When an agent selects After-Call / Wrap-up during a call, Avaya puts it in a pending state until the call is disconnected and agent goes into After-Call / Wrap-up. The problem is Genesys reports the agent as going into Wrap-up as soon as the button is pressed not when the phone actually goes into Wrap-up. Does anyone know how to fix this problem?
Those settings all look good. That what we’re using at the moment and it works fine.
When you say that Genesys reports the agent as being in ACW do you mean that the Stat Server logs / CC Pulse changes their state immediately or do you mean in the T-Server logs?
Those settings look good to me as well. I would upgrade the T Server in test region to see if it fixes it. Make sure your softphone is correctly setting the pending state. Maybe start digging into switch settings if none of that works
