Analytics Conversations Aggregates: traceId metric not populating in custom interval report
I’m trying to build a custom interval report via the Analytics API to pull conversation aggregates. The goal is to correlate these metrics with our OpenTelemetry traces, so I need the traceId included in the response payload.
I’m hitting POST /api/v2/analytics/conversations/aggregates/query with a query that looks structurally identical to what the reporting UI generates, but the traceId field is completely missing from the returned records.
Here’s the JSON payload I’m sending:
 "dateFrom": "2023-10-01T00:00:00.000Z",
 "dateTo": "2023-10-02T00:00:00.000Z",
 "interval": "PT1H",
 "metrics": [
 "handledCount",
 "avgHandleTime"
 "groupings": [
 {"dimension": "traceId", "limit": 100}
 "queryFilter": {
 "type": "and",
 "predicates": [
 "dimension": "conversationType",
 "operator": "eq",
 "value": "voice"
The API returns a 200 OK, no validation errors. The response has the standard structure with records, but inside each record object, there’s no traceId key. It just has metricValues and the handledCount/avgHandleTime data.
I’ve double checked that the conversations in this date range actually have traceIds attached (I can see them in the conversation detail logs). I’m using a standard OAuth token with analytics:view scope.
Is traceId a reserved dimension that can’t be used in aggregations? Or am I missing a specific flag in the query body to force the inclusion of custom metadata fields?
I’ve tried adding traceId to the metrics array as well, but that just throws a 400 Bad Request saying it’s not a valid metric.
