503 on MCP trying to read defaults-ng.vxml
Hi guys,
So I’m stuck again with this installation…MCP complains about this:
2012-12-12 17:20:57.314 DBUG 00000000-00000000 5428 08500500 VGDocumentManager.cxx:875 Fetching document, uri: file://C:/Program Files/GCTI/MCP/config/defaults-ng.vxml, nMaxage: -1, nMaxstale: -1, enctype: application/x-www-form-urlencoded, post: GET, timeout: 30000
2012-12-12T17:20:57.314 Int 50016 00E1010C-10002EE3 5428 wf_lookup file://C:/Program Files/GCTI/MCP/config/defaults-ng.vxml
2012-12-12 17:20:57.314 DBUG 00E1010C-10002EE3 5428 0C000000 VXMLSession.cxx:1894 ProcessEvents() Event queue was empty
2012-12-12 17:20:57.314 DBUG 00E1010C-10002EE3-00000004 4924 01F00000 FMThreadQueue.cxx:438 Connection #0 seems to be dead!
And then it gives a 503 error
2012-12-12 17:20:58.344 DBUG 00000000-00000000 4924 01F00000 FMResponseData.cxx:326 HTTP/1.0 503 Service Unavailable
When i try to open the file manually it also fails… ???
Had anybody suffered this issue?
Cheers
Removed VOICE from grammar file (as still don’t integrate TTS) and now it handles it…but now SQUID is having some issue because refuses connection…next step…
disable squid :slight_smile: - if it is MCP 8.1.5 I had some issues with IPv6 - I had to disable it on network interface and laso force host to resolve to IPv4 address instead of IPv6 address
Yup, removed it from the options and now it at least attempts to play the prompt…but I think now I have a codecs issue…one step further!
Just FYI,
according to manual you should use the URI as file:///C:/Program Files/GCTI/MCP/config/defaults-ng.vxml with 3 ‘/’ after the file. i had an issue where used 2 and nothing worked when trying to get the defaults.
Removing SQUID options worked. Then had an issue on MediaGateway with codecs configuration, now it works. I’m only stuck so far at the transfer stuff
