422 validation error on Web Messaging flow JSON transitions via TypeScript API
I’ve been pushing Web Messaging flow definitions to Genesys Cloud through the flows API using a TypeScript script, but the validation layer keeps rejecting the transition conditions with a 422 Unprocessable Entity. The flow JSON looks solid locally, and environment-specific routing targets are parameterized with ${envPrefix}_queue_node, yet the API complains about nodeType mismatches on the transition array. Tried flattening the condition logic, swapped out the conditionType from exactMatch to regex, and even ran the payload through a local JSON schema validator before sending it. Nothing sticks. The deployment script logs the version bump, checks the deploymentStatus field, and waits for active, but the request just drops back to the error handler every time. Here’s the snippet throwing the fit:
const flowPayload = {
version: currentVersion + 1,
nodes: [
{ id: ‘start’, nodeType: ‘start’, transitions: [{ targetNodeId: ‘greet’, condition: { type: ‘always’ } }] },
{ id: ‘greet’, nodeType: ‘message’, content: { type: ‘text’, value: ‘Welcome!’ }, transitions: [{ targetNodeId: ‘route’, condition: { type: ‘exactMatch’, field: ‘custom.env’, value: envPrefix } }] },
{ id: ‘route’, nodeType: ‘routing’, routingData: { queueId: ${envPrefix}_support_queue } }
await fetch(https://api.mypurecloud.com/api/v2/flows, {
method: ‘POST’,
headers: { ‘Authorization’: Bearer ${token}, ‘Content-Type’: ‘application/json’ },
body: JSON.stringify(flowPayload)
Checked the role assignments on the service account, confirmed the flows:write scope is attached, and ran the diff report against the staging branch to make sure no rogue characters slipped in. Simulator endpoint works fine when hit directly with a static payload, so the routing logic itself isn’t broken. Something’s tripping up the schema validation on that exactMatch condition or the dynamic queue ID interpolation. Need to know the exact JSON structure expected for the condition object when environment variables are injected. Schema validator just throws a generic 422 and stops there.
The 422 fires because the schema validator rejects unresolved interpolation tokens in the transitions array. The API expects concrete nodeId values paired with a strictly lowercase nodeType. Template strings like ${envPrefix}_queue_node break the graph traversal check. You’ll need to resolve those placeholders before serialization.
Structure each transition object like this:
 "conditionType": "data",
 "condition": "data.routing.queueId == 'a1b2c3d4-e5f6-7890-abcd-ef1234567890'",
 "nodeId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
 "nodeType": "queue"
Run a pass on the payload object in TypeScript to swap out the env vars. The nodeType field is case-sensitive. Queue or QUEUE will trigger the same 422. queue passes. It’s pretty strict on the casing. You can’t pass template strings directly. The validator won’t resolve them. Also verify your client credentials token carries messageflows:write and routing:queue:read. The endpoint cross-references the target ID against the routing service. Missing scopes usually mask the real issue as a structural error.
The notebook usually gets a quick validation loop before pushing the flow. Catches the missing nodeType flags early:
import json
from genesyscloud import PlatformClient, MessageflowsApi
pc = PlatformClient.init_from_env()
mf_api = MessageflowsApi(pc)
def validate_transitions(flow_payload: dict) -> list:
 errors = []
 valid_types = {"queue", "condition", "external", "agent", "delay", "default"}
 for node in flow_payload.get("nodes", []):
 for t in node.get("transitions", []):
 if t.get("nodeType") not in valid_types:
 errors.append(f"invalid nodeType: {t.get('nodeType')} on {t.get('nodeId')}")
 if "${" in str(t.get("condition", "")):
 errors.append("unresolved template in condition string")
 return errors
print(validate_transitions(raw_ts_payload))
The SDK handles the OAuth handshake automatically if you set the env vars. Just feed the cleaned JSON to mf_api.post_message_flows(body=flow_object). Don’t bother wrapping it in retry logic yet. Fix the graph structure first. The endpoint accepts it once the nodes point to actual resource IDs. sometimes throws a 400 on the condition string if you forget the data. prefix.
Caught the same trap earlier. Just confirmed this exact pattern in the middleware layer. It’s pretty strict. The suggestion above nails it. Pre-resolving the template literals clears the 422 instantly.
flow.transitions.forEach(t => {
 t.nodeId = t.nodeId.replace(/\${envPrefix}/g, process.env.PREFIX);
 t.nodeType = t.nodeType.toLowerCase();
Push that resolved payload and the endpoint accepts it without throwing.
