Aggregating Genesys Cloud Telephony CDRs with Python SDK for Billing Alignment
- A Python module that fetches call detail records via the Genesys Cloud Telephony API, processes them in validated batches, calculates costs based on duration and rate tiers, checks for duplicate legs, and synchronizes aggregated results with an external ERP system via webhook.
- This tutorial uses the Genesys Cloud Python SDK (
genesyscloud) alongsidehttpxandpydanticfor schema validation and external synchronization. - The implementation is written in Python 3.9+ and covers authentication, pagination, batch processing, error handling, latency tracking, and audit logging.
- Genesys Cloud OAuth client credentials (client ID, client secret, private key, and private key password)
- Required OAuth scope:
telephony:call:read - Python 3.9 or higher
- External dependencies:
genesyscloud>=2.0.0,httpx>=0.25.0,pydantic>=2.0.0,pydantic[email] - Access to an external ERP webhook endpoint for invoice synchronization
The Genesys Cloud Python SDK handles JWT bearer token acquisition, caching, and automatic refresh when configured with a private key. You must initialize the PureCloudPlatformClientV2 configuration before making any API calls.
import os
from genesyscloud.rest import Configuration
def build_genesys_config() -> Configuration:
config = Configuration()
config.host = "https://api.mypurecloud.com"
config.access_token = os.getenv("GENESYS_ACCESS_TOKEN")
if not config.access_token:
config.oauth_client_id = os.getenv("GENESYS_CLIENT_ID")
config.oauth_client_secret = os.getenv("GENESYS_CLIENT_SECRET")
config.oauth_private_key = os.getenv("GENESYS_PRIVATE_KEY")
config.oauth_private_key_password = os.getenv("GENESYS_PRIVATE_KEY_PASSWORD")
config.oauth_jwt_grant_type = "urn:ietf:params:oauth:grant-type:jwt-bearer"
return config
The SDK caches the token in memory and automatically requests a new token when the current one expires. If you provide a static access token, the SDK will use it until it fails with a 401 status code.
Step 1: Query CDRs with Pagination and Batch Limits
The Telephony API returns call detail records in paginated batches. You must construct a query payload with a date range, set a size limit to prevent payload overflow, and iterate using the nextPageToken. The endpoint supports a maximum batch size of 1000 records, but billing systems typically enforce stricter limits. This example caps batches at 500 records.
import httpx
from genesyscloud.api_client import ApiClient
from genesyscloud.telephony.api import TelephonyApi
from genesyscloud.telephony.model import QueryTelephonyCallsDetailsRequest
def fetch_cdr_batches(api_client: ApiClient, start_time: str, end_time: str, batch_size: int = 500):
telephony_api = TelephonyApi(api_client)
page_token = None
batch_count = 0
latency_tracker = []
while True:
request_body = {
"query": {
"filter": {
"field": "startTime",
"op": "between",
"value": [start_time, end_time]
"size": batch_size,
"nextPageToken": page_token
start_req = time.perf_counter()
response = telephony_api.post_telephony_calls_details_query(
body=QueryTelephonyCallsDetailsRequest.from_dict(request_body)
elapsed = time.perf_counter() - start_req
latency_tracker.append(elapsed)
if not response.entities:
break
batch_count += 1
yield response.entities, elapsed
page_token = response.next_page_token
if not page_token:
break
if e.response.status_code == 429:
retry_after = int(e.response.headers.get("Retry-After", 2))
time.sleep(retry_after)
raise
Expected Response Structure:
"entities": [
"id": "call-uuid-1",
"startTime": "2024-01-15T10:00:00Z",
"answerTime": "2024-01-15T10:00:02Z",
"endTime": "2024-01-15T10:05:30Z",
"direction": "outbound",
"from": {"number": "+15550100", "name": "Agent 1"},
"to": {"number": "+15550200", "name": "Customer A"},
"legIndex": 0,
"callId": "parent-call-uuid"
"nextPageToken": "eyJwYWdlIjoyLCJzaXplIjo1MDB9",
"pageSize": 500,
"total": 1250
The 429 status code triggers a retry loop using the Retry-After header. If the header is missing, the code defaults to a 2-second delay. The 401 and 403 errors propagate immediately because they indicate credential or scope misconfiguration.
Step 2: Process Batches with Duration Calculation and Duplicate Leg Checking
Each batch requires duration calculation, rate tier evaluation, and duplicate leg detection. You must calculate duration in seconds using ISO 8601 timestamps, verify against a tariff configuration via an atomic GET operation, and filter duplicate legs using a composite key of callId and legIndex.
from typing import List, Dict, Set
import httpx
def fetch_rate_tiers(base_url: str) -> Dict[str, float]:
response = httpx.get(f"{base_url}/api/v1/tariffs/active")
response.raise_for_status()
return response.json()
def process_cdr_batch(cdr_entities: List[Dict], rate_tiers: Dict[str, float], seen_legs: Set[str]) -> List[Dict]:
processed_records = []
for cdr in cdr_entities:
leg_key = f"{cdr.get('callId')}:{cdr.get('legIndex')}"
if leg_key in seen_legs:
seen_legs.add(leg_key)
start_dt = datetime.fromisoformat(cdr["startTime"].replace("Z", "+00:00"))
answer_dt = datetime.fromisoformat(cdr["answerTime"].replace("Z", "+00:00")) if cdr.get("answerTime") else start_dt
end_dt = datetime.fromisoformat(cdr["endTime"].replace("Z", "+00:00"))
duration_seconds = (end_dt - answer_dt).total_seconds()
if duration_seconds <= 0:
destination_country = cdr.get("to", {}).get("countryCode", "US")
rate_per_second = rate_tiers.get(destination_country, 0.01)
processed_records.append({
"cdr_reference": cdr["id"],
"call_id": cdr["callId"],
"duration_seconds": round(duration_seconds, 2),
"rate_per_second": rate_per_second,
"calculated_cost": round(duration_seconds * rate_per_second, 4),
"tariff_country": destination_country,
"direction": cdr["direction"]
return processed_records
The duration_seconds calculation excludes pre-answer time to align with standard billing practices. The seen_legs set prevents double-charging when Genesys Cloud returns multiple legs for the same call session. The atomic GET operation to /api/v1/tariffs/active represents your internal billing service. You must replace the URL with your actual tariff configuration endpoint.
Step 3: Validate Schema and Trigger ERP Invoice Sync
Before transmitting aggregated data to an external system, you must validate the payload against billing constraints. Pydantic enforces field types, maximum values, and required structures. After validation, the code triggers an automatic invoice webhook and records an audit log.
from pydantic import BaseModel, Field, ValidationError
import json
import logging
class CdrAggregationPayload(BaseModel):
cdr_reference: str
call_id: str
duration_seconds: float = Field(le=86400, ge=0)
rate_per_second: float = Field(ge=0)
calculated_cost: float = Field(ge=0)
tariff_country: str
direction: str
class BillingAggregation(BaseModel):
batch_id: str
records: List[CdrAggregationPayload] = Field(max_length=500)
total_cost: float
record_count: int
aggregation_timestamp: str
def validate_and_sync(batch_records: List[Dict], batch_id: str, webhook_url: str, logger: logging.Logger) -> Dict:
validated_payloads = []
validation_errors = []
for rec in batch_records:
validated_payloads.append(CdrAggregationPayload(**rec))
except ValidationError as e:
validation_errors.append({"cdr": rec.get("cdr_reference"), "errors": e.errors()})
if validation_errors:
logger.warning(f"Validation failures in batch {batch_id}: {validation_errors}")
aggregation = BillingAggregation(
batch_id=batch_id,
records=validated_payloads,
total_cost=sum(r.calculated_cost for r in validated_payloads),
record_count=len(validated_payloads),
aggregation_timestamp=datetime.now(timezone.utc).isoformat()
payload_json = aggregation.model_dump_json()
response = httpx.post(webhook_url, content=payload_json, headers={"Content-Type": "application/json"})
audit_log = {
"event": "cdr_aggregation_sync",
"batch_id": batch_id,
"records_processed": aggregation.record_count,
"total_cost": aggregation.total_cost,
"status": "success",
"webhook_status": response.status_code,
"timestamp": datetime.now(timezone.utc).isoformat()
logger.info(json.dumps(audit_log))
return audit_log
The BillingAggregation schema enforces a maximum record count of 500 to prevent payload rejection. The le=86400 constraint on duration_seconds prevents runaway billing calculations. The audit log records success metrics and webhook status for governance tracking.
This script combines authentication, pagination, batch processing, validation, and synchronization into a single executable module. Replace the environment variables and webhook URL before execution.
import os
import uuid
import json
import logging
import httpx
cdr_reference: str
call_id: str
tariff_country: str
direction: str
batch_id: str
total_cost: float
record_count: int
class CdrAggregator:
def __init__(self, config: Configuration, tariff_url: str, webhook_url: str):
self.api_client = ApiClient(config)
self.telephony_api = TelephonyApi(self.api_client)
self.tariff_url = tariff_url
self.seen_legs: Set[str] = set()
self.latency_log: List[float] = []
self.success_count = 0
self.total_batches = 0
self.logger = logging.getLogger("cdr_aggregator")
self.logger.setLevel(logging.INFO)
handler = logging.StreamHandler()
handler.setFormatter(logging.Formatter("%(asctime)s - %(levelname)s - %(message)s"))
self.logger.addHandler(handler)
def _fetch_rate_tiers(self) -> Dict[str, float]:
response = httpx.get(f"{self.tariff_url}/api/v1/tariffs/active")
def _process_batch(self, entities: List[Dict], rate_tiers: Dict[str, float]) -> List[Dict]:
processed = []
for cdr in entities:
if leg_key in self.seen_legs:
self.seen_legs.add(leg_key)
dest_country = cdr.get("to", {}).get("countryCode", "US")
rate = rate_tiers.get(dest_country, 0.01)
processed.append({
"rate_per_second": rate,
"calculated_cost": round(duration_seconds * rate, 4),
"tariff_country": dest_country,
return processed
def _sync_batch(self, batch_records: List[Dict], batch_id: str) -> Dict:
validated = []
validated.append(CdrAggregationPayload(**rec))
self.logger.warning(f"Validation failed for {rec.get('cdr_reference')}: {e.errors()}")
batch_id=batch_id,
records=validated,
total_cost=sum(r.calculated_cost for r in validated),
record_count=len(validated),
response = httpx.post(self.webhook_url, content=aggregation.model_dump_json(), headers={"Content-Type": "application/json"})
audit = {
self.logger.info(json.dumps(audit))
return audit
def run(self, start_time: str, end_time: str, batch_size: int = 500):
rate_tiers = self._fetch_rate_tiers()
page_token = None
while True:
request_body = {
"query": {"filter": {"field": "startTime", "op": "between", "value": [start_time, end_time]}},
"size": batch_size,
response = self.telephony_api.post_telephony_calls_details_query(
self.latency_log.append(time.perf_counter() - start_req)
break
self.total_batches += 1
batch_id = str(uuid.uuid4())
processed = self._process_batch(response.entities, rate_tiers)
if processed:
self._sync_batch(processed, batch_id)
self.success_count += 1
if not page_token:
break
self.logger.warning(f"Rate limited. Retrying in {retry_after}s")
raise
avg_latency = sum(self.latency_log) / len(self.latency_log) if self.latency_log else 0
success_rate = (self.success_count / self.total_batches * 100) if self.total_batches > 0 else 0
self.logger.info(f"Aggregation complete. Batches: {self.total_batches}, Success Rate: {success_rate:.2f}%, Avg Latency: {avg_latency:.3f}s")
def main():
aggregator = CdrAggregator(
config=config,
tariff_url=os.getenv("TARIFF_SERVICE_URL", "https://billing.internal"),
webhook_url=os.getenv("ERP_WEBHOOK_URL", "https://erp.internal/api/v1/invoices/trigger")
aggregator.run(
start_time="2024-01-01T00:00:00Z",
end_time="2024-01-31T23:59:59Z",
batch_size=500
main()
- Cause: The OAuth private key is expired, malformed, or the client credentials lack the
telephony:call:readscope. - Fix: Regenerate the private key in the Genesys Cloud admin console. Verify the scope assignment on the OAuth client. Ensure the private key password matches the key file.
- Code Fix: The SDK raises
httpx.HTTPStatusErrorwith status 401. Catch it explicitly and log the credential validation failure before terminating the process.
- Cause: The aggregation loop exceeds Genesys Cloud API rate limits. The Telephony API enforces per-client and per-tenant quotas.
- Fix: Implement exponential backoff. Read the
Retry-Afterheader from the response. The provided code already includes a retry loop that sleeps for the specified duration. - Code Fix:
- Cause: The Genesys Cloud query engine encounters a malformed date range, unsupported filter operator, or backend timeout.
- Fix: Validate the ISO 8601 date strings before submission. Ensure the
opfield uses valid operators (between,gt,lt). Reduce the date window size if timeouts persist. - Code Fix: Wrap the API call in a try-except block that logs the request payload and raises a custom exception with context for downstream monitoring systems.
