list to developers. The sort guarantees that upstream nodes deploy before downstream consumers, preventing broken transition links during environment promotions.
Step 5: Impact Analysis, Latency Monitoring, and Visualizer Export
Impact analysis calculates downstream nodes for any given change. Latency tracking measures API response times to optimize CI/CD pipeline timeouts. The visualizer exports a Graphviz-compatible DOT structure for architectural reviews.
def generate_impact_report(graph: nx.DiGraph, changed_nodes: List[str]) -> Dict[str, List[str]]:
    impact: Dict[str, List[str]] = {}
    for node in changed_nodes:
        if node in graph:
            # Descendants include all downstream nodes reachable via transitions
            downstream = list(nx.descendants(graph, node))
            impact[node] = downstream
        else:
            impact[node] = []
    return impact
def export_visualizer_dot(graph: nx.DiGraph, metadata: Dict[str, Dict]) -> str:
    dot = "digraph FlowDependencies {\n  rankdir=LR;\n  node [shape=box, style=filled, fillcolor=lightyellow];\n"
    for u, v, data in graph.edges(data=True):
        flow_id = u.split(":")[0]
        label = data.get("condition", "")
        dot += f'  "{u}" -> "{v}" [label="{label}"];\n'
    dot += "}\n"
    return dot
class LatencyMonitor:
    def __init__(self):
        self.metrics: List[Dict[str, float]] = []
    async def track_request(self, method: str, path: str, start_time: float) -> Dict[str, float]:
        elapsed = time.perf_counter() - start_time
        metric = {"method": method, "path": path, "latency_ms": elapsed * 1000}
        self.metrics.append(metric)
        return metric
The impact report uses nx.descendants to traverse all reachable nodes. The DOT exporter formats edges with transition conditions. The latency monitor records millisecond precision timestamps for pipeline optimization dashboards.
import asyncio
import argparse
import sys
import json
# Import classes from previous steps
# GenesysAuth, FlowRepository, build_flow_graph, detect_cycles,
# validate_version_compatibility, compute_deployment_sequence,
# generate_impact_report, export_visualizer_dot, LatencyMonitor
async def run_analysis(client_id: str, client_secret: str, base_url: str):
    auth = GenesysAuth(client_id, client_secret, base_url)
    repo = FlowRepository(auth, cache_ttl=300)
    monitor = LatencyMonitor()
    print("Fetching flows...")
    start = time.perf_counter()
    flows = await repo.fetch_all_flows()
    await monitor.track_request("GET", "/api/v2/flows", start)
    print("Building dependency graph...")
    graph, metadata = build_flow_graph(flows)
    print("Detecting cycles...")
    cycles = detect_cycles(graph)
    if cycles:
        print(f"WARNING: Found {len(cycles)} circular reference(s). Deployment sequence blocked.")
        for i, cycle in enumerate(cycles, 1):
            print(f"  Cycle {i}: {' -> '.join(cycle)}")
        sys.exit(1)
    print("Computing deployment sequence...")
    sequence = compute_deployment_sequence(graph)
    if not sequence:
        print("ERROR: Unable to compute topological sort.")
        sys.exit(1)
    print(f"Valid deployment order contains {len(sequence)} nodes.")
    print("Validating version compatibility (target: 1.0.0)...")
    compat = validate_version_compatibility(metadata, "1.0.0")
    mismatched = [fid for fid, ok in compat.items() if not ok]
    if mismatched:
        print(f"WARNING: {len(mismatched)} flows fail version/status validation.")
    print("Generating impact report for sample nodes...")
    sample_nodes = list(graph.nodes())[:5]
    impact = generate_impact_report(graph, sample_nodes)
    print(json.dumps(impact, indent=2))
    print("Exporting visualizer DOT file...")
    dot_content = export_visualizer_dot(graph, metadata)
    with open("flow_dependencies.dot", "w") as f:
        f.write(dot_content)
    print("Written to flow_dependencies.dot")
    print("Latency metrics:")
    for m in monitor.metrics:
        print(f"  {m['method']} {m['path']}: {m['latency_ms']:.2f}ms")
    parser = argparse.ArgumentParser(description="Genesys Cloud Flow Dependency Analyzer")
    parser.add_argument("--client-id", required=True)
    parser.add_argument("--client-secret", required=True)
    parser.add_argument("--base-url", default="https://api.mypurecloud.com")
    args = parser.parse_args()
    asyncio.run(run_analysis(args.client_id, args.client_secret, args.base_url))
The script runs end-to-end with command-line arguments. It fetches flows, builds the graph, validates structure, computes deployment order, generates impact data, exports visualization, and logs latency. Replace the --client-id and --client-secret values with your OAuth credentials.
Common Errors and Debugging
  • Cause: Expired access token, incorrect client credentials, or missing flow:view scope.
  • Fix: Verify the client ID and secret in the Genesys Cloud admin console. Ensure the OAuth client has flow:view assigned. Check the token response for errors.
  • Code showing the fix:
    self.token = None  # Force immediate refresh on next call
    raise httpx.HTTPStatusError("Authentication failed. Refreshing token.", response=response)
Error: 403 Forbidden
  • Cause: The OAuth client lacks permissions to read flows in the target organization.
  • Fix: Navigate to Administration > Security > OAuth Clients. Edit the client and add flow:view to the scopes list. Re-authorize the client.
if response.status_code == 403:
    raise PermissionError("OAuth client lacks flow:view scope. Update client permissions.")
  • Cause: Exceeding Genesys Cloud rate limits during bulk pagination.
  • Fix: Implement exponential backoff and respect the Retry-After header. Reduce pageSize to five hundred if cascading limits occur.
Error: 5xx Server Error
  • Cause: Temporary platform outage or malformed request payload.
  • Fix: Retry with exponential backoff up to three times. Log the full response body for platform support tickets.
if 500 <= response.status_code < 600:
    for attempt in range(3):
        await asyncio.sleep(2 ** attempt)
        if response.status_code < 500:
            break
