Hi everybody!
I’ve noticed a problem in our production environment just before starting multichannel, voice and email.
I’ve been doing some test, just to see that everything worked properly, but testing the email and voice channels i found the following:
I’ve created a capacity rule for my test agent. I decided to handle 1 voice interaction and 10 emails at the same time.
The problem is, that with the capacity rule assigned, calls are being routed to default, and without the capacity rule, it worked fine, except for emails, because without capacity rule can’t be routed.
If I assign the capacity rule to the agent, and I call to my test service, I found that URS tried to route the agent, using as OtherDN my employeeid, not my extensionDN. If I don’t use any capacity rule, OtherDN gets the correct value, my extension DN.
Also, our Avaya PBX returned us the error C_INVLDNUM C_COV_DONT_ANS, thats because it doesn’t exist a DN called as the agent employeeid.
My PBX is an Avaya one, we are using StatServer 7.2.000.005, URS it’s 7.1 and T-Server 7.1 as well.
Does any body heard any time something similar? ![]()
Thank u in advance!
Toni.
