Adjusting Genesys Cloud IVR Voicemail Thresholds and Queue Routing via Java SDK
- A Java service that programmatically updates IVR voicemail thresholds and queue overflow limits using atomic HTTP PUT operations with ETag validation.
- This tutorial uses the official Genesys Cloud Java SDK (
com.mendix.genesyscloud) combined withjava.net.http.HttpClientfor precise header control and audit logging. - The code is written in Java 17+ and handles capacity validation, stale configuration detection, 429 retry logic, metric tracking, and external webhook synchronization.
- OAuth Client Credentials flow with required scopes:
routing:queue:write,ivrs:write,routing:queue:read,ivrs:read - Genesys Cloud Java SDK v16.0+ (
com.mendix:genesyscloud) - Java 17 runtime
- External dependencies:
jackson-databindfor JSON serialization,slf4j-apifor structured logging - A Genesys Cloud organization with an active IVR and at least one configured Queue
The Genesys Cloud Java SDK abstracts the OAuth2 Client Credentials flow. You must configure the OAuthClientCredentials object with your client ID, client secret, and login URL. The SDK handles token caching and automatic refresh when the access token expires.
import com.mendix.genesyscloud.ApiClient;
import com.mendix.genesyscloud.auth.OAuthClientCredentials;
import com.mendix.genesyscloud.auth.OAuthClientCredentials.TokenResponse;
public class GenesysAuth {
private static final String LOGIN_URL = "https://login.mypurecloud.com";
private static final String CLIENT_ID = System.getenv("GENESYS_CLIENT_ID");
private static final String CLIENT_SECRET = System.getenv("GENESYS_CLIENT_SECRET");
public static ApiClient initializeApiClient() throws Exception {
OAuthClientCredentials oAuth = new OAuthClientCredentials(LOGIN_URL, CLIENT_ID, CLIENT_SECRET);
oAuth.setScopes(List.of("routing:queue:write", "ivrs:write", "routing:queue:read", "ivrs:read"));
TokenResponse token = oAuth.getAccessToken();
if (token == null || token.getAccessToken() == null) {
throw new IllegalStateException("OAuth token acquisition failed");
ApiClient apiClient = new ApiClient(LOGIN_URL);
apiClient.setAccessToken(token.getAccessToken());
apiClient.setRefreshToken(token.getRefreshToken());
return apiClient;
Step 1: Construct Threshold Payloads and Validate Against Capacity Constraints
Before sending configuration changes, you must validate the payload against Genesys Cloud routing constraints. The queue matrix defines routing rules, skills, and overflow behavior. The threshold reference maps to voicemailNumber and overflowThreshold. You must ensure the overflow threshold does not exceed the maximum wait time multiplied by the concurrent call limit, and that the voicemail number follows E.164 or valid SIP URI format.
import com.fasterxml.jackson.databind.SerializationFeature;
import com.mendix.genesyscloud.model.Queue;
import com.mendix.genesyscloud.model.Ivr;
import com.mendix.genesyscloud.model.QueueRoutingRules;
import java.util.Map;
import java.util.regex.Pattern;
public class ThresholdValidator {
private static final Pattern E164_PATTERN = Pattern.compile("^\\+[1-9]\\d{1,14}$");
private static final int MAX_OVERFLOW_THRESHOLD = 999;
private static final int MAX_WAIT_TIME_SECONDS = 7200;
public static Map<String, Object> buildQueuePayload(String queueId, Queue existingQueue,
int newOverflowThreshold, int newMaxWaitTime,
String voicemailNumber) throws ValidationException {
if (newOverflowThreshold < 0 || newOverflowThreshold > MAX_OVERFLOW_THRESHOLD) {
throw new ValidationException("Overflow threshold exceeds capacity constraints");
if (newMaxWaitTime < 0 || newMaxWaitTime > MAX_WAIT_TIME_SECONDS) {
throw new ValidationException("Wait time exceeds maximum allowed duration");
if (voicemailNumber != null && !E164_PATTERN.matcher(voicemailNumber).matches()) {
throw new ValidationException("Voicemail number must be in valid E.164 format");
// Conflict verification: ensure overflow does not bypass wait time logic
if (newMaxWaitTime > 0 && newOverflowThreshold < newMaxWaitTime) {
throw new ValidationException("Rule conflict: overflow threshold cannot be less than max wait time");
Queue updatedQueue = new Queue();
updatedQueue.setId(queueId);
updatedQueue.setOverflowThreshold(newOverflowThreshold);
updatedQueue.setMaxWaitTime(newMaxWaitTime);
updatedQueue.setVoicemailNumber(voicemailNumber);
// Preserve existing routing rules (queue-matrix) to prevent accidental rule deletion
updatedQueue.setRoutingRules(existingQueue.getRoutingRules());
updatedQueue.setSkills(existingQueue.getSkills());
updatedQueue.setWrapUpTime(existingQueue.getWrapUpTime());
updatedQueue.setMemberLimit(existingQueue.getMemberLimit());
updatedQueue.setOutboundMemberLimit(existingQueue.getOutboundMemberLimit());
ObjectMapper mapper = new ObjectMapper().enable(SerializationFeature.INDENT_OUTPUT);
return Map.of(
"queue", mapper.writeValueAsString(updatedQueue),
"etag", existingQueue.getEtag()
} catch (Exception e) {
throw new RuntimeException("JSON serialization failed", e);
public static class ValidationException extends Exception {
public ValidationException(String message) { super(message); }
Step 2: Execute Atomic HTTP PUT with ETag Stale-Config Checking
Genesys Cloud enforces optimistic concurrency control via the If-Match header. You must fetch the current resource, extract the etag, and include it in the PUT request. If another process modified the configuration between fetch and update, the API returns HTTP 409. The following code demonstrates the exact HTTP cycle, including format verification and automatic notification triggers.
import java.net.URI;
import java.time.Duration;
public class AtomicConfigUpdater {
private static final HttpClient httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.build();
private static final ObjectMapper objectMapper = new ObjectMapper();
public static Map<String, Object> updateQueueConfiguration(String domain, String accessToken,
String queueId, Map<String, Object> payload)
throws Exception {
String endpoint = String.format("https://%s/api/v2/routing/queues/%s", domain, queueId);
String jsonBody = (String) payload.get("queue");
String etag = (String) payload.get("etag");
.uri(URI.create(endpoint))
.header("Authorization", "Bearer " + accessToken)
.header("If-Match", etag)
.PUT(HttpRequest.BodyPublishers.ofString(jsonBody))
.build();
if (response.statusCode() == 409) {
throw new StaleConfigurationException("Configuration changed since last fetch. Refresh and retry.");
if (response.statusCode() >= 400) {
throw new ApiExecutionException("HTTP " + response.statusCode() + ": " + response.body());
return Map.of(
"statusCode", response.statusCode(),
"headers", response.headers().map(),
"body", response.body(),
"requestPayload", jsonBody
public static class StaleConfigurationException extends Exception {
public StaleConfigurationException(String msg) { super(msg); }
public static class ApiExecutionException extends Exception {
public ApiExecutionException(String msg) { super(msg); }
Step 3: Implement Retry Logic, Audit Logging, and Metric Tracking
Production integrations must handle rate limiting (HTTP 429) gracefully. You must implement exponential backoff with jitter. You must also track latency, success rates, and generate audit logs for IVR governance. The following class wraps the PUT operation with retry logic, metrics collection, and webhook synchronization.
import java.time.Instant;
import java.util.ArrayList;
import java.util.List;
import java.util.logging.Logger;
import java.util.logging.Level;
public class ThresholdAdjuster {
private static final Logger logger = Logger.getLogger(ThresholdAdjuster.class.getName());
private static final int MAX_RETRIES = 3;
private static final long INITIAL_BACKOFF_MS = 1000;
private final List<AuditRecord> auditLogs = new ArrayList<>();
private final MetricsCollector metrics = new MetricsCollector();
private final String webhookUrl;
public ThresholdAdjuster(String webhookUrl) {
this.webhookUrl = webhookUrl;
public Map<String, Object> executeAdjustment(String domain, String token, String queueId, Map<String, Object> payload) throws Exception {
long startNanos = System.nanoTime();
String operationId = java.util.UUID.randomUUID().toString();
for (int attempt = 1; attempt <= MAX_RETRIES; attempt++) {
Map<String, Object> result = AtomicConfigUpdater.updateQueueConfiguration(domain, token, queueId, payload);
long latencyMs = TimeUnit.NANOSECONDS.toMillis(System.nanoTime() - startNanos);
metrics.recordSuccess(operationId, latencyMs);
recordAudit(operationId, queueId, "SUCCESS", payload, result, latencyMs);
triggerWebhookSync(operationId, queueId, result);
return result;
} catch (AtomicConfigUpdater.ApiExecutionException e) {
if (e.getMessage().startsWith("HTTP 429") && attempt < MAX_RETRIES) {
long backoff = INITIAL_BACKOFF_MS * (1L << (attempt - 1));
logger.info("Rate limited. Retrying in " + backoff + "ms. Attempt " + attempt);
TimeUnit.MILLISECONDS.sleep(backoff);
continue;
throw e;
} catch (AtomicConfigUpdater.StaleConfigurationException e) {
logger.warning("Stale config detected. Caller must refresh resource.");
throw e;
throw new Exception("Max retries exceeded for queue " + queueId);
private void recordAudit(String opId, String queueId, String status, Map<String, Object> payload,
Map<String, Object> result, long latencyMs) {
AuditRecord record = new AuditRecord(opId, queueId, status, payload, result, latencyMs, Instant.now());
auditLogs.add(record);
logger.log(Level.INFO, () -> "AUDIT: " + record);
private void triggerWebhookSync(String opId, String queueId, Map<String, Object> result) {
String webhookPayload = objectMapper.writeValueAsString(Map.of(
"event", "threshold.adjusted",
"operationId", opId,
"queueId", queueId,
"timestamp", Instant.now().toString(),
"status", "synced",
"resultSummary", result
HttpRequest webhookReq = HttpRequest.newBuilder()
.uri(URI.create(webhookUrl))
.POST(HttpRequest.BodyPublishers.ofString(webhookPayload))
.build();
HttpResponse<String> webhookResp = httpClient.send(webhookReq, HttpResponse.BodyHandlers.ofString());
logger.info("Webhook sync completed with status: " + webhookResp.statusCode());
logger.log(Level.WARNING, "Webhook sync failed", e);
public static class AuditRecord {
public final String operationId;
public final String queueId;
public final String status;
public final Map<String, Object> payload;
public final Map<String, Object> result;
public final long latencyMs;
public final Instant timestamp;
public AuditRecord(String opId, String qId, String status, Map<String, Object> payload,
Map<String, Object> result, long latency, Instant ts) {
this.operationId = opId; this.queueId = qId; this.status = status;
this.payload = payload; this.result = result; this.latencyMs = latency; this.timestamp = ts;
@Override public String toString() {
return String.format("Op:%s Queue:%s Status:%s Latency:%dms Time:%s",
operationId, queueId, status, latencyMs, timestamp);
class MetricsCollector {
private int successCount = 0;
private double totalLatency = 0;
public synchronized void recordSuccess(String opId, long latencyMs) {
successCount++;
totalLatency += latencyMs;
logger.info("Metrics: Success count=" + successCount + ", Avg latency=" + (totalLatency / successCount) + "ms");
The following script combines authentication, validation, atomic update, retry logic, and audit tracking into a single executable class. Replace the environment variables before execution.
import com.mendix.genesyscloud.api.RoutingQueuesApi;
public class IvRThresholdAdjusterMain {
private static final String DOMAIN = System.getenv("GENESYS_DOMAIN");
private static final String QUEUE_ID = System.getenv("GENESYS_QUEUE_ID");
private static final String WEBHOOK_URL = System.getenv("EXTERNAL_WEBHOOK_URL");
// 1. Authenticate
ApiClient apiClient = GenesysAuth.initializeApiClient();
String accessToken = apiClient.getAccessToken();
RoutingQueuesApi queuesApi = new RoutingQueuesApi(apiClient);
// 2. Fetch current configuration for ETag and baseline validation
Queue currentQueue = queuesApi.getRoutingQueue(QUEUE_ID, null, null, null, null, null);
// 3. Construct and validate payload
Map<String, Object> payload = ThresholdValidator.buildQueuePayload(
QUEUE_ID,
currentQueue,
150, // new overflow threshold
300, // new max wait time (seconds)
"+15551234567" // voicemail threshold reference
// 4. Execute adjustment with retry, audit, and webhook sync
ThresholdAdjuster adjuster = new ThresholdAdjuster(WEBHOOK_URL);
Map<String, Object> result = adjuster.executeAdjustment(
DOMAIN, accessToken, QUEUE_ID, payload
System.out.println("Adjustment complete. Response: " + objectMapper.writeValueAsString(result));
} catch (ThresholdValidator.ValidationException e) {
System.err.println("Validation failed: " + e.getMessage());
System.err.println("Stale configuration: " + e.getMessage());
System.err.println("Execution failed: " + e.getMessage());
e.printStackTrace();
Error: HTTP 401 Unauthorized
- Cause: OAuth token expired, invalid client credentials, or missing
routing:queue:writescope. - Fix: Verify the client ID and secret. Ensure the OAuth client in the Genesys Cloud admin console is set to
confidentialand has the required scopes assigned. Re-fetch the token before retrying.
Error: HTTP 403 Forbidden
- Cause: The authenticated user or service account lacks permission to modify queues or IVRs.
- Fix: Assign the
Routing AdministratororIVR Administratorrole to the service account. Verify the OAuth client hasrouting:queue:writeandivrs:writescopes.
Error: HTTP 409 Conflict (Stale Config)
- Cause: The
If-Matchheader contains an outdatedetag. Another process modified the queue between your GET and PUT calls. - Fix: Implement a fetch-retry loop. Catch
StaleConfigurationException, re-fetch the queue viagetRoutingQueue, rebuild the payload preserving the newetag, and retry the PUT.
- Cause: Exceeded Genesys Cloud rate limits for configuration endpoints.
- Fix: The
ThresholdAdjusterclass already implements exponential backoff. If failures persist, reduce batch size or introduce a fixed delay between queue updates.
Error: HTTP 400 Bad Request
- Cause: Payload violates schema constraints, such as negative overflow thresholds, invalid voicemail formats, or conflicting routing rules.
- Fix: Review the
ThresholdValidatorconstraints. EnsureoverflowThresholdis non-negative,maxWaitTimedoes not exceed 7200 seconds, and voicemail numbers match E.164 format.
