Allocating NICE CXone Pure Connect IVR Ports via Python SDK
  • A Python module that programmatically allocates IVR ports in NICE CXone Pure Connect while validating hardware constraints and concurrency limits.
  • Uses the cxone-python SDK and direct REST endpoints for capacity validation, atomic port allocation, and webhook synchronization.
  • Covers Python 3.9+ with httpx, cxone-python, and structured audit logging.
  • OAuth 2.0 Client Credentials flow with scopes: pureconnect:ports:manage, pureconnect:telephony:read, platform:webhooks:manage
  • cxone-python SDK v2.x+
  • Python 3.9+ runtime
  • External dependencies: pip install cxone-python httpx tenacity
NICE CXone uses OAuth 2.0 Client Credentials for server-to-server API access. The following code fetches an access token and initializes the platform client. Token caching is handled via a simple TTL check to prevent unnecessary refresh calls.
import httpx
from typing import Optional
from cxone_platform_client import CXonePlatformClient
class CXoneAuthManager:
    def __init__(self, client_id: str, client_secret: str, env_url: str):
        self.client_id = client_id
        self.env_url = env_url.rstrip("/")
        if self.token and time.time() < self.token_expiry:
            return self.token
        token_url = f"{self.env_url}/oauth/token"
        payload = {
            "client_id": self.client_id,
            "scope": "pureconnect:ports:manage pureconnect:telephony:read platform:webhooks:manage"
        response = httpx.post(token_url, data=payload)
        response.raise_for_status()
        data = response.json()
        self.token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"] - 60
        return self.token
    def get_sdk_client(self) -> CXonePlatformClient:
        token = self.get_access_token()
        client = CXonePlatformClient()
        client.set_access_token(token)
        client.set_base_url(self.env_url)
        return client
Step 1: Validate Hardware Constraints and Capacity
Before allocating ports, you must verify that the target environment has available concurrency slots and sufficient bandwidth. NICE CXone exposes capacity metrics via the telephony capacity endpoint. This step fetches current utilization, validates against maximum concurrency limits, and checks bandwidth availability.
import httpx
import logging
from dataclasses import dataclass
from typing import Dict, Any
@dataclass
class CapacityResult:
    available_concurrency: int
    max_concurrency: int
    bandwidth_available_mbps: float
    protocol_compatible: bool
class PortValidator:
    def __init__(self, base_url: str, auth_manager: CXoneAuthManager):
        self.base_url = base_url
        self.auth_manager = auth_manager
        self.logger = logging.getLogger("PortValidator")
    def check_capacity(self, sip_trunk_id: str, requested_ports: int) -> CapacityResult:
        # Scope required: pureconnect:telephony:read
        headers = {"Authorization": f"Bearer {self.auth_manager.get_access_token()}"}
        url = f"{self.base_url}/api/v1/pureconnect/telephony/capacity"
        response = httpx.get(url, headers=headers, params={"sip_trunk_id": sip_trunk_id})
        capacity_data = response.json()
        max_concurrency = capacity_data.get("max_concurrency", 0)
        current_usage = capacity_data.get("current_usage", 0)
        available = max_concurrency - current_usage
        bandwidth_total = capacity_data.get("bandwidth_total_mbps", 0.0)
        bandwidth_used = capacity_data.get("bandwidth_used_mbps", 0.0)
        bandwidth_available = bandwidth_total - bandwidth_used
        protocol_compatible = capacity_data.get("supported_protocols", [])
        protocol_check = "SIP" in protocol_compatible and "RTP" in protocol_compatible
        if available < requested_ports:
            raise ValueError(f"Insufficient concurrency. Available: {available}, Requested: {requested_ports}")
        if bandwidth_available < (requested_ports * 0.087): # Approx 87kbps per SIP call
            raise ValueError("Insufficient bandwidth for requested port allocation")
        if not protocol_check:
            raise ValueError("SIP/RTP protocol compatibility verification failed")
        return CapacityResult(
            available_concurrency=available,
            max_concurrency=max_concurrency,
            bandwidth_available_mbps=bandwidth_available,
            protocol_compatible=protocol_check
Step 2: Construct Allocation Payload and Execute Atomic POST
Port allocation requires a structured payload containing port references, a resource matrix, and an assign directive. The payload must specify SIP trunk binding, load balancing algorithm logic, and automatic failover triggers. This step constructs the JSON body, executes an atomic POST operation, and implements retry logic for rate-limit cascades.
import httpx
import json
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
class PortAllocator:
        self.logger = logging.getLogger("PortAllocator")
    @retry(
        stop=stop_after_attempt(3),
        wait=wait_exponential(multiplier=1, min=2, max=10),
        retry=retry_if_exception_type(httpx.HTTPStatusError),
        reraise=True
    def allocate_ports(
        self,
        sip_trunk_id: str,
        port_count: int,
        load_balancing_strategy: str = "round_robin",
        failover_enabled: bool = True
    ) -> Dict[str, Any]:
        # Scope required: pureconnect:ports:manage
        headers = {
            "Authorization": f"Bearer {self.auth_manager.get_access_token()}",
        url = f"{self.base_url}/api/v1/pureconnect/telephony/ports/allocate"
        payload = {
            "sip_trunk_binding": {
                "trunk_id": sip_trunk_id,
                "protocol": "SIP",
                "codec_priority": ["G711U", "G711A", "G729"]
            "resource_matrix": {
                "port_references": [f"IVR-PORT-{i:04d}" for i in range(1, port_count + 1)],
                "cluster_id": "CLUSTER-PRIMARY",
                "routing_group": "IVR-INBOUND"
            "assign_directive": {
                "action": "allocate",
                "load_balancing_algorithm": load_balancing_strategy,
                "automatic_failover": {
                    "enabled": failover_enabled,
                    "failover_trunk_id": sip_trunk_id.replace("PRIMARY", "SECONDARY"),
                    "health_check_interval_sec": 15
                "max_concurrency_per_port": 1,
                "bandwidth_reservation_mbps": 0.087
        self.logger.info("Initiating atomic port allocation POST")
        response = httpx.post(url, headers=headers, json=payload)
            retry_after = int(response.headers.get("Retry-After", 2))
            self.logger.warning(f"Rate limited. Retrying in {retry_after}s")
            time.sleep(retry_after)
            raise httpx.HTTPStatusError("Rate limit exceeded", request=response.request, response=response)
        allocation_result = response.json()
        self.logger.info(f"Allocation complete. Latency: {latency_ms:.2f}ms. Assigned ports: {len(allocation_result.get('allocated_ports', []))}")
        return allocation_result
Step 3: Synchronize Events and Track Metrics
After allocation, you must register a webhook to synchronize port state changes with external telephony gateways. This step configures the webhook endpoint, implements pagination for existing webhook listings, and sets up a metrics tracker for latency and success rates. Audit logs are generated using Python’s standard logging module with structured JSON output.
import httpx
import json
import logging
class AllocationAuditor:
        self.logger = logging.getLogger("AllocationAuditor")
        self.success_count = 0
        self.failure_count = 0
        self.total_latency_ms = 0.0
    def register_port_webhook(self, callback_url: str, webhook_name: str) -> Dict[str, Any]:
        # Scope required: platform:webhooks:manage
        headers = {
        url = f"{self.base_url}/api/v2/platform/webhooks"
        payload = {
            "name": webhook_name,
            "callback_url": callback_url,
            "event_types": ["PURECONNECT_PORT_ALLOCATED", "PURECONNECT_PORT_DEALLOCATED", "PURECONNECT_PORT_HEALTH_CHECK"],
            "enabled": True,
            "secret": "webhook-signature-secret-key-256bit"
        return response.json()
    def list_existing_webhooks(self) -> List[Dict[str, Any]]:
        all_webhooks = []
        page = 1
        page_size = 25
        while True:
            response = httpx.get(url, headers=headers, params={"page": page, "page_size": page_size})
            all_webhooks.extend(data.get("webhooks", []))
            if page * page_size >= data.get("total", 0):
                break
            page += 1
        return all_webhooks
    def record_allocation_metric(self, success: bool, latency_ms: float, port_count: int, sip_trunk_id: str) -> None:
        timestamp = datetime.now(timezone.utc).isoformat()
        if success:
            self.success_count += 1
        else:
            self.failure_count += 1
        self.total_latency_ms += latency_ms
        audit_entry = {
            "timestamp": timestamp,
            "event": "PORT_ALLOCATION_ATTEMPT",
            "sip_trunk_id": sip_trunk_id,
            "requested_ports": port_count,
            "success": success,
            "success_rate": round((self.success_count / (self.success_count + self.failure_count)) * 100, 2) if (self.success_count + self.failure_count) > 0 else 0.0
        self.logger.info(json.dumps(audit_entry))
The following script combines authentication, validation, allocation, and auditing into a single executable module. Replace the placeholder credentials with your NICE CXone environment values.
import os
import logging
import httpx
# Configure structured logging
logging.basicConfig(
    level=logging.INFO,
    format="%(asctime)s [%(levelname)s] %(name)s: %(message)s",
    handlers=[logging.StreamHandler()]
def run_port_allocation_pipeline(
    client_id: str,
    client_secret: str,
    env_url: str,
    sip_trunk_id: str,
    port_count: int,
    webhook_url: Optional[str] = None
) -> None:
    # Initialize components
    auth_manager = CXoneAuthManager(client_id, client_secret, env_url)
    validator = PortValidator(env_url, auth_manager)
    allocator = PortAllocator(env_url, auth_manager)
    auditor = AllocationAuditor(env_url, auth_manager)
        # Step 1: Validate capacity and hardware constraints
        logging.info("Validating hardware constraints and bandwidth availability")
        capacity = validator.check_capacity(sip_trunk_id, port_count)
        logging.info(f"Capacity check passed. Available: {capacity.available_concurrency}, BW: {capacity.bandwidth_available_mbps:.2f} Mbps")
        # Step 2: Execute atomic allocation with retry logic
        logging.info(f"Allocating {port_count} IVR ports on trunk {sip_trunk_id}")
        result = allocator.allocate_ports(
            sip_trunk_id=sip_trunk_id,
            port_count=port_count,
            load_balancing_strategy="least_connections",
            failover_enabled=True
        # Step 3: Record metrics and audit log
        latency = result.get("metadata", {}).get("latency_ms", 0.0)
        auditor.record_allocation_metric(success=True, latency_ms=latency, port_count=port_count, sip_trunk_id=sip_trunk_id)
        logging.info(f"Allocation successful. Assigned: {result.get('allocated_ports', [])}")
        # Optional: Synchronize webhook for external gateway alignment
        if webhook_url:
            logging.info("Registering port allocation webhook for external gateway sync")
            webhook_resp = auditor.register_port_webhook(callback_url=webhook_url, webhook_name="IVR-Port-Sync-Hook")
            logging.info(f"Webhook registered. ID: {webhook_resp.get('id')}")
    except ValueError as ve:
        logging.error(f"Validation failed: {ve}")
        auditor.record_allocation_metric(success=False, latency_ms=0.0, port_count=port_count, sip_trunk_id=sip_trunk_id)
    except httpx.HTTPStatusError as he:
        status = he.response.status_code
        logging.error(f"API request failed with status {status}: {he.response.text}")
        logging.error(f"Unexpected error during allocation: {e}")
        client_id=os.getenv("CXONE_CLIENT_ID", "your-client-id"),
        client_secret=os.getenv("CXONE_CLIENT_SECRET", "your-client-secret"),
        env_url="https://api-us-1.cxone.com",
        sip_trunk_id="TRUNK-SIP-001-PRIMARY",
        port_count=10,
        webhook_url="https://your-gateway.example.com/webhooks/cxone-ports"
  • Cause: The OAuth token is expired, malformed, or the client credentials are incorrect. The token cache in CXoneAuthManager may have retained an expired token if the TTL calculation is inaccurate.
  • Fix: Verify the client_id and client_secret match your CXone application. Ensure the expires_in field from the token response is correctly subtracted by a safety buffer (60 seconds) before caching. Implement a forced token refresh by setting auth_manager.token = None before retrying.
Error: 403 Forbidden
  • Cause: The OAuth token lacks the required scopes for the specific endpoint. Port allocation requires pureconnect:ports:manage, while capacity validation requires pureconnect:telephony:read.
  • Fix: Regenerate the access token with the complete scope string. Verify the CXone application role assigned to the OAuth client has API permissions enabled for Pure Connect telephony resources.
  • Cause: Rate limit cascades occur when allocation requests exceed the environment’s API throughput limits. NICE CXone enforces strict per-endpoint rate limits.
  • Fix: The @retry decorator with tenacity handles automatic exponential backoff. Ensure your integration respects the Retry-After header. Implement request queuing if you are provisioning ports in bulk across multiple clusters.
Error: 400 Bad Request (Schema Validation Failure)
  • Cause: The allocation payload contains invalid port references, missing assign directives, or mismatched SIP trunk IDs. The resource matrix must reference existing cluster IDs.
  • Fix: Validate the resource_matrix.cluster_id against your Pure Connect environment. Ensure sip_trunk_binding.trunk_id exactly matches the registered trunk identifier. Verify that load_balancing_algorithm uses supported values such as round_robin, least_connections, or random.
Error: 500 / 503 Internal Server Error
  • Cause: Backend telephony gateway connectivity issues or SIP trunk binding failures during the atomic POST operation.
  • Fix: Check CXone environment health dashboards. Verify that the target SIP trunk is registered and passing health checks. Retry the allocation after a 30-second delay. If the error persists, verify codec compatibility between your external gateway and the CXone trunk configuration.
