Aggregating Genesys Cloud EventBridge Metric Snapshots with Python
A Python module that consumes Genesys Cloud EventBridge metric snapshots, constructs aggregate payloads using metric key references, window matrices, and rollup directives, validates schemas against event bus constraints and retention limits, aligns timestamps automatically, detects outliers, syncs to an external time-series database via webhooks, tracks latency and merge success rates, generates audit logs, and exposes an automated metric aggregator.
This tutorial uses the Genesys Cloud EventBridge REST API and the official genesyscloud Python SDK.
The implementation uses Python 3.10+ with httpx, pydantic, and standard library modules.
- OAuth Client Credentials with scopes:
eventbridge:read,eventbridge:write,analytics:report:query - Genesys Cloud
genesyscloudSDK v1.5.0+ - Python 3.10 or later
- External dependencies:
pip install httpx pydantic numpy - A configured EventBridge subscription targeting a metric topic (e.g.,
wfc:queue:metric)
Genesys Cloud uses OAuth 2.0 Client Credentials flow. The following code fetches an access token, caches it, and handles expiration.
import httpx
from typing import Optional
class GenesysAuth:
def __init__(self, org_host: str, client_id: str, client_secret: str, scopes: list[str]):
self.org_host = org_host.rstrip("/")
self.client_id = client_id
self.scopes = scopes
self.expires_at: float = 0.0
def get_token(self) -> str:
if self.token and time.time() < self.expires_at - 30:
return self.token
url = f"{self.org_host}/oauth/token"
data = {
"client_id": self.client_id,
"scope": " ".join(self.scopes)
with httpx.Client() as client:
response = client.post(url, headers=headers, data=data)
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.expires_at = time.time() + payload["expires_in"]
return self.token
Step 1: SDK Initialization and Subscription Message Retrieval
The genesyscloud SDK wraps the EventBridge API. We initialize the platform client, attach the OAuth token provider, and configure an httpx transport for atomic GET operations with retry logic.
import httpx
from genesyscloud.platform_client_v2 import Configuration, ApiClient
from genesyscloud.eventbridge.eventbridge_api import EventBridgeApi
from genesyscloud.eventbridge.model import MessagesQuery
class EventBridgeFetcher:
def __init__(self, auth: GenesysAuth, subscription_id: str):
self.subscription_id = subscription_id
self.auth = auth
config = Configuration(host=auth.org_host)
config.access_token = auth.get_token()
config.access_token_provider = auth.get_token
self.api_client = ApiClient(configuration=config, http_client=httpx.Client())
self.eventbridge_api = EventBridgeApi(api_client=self.api_client)
def fetch_snapshots(self, limit: int = 100) -> dict:
query = MessagesQuery(limit=limit)
response = self.eventbridge_api.post_eventbridge_subscriptions_messages_query(
subscription_id=self.subscription_id,
body=query
return response.to_dict()
if e.response.status_code == 429:
retry_after = int(e.response.headers.get("Retry-After", 5))
print(f"Rate limited. Retrying in {retry_after} seconds.")
time.sleep(retry_after)
return self.fetch_snapshots(limit)
elif e.response.status_code in (401, 403):
raise PermissionError(f"OAuth failure: {e.response.status_code}")
raise
Step 2: Aggregate Payload Construction with Window Matrix and Rollup Directive
We define a strict schema for the aggregate payload. The window matrix maps time buckets to second intervals. The rollup directive specifies the mathematical reduction function.
from pydantic import BaseModel, Field, validator
from typing import Any
class AggregatePayload(BaseModel):
metric_keys: list[str] = Field(..., min_items=1)
window_matrix: dict[str, int] = Field(default_factory=lambda: {"5m": 300, "1h": 3600})
rollup_directive: str = Field(..., pattern="^(mean|sum|max|min|count)$")
snapshots: list[dict[str, Any]] = Field(default_factory=list)
schema_version: str = Field(default="v2.1")
aggregated_at: str = Field(default_factory=lambda: time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()))
@validator("window_matrix")
def validate_window_intervals(cls, v):
for key, seconds in v.items():
if seconds <= 0 or seconds % 60 != 0:
raise ValueError("Window intervals must be positive multiples of 60 seconds.")
return v
Step 3: Schema Validation, Retention Limits, and Format Verification
EventBus constraints enforce a maximum payload size (256 KB) and retention windows. We validate incoming snapshots against these limits before aggregation.
import json
import logging
logger = logging.getLogger("genesys_aggregator")
MAX_PAYLOAD_BYTES = 256 * 1024
MAX_RETENTION_SNAPSHOTS = 10000
def validate_event_bus_constraints(payload: AggregatePayload) -> bool:
serialized = json.dumps(payload.dict()).encode("utf-8")
if len(serialized) > MAX_PAYLOAD_BYTES:
logger.error("Aggregate payload exceeds 256KB event bus constraint.")
return False
if len(payload.snapshots) > MAX_RETENTION_SNAPSHOTS:
logger.error(f"Snapshot count {len(payload.snapshots)} exceeds retention limit {MAX_RETENTION_SNAPSHOTS}.")
return False
return True
def verify_snapshot_format(snapshot: dict) -> bool:
required_keys = {"publishedDate", "payload", "schemaVersion"}
if not required_keys.issubset(snapshot.keys()):
return False
if not isinstance(snapshot["payload"], dict):
return False
return True
Step 4: Timestamp Alignment, Outlier Detection, and Schema Verification Pipeline
We align timestamps to the nearest window boundary, verify schema versions match the expected pipeline version, and filter outliers using the Interquartile Range method.
import math
import statistics
def align_timestamp_to_window(ts_str: str, window_seconds: int) -> str:
dt = datetime.fromisoformat(ts_str.replace("Z", "+00:00"))
epoch = int(dt.timestamp())
aligned_epoch = (epoch // window_seconds) * window_seconds
aligned_dt = datetime.fromtimestamp(aligned_epoch, tz=timezone.utc)
return aligned_dt.strftime("%Y-%m-%dT%H:%M:%SZ")
def detect_outlier(value: float, history: list[float], threshold: float = 1.5) -> bool:
if len(history) < 4:
return False
q1 = statistics.quantiles(history, n=4)[0]
q3 = statistics.quantiles(history, n=4)[2]
iqr = q3 - q1
lower = q1 - (threshold * iqr)
upper = q3 + (threshold * iqr)
return value < lower or value > upper
def process_snapshot_pipeline(raw_messages: list[dict], expected_schema: str, window_seconds: int) -> list[dict]:
aligned_snapshots = []
metric_history = {}
for msg in raw_messages:
if not verify_snapshot_format(msg):
logger.warning("Skipping malformed snapshot.")
if msg.get("schemaVersion") != expected_schema:
logger.warning(f"Schema version mismatch: expected {expected_schema}, got {msg.get('schemaVersion')}")
payload_data = msg["payload"]
metric_key = payload_data.get("metricKey")
metric_value = payload_data.get("value")
if metric_key is None or metric_value is None:
if metric_key not in metric_history:
metric_history[metric_key] = []
if detect_outlier(float(metric_value), metric_history[metric_key]):
logger.info(f"Outlier detected for {metric_key}: {metric_value}. Excluding from aggregate.")
metric_history[metric_key].append(float(metric_value))
aligned_ts = align_timestamp_to_window(msg["publishedDate"], window_seconds)
aligned_snapshots.append({
"metricKey": metric_key,
"value": float(metric_value),
"timestamp": aligned_ts,
"originalSchemaVersion": msg["schemaVersion"]
return aligned_snapshots
Step 5: Webhook Synchronization, Latency Tracking, and Audit Logging
The aggregator posts validated aggregates to an external time-series database webhook, tracks merge success rates, measures latency, and writes structured audit logs.
import uuid
@dataclass
class AggregatorMetrics:
total_processed: int = 0
merge_successes: int = 0
merge_failures: int = 0
total_latency_ms: float = 0.0
audit_log: list[dict] = field(default_factory=list)
@property
def success_rate(self) -> float:
total = self.merge_successes + self.merge_failures
return (self.merge_successes / total * 100) if total > 0 else 0.0
@property
def avg_latency_ms(self) -> float:
return self.total_latency_ms / self.total_processed if self.total_processed > 0 else 0.0
class MetricAggregator:
def __init__(self, fetcher: EventBridgeFetcher, webhook_url: str):
self.fetcher = fetcher
self.metrics = AggregatorMetrics()
self.expected_schema = "v2.1"
self.default_window = 300 # 5 minutes
def run_aggregation_cycle(self) -> dict:
raw_response = self.fetcher.fetch_snapshots(limit=50)
messages = raw_response.get("entities", [])
if not messages:
logger.info("No messages returned. Skipping cycle.")
return {"status": "empty"}
aligned_data = process_snapshot_pipeline(messages, self.expected_schema, self.default_window)
aggregate = AggregatePayload(
metric_keys=list(set(s["metricKey"] for s in aligned_data)),
window_matrix={"5m": 300},
rollup_directive="mean",
snapshots=aligned_data,
schema_version=self.expected_schema
if not validate_event_bus_constraints(aggregate):
self.metrics.merge_failures += 1
return {"status": "validation_failed"}
# Webhook sync
with httpx.Client(timeout=10.0) as client:
resp = client.post(
self.webhook_url,
json=aggregate.dict(),
headers={"Content-Type": "application/json", "X-Genesys-Aggregator": "v1"}
resp.raise_for_status()
self.metrics.merge_successes += 1
except httpx.HTTPError as e:
logger.error(f"Webhook sync failed: {e}")
return {"status": "sync_failed", "error": str(e)}
elapsed_ms = (time.perf_counter() - start_time) * 1000
self.metrics.total_latency_ms += elapsed_ms
self.metrics.total_processed += 1
# Audit log entry
audit_entry = {
"cycle_id": str(uuid.uuid4()),
"timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
"snapshots_processed": len(messages),
"snapshots_aggregated": len(aligned_data),
"latency_ms": round(elapsed_ms, 2),
"success_rate": round(self.metrics.success_rate, 2)
self.metrics.audit_log.append(audit_entry)
logger.info(f"Aggregation cycle complete. Latency: {elapsed_ms:.2f}ms. Success Rate: {self.metrics.success_rate:.2f}%")
return {"status": "success", "audit": audit_entry}
The following script demonstrates the full execution flow. Replace the placeholder credentials and webhook URL before running.
import os
import logging
ORG_HOST = os.getenv("GENESYS_ORG_HOST", "https://api.mypurecloud.com")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "your_client_id")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "your_client_secret")
SUBSCRIPTION_ID = os.getenv("GENESYS_SUBSCRIPTION_ID", "your_subscription_id")
WEBHOOK_URL = os.getenv("TSDB_WEBHOOK_URL", "https://your-tsdb-ingest.example.com/api/v1/write")
auth = GenesysAuth(
org_host=ORG_HOST,
client_id=CLIENT_ID,
client_secret=CLIENT_SECRET,
scopes=["eventbridge:read", "eventbridge:write", "analytics:report:query"]
fetcher = EventBridgeFetcher(auth=auth, subscription_id=SUBSCRIPTION_ID)
aggregator = MetricAggregator(fetcher=fetcher, webhook_url=WEBHOOK_URL)
# Execute a single aggregation cycle
result = aggregator.run_aggregation_cycle()
print("Cycle Result:", result)
print("Aggregator Metrics:", aggregator.metrics)
- Cause: Expired OAuth token, missing
eventbridge:readscope, or incorrect client credentials. - Fix: Verify the client ID and secret match the Genesys Cloud admin console. Ensure the token provider refreshes automatically. The
GenesysAuthclass handles expiration by checkingexpires_at. If the scope is missing, update the OAuth client in Genesys Cloud Settings. - Code Fix: The
get_tokenmethod already implements automatic refresh. Add explicit scope validation during initialization if your environment requires strict scope enforcement.
- Cause: Exceeding Genesys Cloud API rate limits, typically 100 requests per second for EventBridge endpoints.
- Fix: Implement exponential backoff or honor the
Retry-Afterheader. TheEventBridgeFetcher.fetch_snapshotsmethod includes a 429 handler that sleeps for the specified duration before retrying. - Code Fix: The retry logic is built into
fetch_snapshots. For high-volume pipelines, add a token bucket rate limiter before calling the API.
Error: 400 Bad Request (Schema Validation Failure)
- Cause: Payload exceeds 256 KB, snapshot count exceeds retention limits, or malformed JSON structure.
- Fix: Review the
validate_event_bus_constraintsfunction. Reduce thelimitparameter infetch_snapshotsor increase the window interval to reduce snapshot density. Ensure all snapshots containpublishedDate,payload, andschemaVersion. - Code Fix: The
AggregatePayloadPydantic model enforces structure. If validation fails, the aggregator logs the exact constraint violation and incrementsmerge_failures.
Error: Timestamp Alignment Drift
- Cause: Timezone mismatches or non-ISO8601 formatted timestamps from legacy event sources.
- Fix: The
align_timestamp_to_windowfunction normalizes all timestamps to UTC and floors them to the nearest window boundary. Ensure incomingpublishedDatevalues follow ISO8601 format withZor+00:00suffix. - Code Fix: Add a fallback parser using
dateutil.parserif legacy formats appear, but prefer standardizing at the EventBridge subscription level.
