Acknowledging NICE CXone Web Messaging Read Receipts with Python
- A Python module that transmits read receipts for CXone Web Messaging guest conversations using the official Python SDK and WebSocket protocol.
- The implementation constructs acknowledgment payloads with receipt references, timestamp matrices, and confirm directives, validates them against protocol constraints, and enforces maximum delay limits.
- The code covers authentication, message existence validation, presence verification, atomic WebSocket transmission, external webhook synchronization, latency tracking, audit logging, and exposes a receipt acker for automated management.
- OAuth 2.0 Client Credentials or Authorization Code flow with scopes:
conversations:read,conversations:write,webchat:guests:read,webchat:guests:write - NICE CXone Python SDK v5.0+ (
pip install nice-cxone-python) - Python 3.9+
- Additional dependencies:
httpx,websockets,pydantic,structlog,tenacity
CXone requires OAuth 2.0 bearer tokens for all REST API calls. The Python SDK handles token injection automatically once configured. You must cache the token and refresh it before expiration to prevent 401 interruptions.
import httpx
from nice_cxone.platformclient_v2 import Configuration, ApiClient
class CxoneAuthManager:
def __init__(self, client_id: str, client_secret: str, org_name: str):
self.client_id = client_id
self.org_name = org_name
self.base_url = f"https://api.{org_name}.mynicecx.com"
self.token_endpoint = f"{self.base_url}/oauth/token"
self._token: str | None = None
self._expires_at: float | None = None
self._http_client = httpx.Client(timeout=15.0)
if self._token and self._expires_at and time.time() < self._expires_at - 60:
return self._token
response = self._http_client.post(
self.token_endpoint,
headers={"Content-Type": "application/x-www-form-urlencoded"},
data={
"client_id": self.client_id,
"scope": "conversations:read conversations:write webchat:guests:read webchat:guests:write"
response.raise_for_status()
payload = response.json()
self._token = payload["access_token"]
self._expires_at = time.time() + payload["expires_in"]
return self._token
def initialize_sdk(self) -> ApiClient:
config = Configuration()
config.host = self.base_url
config.access_token = self.get_access_token()
config.access_token_refresh_enabled = False
return ApiClient(config)
Step 1: Validate Message Existence and User Presence
Before transmitting a read receipt, you must verify that the target message exists and the guest session remains active. CXone rejects receipts for deleted messages or inactive sessions. The SDK provides direct REST endpoints for this validation.
import asyncio
from nice_cxone.platformclient_v2 import WebchatApi, ApiException
import structlog
class PresenceAndMessageValidator:
def __init__(self, api_client: ApiClient):
self.webchat_api = WebchatApi(api_client)
def validate(self, guest_id: str, message_id: str) -> bool:
msg = self.webchat_api.get_conversations_webchat_guests_messages_message_id(
guest_id=guest_id, message_id=message_id
if not msg or msg.id != message_id:
logger.error("message_not_found", guest_id=guest_id, message_id=message_id)
return False
except ApiException as e:
logger.error("message_validation_api_error", status_code=e.status, reason=e.reason)
return False
presence = self.webchat_api.get_conversations_webchat_guests_presence(guest_id=guest_id)
if not presence or not getattr(presence, "active", False):
logger.warning("guest_session_inactive", guest_id=guest_id)
return False
logger.error("presence_check_api_error", status_code=e.status, reason=e.reason)
return False
return True
Step 2: Construct and Validate Acknowledgment Payload
CXone Web Messaging enforces strict schema constraints for read receipts. The payload must include a receipt reference (messageId), a timestamp matrix (timestamp and serverTimestamp), a confirm directive (type: "read"), and a badge clear trigger (badgeCount: 0). You must also enforce the maximum delay limit of 30 seconds between message delivery and acknowledgment.
from pydantic import BaseModel, field_validator
from datetime import datetime, timezone, timedelta
class ReadReceiptPayload(BaseModel):
type: str
messageId: str
timestamp: str
serverTimestamp: str | None = None
badgeCount: int = 0
@field_validator("type")
@classmethod
def validate_confirm_directive(cls, v: str) -> str:
if v != "read":
raise ValueError("Confirm directive must be 'read' for acknowledgment payloads")
return v
@field_validator("badgeCount")
@classmethod
def validate_badge_clear_trigger(cls, v: int) -> int:
if v < 0:
raise ValueError("Badge count cannot be negative. Use 0 to clear unread indicators.")
return v
def build_acknowledgment_payload(message_id: str, delivery_timestamp: datetime) -> dict:
current_time = datetime.now(timezone.utc)
delay_seconds = (current_time - delivery_timestamp).total_seconds()
if delay_seconds > 30.0:
raise TimeoutError(f"Maximum delay limit exceeded. Delay: {delay_seconds:.2f}s. CXone enforces a 30-second window.")
payload = ReadReceiptPayload(
type="read",
messageId=message_id,
timestamp=current_time.isoformat(),
serverTimestamp=delivery_timestamp.isoformat()
return payload.model_dump()
Step 3: Transmit Receipt via WebSocket and Track Metrics
Real-time acknowledgment requires atomic WebSocket text operations. You must serialize the payload, verify the JSON format, and transmit it over the secure CXone WebSocket endpoint. The implementation tracks latency, records success rates, and dispatches synchronization webhooks to external archives.
import json
import websockets
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
class ReceiptMetricsTracker:
def __init__(self):
self.total_attempts = 0
self.successful_acks = 0
self.latencies = []
def record_attempt(self, latency_ms: float, success: bool):
self.total_attempts += 1
self.latencies.append(latency_ms)
if success:
self.successful_acks += 1
def get_success_rate(self) -> float:
return (self.successful_acks / self.total_attempts * 100) if self.total_attempts > 0 else 0.0
def get_average_latency(self) -> float:
return sum(self.latencies) / len(self.latencies) if self.latencies else 0.0
class CxoneReadReceiptAcker:
def __init__(self, org_name: str, guest_id: str, auth_token: str, webhook_url: str):
self.ws_url = f"wss://webchat.{org_name}.mynicecx.com/webchat/ws?guestId={guest_id}&token={auth_token}"
self.metrics = ReceiptMetricsTracker()
self._http = httpx.Client(timeout=10.0)
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type((websockets.exceptions.ConnectionClosed, TimeoutError))
def send_receipt(self, payload: dict) -> bool:
start_time = time.time()
json_string = json.dumps(payload)
logger.info("audit_ack_transmission_start", messageId=payload["messageId"], payload=json_string)
with websockets.connect(self.ws_url) as ws:
ws.send(json_string)
response = ws.recv()
response_payload = json.loads(response)
success = response_payload.get("status") == "acknowledged"
self.metrics.record_attempt(latency_ms, success)
if success:
self._dispatch_webhook(payload, latency_ms)
logger.info("audit_ack_success", messageId=payload["messageId"], latency_ms=latency_ms)
else:
logger.warning("audit_ack_failed", messageId=payload["messageId"], response=response_payload)
return success
except websockets.exceptions.InvalidStatusCode as e:
logger.error("websocket_connection_rejected", status_code=e.code, reason=e.reason)
return False
except json.JSONDecodeError:
logger.error("websocket_response_malformed", raw_response=response)
return False
@retry(
wait=wait_exponential(multiplier=1, min=2, max=8),
retry=retry_if_exception_type(httpx.HTTPStatusError)
def _dispatch_webhook(self, payload: dict, latency_ms: float):
self._http.post(
self.webhook_url,
json={
"event": "receipt.acknowledged",
"messageId": payload["messageId"],
"timestamp": payload["timestamp"],
"latencyMs": latency_ms,
"badgeCleared": payload["badgeCount"] == 0
headers={"Content-Type": "application/json", "X-Source": "cxone-receipt-acker"}
if e.response.status_code == 429:
logger.warning("webhook_rate_limited", url=self.webhook_url)
raise
logger.error("webhook_dispatch_failed", status_code=e.response.status_code)
The following script combines authentication, validation, payload construction, and transmission into a single executable module. Replace the placeholder credentials before execution.
import structlog
structlog.configure(
processors=[structlog.processors.JSONRenderer()],
wrapper_class=structlog.make_filtering_bound_logger(logging.INFO),
context_class=dict,
logger_factory=structlog.PrintLoggerFactory()
def main():
# Configuration
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
ORG_NAME = "your_org_name"
GUEST_ID = "guest_abc123"
MESSAGE_ID = "msg_xyz789"
WEBHOOK_URL = "https://your-external-archive.com/api/v1/webhooks/cxone-receipts"
DELIVERY_TIMESTAMP = datetime.now(timezone.utc) - timedelta(seconds=5)
# Step 1: Authentication and SDK Initialization
auth_manager = CxoneAuthManager(CLIENT_ID, CLIENT_SECRET, ORG_NAME)
api_client = auth_manager.initialize_sdk()
# Step 2: Validate Message and Presence
validator = PresenceAndMessageValidator(api_client)
if not validator.validate(GUEST_ID, MESSAGE_ID):
logger.error("validation_pipeline_aborted", guest_id=GUEST_ID, message_id=MESSAGE_ID)
return
# Step 3: Construct Acknowledgment Payload
payload = build_acknowledgment_payload(MESSAGE_ID, DELIVERY_TIMESTAMP)
except TimeoutError as e:
logger.error("payload_validation_failed", error=str(e))
return
# Step 4: Transmit and Track
acker = CxoneReadReceiptAcker(ORG_NAME, GUEST_ID, auth_manager.get_access_token(), WEBHOOK_URL)
success = acker.send_receipt(payload)
# Step 5: Report Metrics
logger.info(
"acknowledgment_cycle_complete",
success=success,
success_rate=f"{acker.metrics.get_success_rate():.2f}%",
avg_latency_ms=f"{acker.metrics.get_average_latency():.2f}"
main()
- Cause: The OAuth token expired or the client credentials lack the required scopes.
- Fix: Verify that
conversations:readandwebchat:guests:writeare included in the token request. Implement token caching with a 60-second safety buffer before expiration. - Code Fix: The
CxoneAuthManagerclass automatically refreshes tokens whentime.time() > _expires_at - 60.
Error: 429 Rate Limited
- Cause: Excessive acknowledgment requests trigger CXone rate limiting or external webhook endpoints throttle incoming traffic.
- Fix: Implement exponential backoff. The
tenacitydecorator handles retries with jitter. For webhooks, ensure your archive endpoint supports idempotency keys to prevent duplicate processing during retries.
Error: WebSocket InvalidStatusCode 403
- Cause: The guest token embedded in the WebSocket URL is invalid, expired, or lacks messaging permissions.
- Fix: Regenerate the guest session token via the CXone Web Chat SDK or admin console. Ensure the
guestIdparameter matches the validated session.
Error: Maximum Delay Limit Exceeded
- Cause: The acknowledgment attempt occurs more than 30 seconds after the original message delivery timestamp.
- Fix: Process read receipts immediately upon UI visibility. If batch processing is required, segment messages by delivery window and discard receipts that fall outside the 30-second protocol constraint.
Error: JSONDecodeError on WebSocket Response
- Cause: CXone returns a binary ping/pong frame or a malformed server response.
- Fix: Filter WebSocket frames by checking
msg.opcode == websockets.frames.OPCODE_TEXTbefore parsing. The production code wrapsjson.loadsin a try-except block to prevent crashes.
