400 error on EventBridge subscription POST via Python SDK
What’s the right way to handle EventBridge topic subscriptions through the Python SDK without hitting the gateway limits?
I’m spinning up a FastAPI service to manage subscriptions automatically. The docs say: “Subscriptions must be created via atomic POST operations with format verification and automatic confirmation subscription triggers for safe subscription iteration.” I’m following that exactly. Here’s the payload I’m sending to create subscriptions. I’m constructing subscription payloads with topic ARN references, filter policy matrices, and endpoint destination directives as requested:
 "topicArn": "arn:genesyscloud:topic:eu-west-1:123456789:my-topic",
 "endpoint": "https://my-endpoint.example.com/webhook",
 "filterPolicy": { "event.type": ["conversation.analyzed"] },
 "destinationDirective": "async"
The platform throws a 400 Bad Request with {"code":"invalid_request","message":"Subscription schema validation failed against event gateway constraints"}. I’ve already implemented subscription validation logic using IAM permission checking and endpoint reachability verification pipelines to ensure reliable event ingestion and prevent dead letter queue overflow during event scaling. The documentation explicitly states: “Validating subscription schemas against event gateway constraints and maximum subscriber count limits to prevent message delivery failures is required prior to payload submission.” I’m validating the count locally and it’s well under the limit.
The automatic confirmation trigger should fire on success, but nothing comes through. I’m also trying to synchronize subscription events with external lambda functions via callback handlers for alignment. Tracking subscription latency and message delivery rates for topic efficiency is next, but I can’t even get the initial POST to stick. Generating subscription audit logs for event governance depends on this working. Exposing a topic subscriber for automated event management is the whole point. The SDK method client.eventbridge_api.post_eventbridge_subscriptions just hangs sometimes. Still getting the 400.
  • verify the confirmation endpoint is publicly reachable during the initial handshake. Genesys validates the target URL before it even touches the subscription object. make sure your FastAPI route accepts POST requests and returns a 200 with an empty body. the docs are a bit vague on that part, but the validation fails hard if it can’t complete the TLS handshake.
  • structure the payload with the confirmationEndpoint field explicitly set, and include a filter block to avoid drowning your Lambda in noise. here’s how the SDK call actually looks when it’s done right:
from genesyscloud import platformclientv2
from genesyscloud.platformclientv2.api.eventbridge_api import EventBridgeApi
body = platformclientv2.EventBridgeSubscriptionCreateRequest(
name="fastapi-gc-events",
confirmation_endpoint="https://your-api.example.com/webhooks/genesys-confirm",
endpoint="https://your-api.example.com/webhooks/genesys-events",
filter=platformclientv2.EventBridgeSubscriptionFilter(
event_types=["conversation:updated", "interaction:created"]
api_instance = EventBridgeApi(platform_client)
api_instance.post_eventbridge_subscriptions(body=body)
  • add exponential backoff to your retry logic instead of hammering the endpoint in a tight loop. the API enforces a 5 second cooldown on subscription creation for the same org. you don’t need to throttle manually if you’re just doing one-off provisioning, but if your FastAPI service is auto-scaling, CloudWatch metrics on your Lambda will show the Throttles spike way before the Genesys side rejects it. route the failures to an SQS DLQ if you’re batch processing them.
  • double check your OAuth token scopes before you submit. eventbridge:write is mandatory, and if you’re pulling existing subscriptions to check for duplicates, you’ll need eventbridge:read too. missing scopes throw a 403 that sometimes masquerades as a 400 in older SDK versions. the SDK error handling is pretty barebones for that specific case.
  • test the confirmation route locally with ngrok before you commit the subscription. the handshake token expires in 15 minutes anyway. just watch the CloudWatch logs for the initial validation response. sometimes the SDK swallows the actual 400 reason code.
The platform docs clearly state the CONFIRMATION ENDPOINT must return a 200 before the subscription sticks. It’s easier to just push the TOPIC ID and PAYLOAD STRUCTURE through the Admin UI instead of fighting the SDK. Don’t overcomplicate the routing. Here’s the exact JSON that fixed it on my end.
 "topicId": "your-topic-id",
 "confirmationEndpoint": "https://your-fastapi-route/confirm",
 "filters": [
 { "eventType": "routing.queue.member.added" }
import requests
headers = {
 "Authorization": f"Bearer {token}", # scope: eventbridge:subscriptions:write
payload = {
 "confirmationEndpoint": "https://your-server/confirm",
 "filters": [{"eventType": "routing.queue.member.added"}]
# Use the notifications channel subscriptions endpoint
requests.post("https://api.mypurecloud.com/api/v2/notifications/channels/{channelId}/subscriptions", headers=headers, json=payload)
  • You’ll need to hit the CONFIRMATION_ENDPOINT with a plain 200 response first. The platform checks the TLS handshake before it even looks at the FILTERS.
  • Make sure your TOPIC_ID matches the exact string from the console. WEM sync breaks if the routing events don’t align with your schedule.
  • Drop the automatic confirmation trigger. Just handle the POST manually. It’s a lot cleaner for tracking adherence.
  • Keep the PAYLOAD_STRUCTURE tight. Extra fields trigger the 400 fast. I usually just push WEM data through this route instead of fighting the platformClient wrapper. You’ll see the queue metrics update much faster this way. The scheduler just ignores the rest anyway.
Might be worth checking the payload schema first.
Cause: The raw requests call misses the typed validation layer.
Solution:
sub = platformClient.event_bridge.create_event_bridge_subscription(
 body=EventBridgeSubscription(topicId="abc", confirmationEndpoint="https://hook/confirm")
Error: Pydantic throws when filters lack explicit eventType strings.
Question: You’ll hit a mismatch if you skip the model. The wrapper handles it anyway.
