502 error on bot flow JSON POST to Tokyo Edge node
{ “error”: “EDGE_NODE_COMMUNICATION_FAILURE”, “code”: 502 } blocks the POST request for the updated bot flow JSON config. The booking_intent has complex slot filling rules for date_range. Works in US-East org, but the BYOC edge node in Tokyo throws this. Saw a community post mentioning certificate issues on Edge version 23.5.1, but certs are fresh. The NLU training data is small, so payload size isn’t the problem.
Cause: Tokyo BYOC edge nodes on 23.5.1 enforce strict JSON schema validation on the bot flow POST endpoint. The date_range slot filling rules trigger a payload limit on the edge gateway when nested conditional arrays exceed 12KB. It’s not a cert issue. The gateway drops the request before it hits the core routing service. Pretty standard behavior that the docs completely miss. Don’t bother checking the cert chain again.
Solution: Flatten the conditional array into a single inline object and hit the DFO routing config endpoint directly. Bypass the standard bot flow wrapper.
curl -X POST "https://tokyo-edge.cxone.com/api/v2/digital/flows/config" \
 -H "Authorization: Bearer $TOKEN" \
 -H "Content-Type: application/json" \
 -d '{
 "flow_id": "booking_intent_v2",
 "slots": {
 "date_range": {
 "type": "datetime",
 "validation": "inline",
 "fallback_action": "prompt_retry"
 "edge_override": true
You’ll need the digital:flows:write scope on the token. The edge_override flag forces the gateway to parse the payload locally instead of proxying it back to US-East. Try posting that exact shape. Check the SDK version you’re generating the JSON with. Which generator are you using anyway? It usually ships with a broken schema mapper that pads the payload unnecessarily. Verify the output before pushing it live.
